    Wifi module keeps disconnecting
    70
    10.5k
      dc42 administrators @kirk001
      @kirk001 said in Wifi module keeps disconnecting:
      I just received my warranty replacement board and installed it. I'm getting fewer disconnect errors, but I'm still getting them. My M122 shows "WiFi signal strength -50dBm, reconnections 0, sleep mode modem."
      I don't think I've configured anything incorrectly, but a second defective board would be quite unlucky. What are my options for getting this to work consistently?
      I'm sorry to hear that you are still getting problems. I would expect a signal strength a little better than -50dBm if the Duet is only 6ft from your router, but -50dBm should be enough for a reliable connection.
      A few questions:
      • Do the disconnections occur when the Duet is idle, or only when printing?
      • Have you increased the maximum number of Ajax retries in the settings/general page of DWC?
      • Do you have a password set, other than the default "reprap"?
      • kirk001undefined
        kirk001
        Signal strength ranges from -40-50dBm, but -50dBM is the worst it gets. The board is sitting at the bottom of my Hypercube--I don't know if that is what's making the signal strength worse at 6ft.
        Disconnections occur when idle. I haven't been able to print. I can't stay connected more than 10 seconds. I've tried channels 1,6, and 11. I'm using a Netgear Nighthawk and I had 4 other devices on the 2.4G working fine. I removed the other 4 devices in case they might interfere with the Duet.
        AJAX retries are at 5.
        And have no password at the moment (it was really tedious to have to enter a password 5 times in one minute because it kept disconnecting every 10 seconds.)
          That's worse than I've ever heard happen before. Please can you connect a PC running e.g. YAT or Pronterface to the Duet, and send M111 S1 P13 (if using YAT, set the end-of-line sequence to "LF only"). This will enable WiFi debugging. When DWC connects, you will see a few lines of debug. When you get a disconnection, there may be some more debug messages - please post them here.
          The latest DWC (1.21.1) remembers the password when it reconnects.
          • kirk001undefined
            kirk001
            Something odd just happened. I logged into my Duet from 2 different computers. On one, I connected directly to the IP address, and on the other, I connected to my "duet.local" address. The one connected directly to the IP address has stayed connected for over an hour now while the "duet.local" connection has disconnected 20+ times. I haven't tried printing yet. but this is the longest I've been able to stay connected.
              Interesting! Were you previously always using "duet.local" to connect?
              If you are able to capture a Wireshark trace showing the network traffic on the PC at the time it disconnects, that may also help us diagnose the problem.
              • kirk001undefined
                kirk001
                Yes "Duet" was the name I put in the config.g file and "Duet.local" was the address I've been using.
                I'm downloading Wireshark now.
                • kirk001undefined
                  kirk001
                  I was able to do a Wireshark capture (I hope I did it correctly.) I saved it to a file (1.7Mb). Should I upload it here or e-mail it to you?
                    Please post it on Dropbox or another file sharing site, and post the link here, if you are happy that it doesn't contain confidential information.
                    • kirk001undefined
                      kirk001
                      https://www.dropbox.com/s/rgbvi0l4k5xb25u/Duet Stream.pcapng?dl=0
                        Thanks, that's on my list to look at soon.
                          I tried to download that file but it looks like you deleted it. Do you still have it?
                          • Knaudlerundefined
                            Knaudler
                            Hello
                            I have Wifi Problem since 1.20
                            if wifi AP reboots, DuetWifi never reconnect
                            all Clients reconnects fine - Duet nope
                            need to Power off (or go via USB and restart network)
                            I using Unifi wifi AP Mesh - works great
                            when need to update, reprovisioning, scan frequencies something likes this,
                            wifi disconnects short time
                            checked settings - all fine
                            no Problem with other clients (10-20)
                            DuetWifi no reconnect after wifi disconnect/signal lost
                            reset wifi, delete wifis ...no
                            checkt with 1.20, 1.21 nope
                            no I'm using wifiServer 1.19.2 - that works fine !
                            with unifi I can push wifi reconnect for spezial client or can block clients
                            so I can test reconnection of DuetWifi
                            now I'm using this kombination:
                            Firmware Version: 2.0(RTOS) (2018-06-05b3)
                            WiFi Server Version: 1.19.2 <-------
                            Web Interface Version: 1.21.1
                            no wifi Problems any more
                            stable and faster
                            and the AP shows the hostname of duetwifi again
                            connection Data from AP:
                            99% (-52 dBm) 72.2 Mbps 54 Mbps
                            good, stable upload speed (100MB gcode)
                            Uploading File(s), 46% Complete (762.1 KiB/s)
                            m122:
                            === Network ===
                            Slowest loop: 222.84ms; fastest: 0.01ms
                            HTTP sessions: 1 of 8
                            • WiFi -
                              Network state is running
                              Failed messages: pending 3, notready 0, noresp 0
                              WiFi firmware version 1.19.2
                              WiFi MAC address 60:01:94:31:48:f2
                              WiFi Vcc 3.08, reset reason Turned on by main processor
                              WiFi flash size 4194304, free heap 38968
                              WiFi IP address 192.168.2.220
                              WiFi signal strength -50dBm, reconnections 0, sleep mode unknown
                            so with WifiServer 1.19.2 wifi disconnects eg. reconnect Problems are gone
                            Greetings from HH
                            Ingo (Knaudler)
                              @Knaudler, thanks for your feedback. My best guess is that the change in the ESP8266 SDK to fix the KRACK WPA2 vulnerability was incompatible with your router. I heard a rumour that this fix was incompatible with some routers.
                              There is an even newer version of the SDK available now, so I will update DuetWiFiServer to use it in the next few days, then you can test whether it works for you.
                              • Knaudlerundefined
                                Knaudler
                                thanks
                                maybe I can double check with Fritzbox 7490 (Labor)
                                if this can help
                                FritzBox is most use Router in germany
                                • Knaudlerundefined
                                  Knaudler
                                  same with Fritzbox 7490 (last beta - only 20mhz, no pmf)
                                  after wlan off ... 30sek wlan on
                                  no reconnect of wifiServer 1.21
                                  with 1.19.2 ok
