    Cannot get response from Duet for M400
    1.3k
    • johnundefined
      john
      I am having trouble reading the "ok" messages from the Duet when I connect over serial port in python.
      When I send a move command, such as "G1 X100", I write to the serial port with a python script. The code I execute needs to know when the movement has physically completed, so I added an M400 command when I was using a different controller board. I would then wait for the appropriate number of "ok" responses, and then my software would move forward.
      When I read the serial port on the Duet, I only occasionally grab the heartbeat "ok" messages when the board automatically sends M105.
      Is there a way to increase the read rate of responses from the Duet? My baud rate is at 115200. Thanks.
        The serial port on Duets is generally used for connecting a PanelDue, so OK responses are not sent to it. If you want to receive OK responses, I suggest you use the USB port instead.
        johnundefined 1 Reply Last reply Reply Quote 0
        • johnundefined
          john
          Thanks for the quick response.
          I use the built in pySerial class to open the connection, which uses the USB Port as best I understand it:
          ser=serial.Serial("/dev/tty.usbmodem", 115200, timeout=0.1)
          Is there an alternate way to connect over USB?
          • johnundefined
            john @dc42
            @dc42 Really all I want is a way to get controlled "OK" messages back from the board. I found a work around where I send the following series of commands:
            G1 ; Any command here it doesn't matter
            M400 ; This waits for everything upstream to execute
            M105
            M105
            The M105 command returns "ok T" for my configuration, presumably trying to tell me the bed temp for a bed that doesn't exist. So, it doesn't matter to me if I connect over USB or Serial, just that I can get back expected "ok" messages easily. But, I am concerned that using this M105 command will have unintended consequences.
            What is the best way in your opinion, to get back these "ok" messages at the conclusion of Move-execution?
            Thanks!
              If you have Marlin compatibility selected in M555, you should get an "ok" response for every command sent via USB or Telnet. I've just tested this, and I do get "ok" after M400 sent via USB.
              • johnundefined
                john
                Ok, based on your direction I set the compatibility mode to Marlin with the command: "M555 P2" and reset the board. I'm not getting any "ok" messages back that are different from before.
                  dc42 administrators @john
                  @sean said in Cannot get response from Duet for M400:
                  Strange, it works for me, sending the commands from YAT. Please try sending those same commands from a terminal emulator.
                  • johnundefined
                    john
                    @dc42 Thanks for sticking with me on this. When I set the firmware compatibility to Marlin previously, I just sent the M555 S2 command from the terminal emulator. After thinking about it some more, I thought to add the command directly to the general config.g settings, and it worked!
                    I now get an "ok" back for every command I send. I added two M400 commands to make sure I know when the batch of movement commands are completed executing.
                    I should say too that I am using a Mac terminal for most of this development work, and also used Pronterface and Arduino IDE previously, but hadn't set the Marlin compatibility directly in config.g
                    I am also using serial.Serial() to open the connection via USB port. Works great!
                    tl;dr Receive "ok"s by setting M555 S2 in config.g file, instead of trying to send M555 S2 over terminal. (I think setting it in the config file makes it more permanent)
