    Wifi module keeps disconnecting
    70
    10.6k
      @r123:
      ps don't forget the two links (from the documentation to the Betas on github) are broken: https://duet3d.dozuki.com/Wiki/Firmware_Overview#Section_Betas
      Thanks, I've corrected that link.
      • kirk001undefined
        kirk001
        I've gone through the Troubleshooting AJAX errors and my last signal strength says 50dbm. I can't stay connected for more than a minute before I get a request timeout. I'm using firmware, server & web control 1.21. Where should I go from here?
          dc42 administrators @kirk001
          @kirk001, have you tried changing your router WiFi channel between 1, 6 and 11 ?
          kirk001undefined 1 Reply Last reply Reply Quote 0
          • kirk001undefined
            kirk001 @dc42
            @dc42 Yes, sir. All 3 and same result.
              I think we need to change your Duet in case the WiFi module is faulty. Please contact your supplier. If you purchased it directly from Duet3D, see https://duet3d.com/warranty.
              • kirk001undefined
                kirk001
                Thank you.
                • kirk001undefined
                  kirk001
                  I just received my warranty replacement board and installed it. I'm getting fewer disconnect errors, but I'm still getting them. My M122 shows "WiFi signal strength -50dBm, reconnections 0, sleep mode modem."
                  I don't think I've configured anything incorrectly, but a second defective board would be quite unlucky. What are my options for getting this to work consistently?
                  • MortarArtundefined
                    MortarArt
                    kirk001 - the solution I used was to create a Wireless Hosted Network on my Win10 workstation that I use to access the Duet. This has the added bonus of keeping the Duet offline. If your computer is closer to the printer than your router it could be worth a shot. There's similar functions in Linux.
                    • kirk001undefined
                      kirk001
                      Both my computer and the printer are 6 feet away from the router. I have a raspberry pi 10 feet away that can has no problem staying connected.
                      I can't believe I spent almost $200 on this and still can't print 4 months later.
                        @kirk001 said in Wifi module keeps disconnecting:
                        I'm sorry to hear that you are still getting problems. I would expect a signal strength a little better than -50dBm if the Duet is only 6ft from your router, but -50dBm should be enough for a reliable connection.
                        A few questions:
                        • Do the disconnections occur when the Duet is idle, or only when printing?
                        • Have you increased the maximum number of Ajax retries in the settings/general page of DWC?
                        • Do you have a password set, other than the default "reprap"?
                        • kirk001undefined
                          kirk001
                          Signal strength ranges from -40-50dBm, but -50dBM is the worst it gets. The board is sitting at the bottom of my Hypercube--I don't know if that is what's making the signal strength worse at 6ft.
                          Disconnections occur when idle. I haven't been able to print. I can't stay connected more than 10 seconds. I've tried channels 1,6, and 11. I'm using a Netgear Nighthawk and I had 4 other devices on the 2.4G working fine. I removed the other 4 devices in case they might interfere with the Duet.
                          AJAX retries are at 5.
                          And have no password at the moment (it was really tedious to have to enter a password 5 times in one minute because it kept disconnecting every 10 seconds.)
                            That's worse than I've ever heard happen before. Please can you connect a PC running e.g. YAT or Pronterface to the Duet, and send M111 S1 P13 (if using YAT, set the end-of-line sequence to "LF only"). This will enable WiFi debugging. When DWC connects, you will see a few lines of debug. When you get a disconnection, there may be some more debug messages - please post them here.
                            The latest DWC (1.21.1) remembers the password when it reconnects.
                            • kirk001undefined
                              kirk001
                              Something odd just happened. I logged into my Duet from 2 different computers. On one, I connected directly to the IP address, and on the other, I connected to my "duet.local" address. The one connected directly to the IP address has stayed connected for over an hour now while the "duet.local" connection has disconnected 20+ times. I haven't tried printing yet. but this is the longest I've been able to stay connected.
                                Interesting! Were you previously always using "duet.local" to connect?
                                If you are able to capture a Wireshark trace showing the network traffic on the PC at the time it disconnects, that may also help us diagnose the problem.
                                • kirk001undefined
                                  kirk001
                                  Yes "Duet" was the name I put in the config.g file and "Duet.local" was the address I've been using.
                                  I'm downloading Wireshark now.
                                  • kirk001undefined
                                    kirk001
                                    I was able to do a Wireshark capture (I hope I did it correctly.) I saved it to a file (1.7Mb). Should I upload it here or e-mail it to you?
                                      Please post it on Dropbox or another file sharing site, and post the link here, if you are happy that it doesn't contain confidential information.
                                      • kirk001undefined
                                        kirk001
                                        https://www.dropbox.com/s/rgbvi0l4k5xb25u/Duet Stream.pcapng?dl=0
                                          Thanks, that's on my list to look at soon.
                                            I tried to download that file but it looks like you deleted it. Do you still have it?
