Duetwifi and paneldue 7“
PanelDue
1.3k
    tkamsker
    Hi
    I Build an hypercube 300x 300 with an different Z axis and have tested now some Hardware
    Smoothieboard Rads 1.5 and now the duet wifi ,.
    I use 0.9 degreees Steppers and it works Fine ( i just Need to tweak the sensorless Homing )
    But the 7“ Panel is Lightning but Shows nothing
    I found somewhere a hin5 That they ned same Speed 56700 ok granted
    Question 1
    Where do i find the Info how to verify that ?
    Q2
    Is there a way to get Both up to 25000 ?
    Q3
    Do others have Same issue ?
    Thx in advance
    Thomas
      Is the screen showing the buttons etc. But stuck at status "Connecting", or is it blank? Or something else?
        tkamsker
        Wow that is fast
        It Shows just a Kind of dark screen backlithed
        So i use Pronterface to kick the wlan on and Then i use the Web Browser ...
        That is why i think no handshake and all Pixels Are in Same State
        Thx
        Thomas
          Even if it is not connected to a Duet, PanelDue should display the printer status screen (without real values of course) if it is supplied with power. So I suspect that either it was not programmed, or the Erase button has been pressed. You can try uploading firmware to it if you wish, see the installation instructions page.
            tkamsker
            Ok
            I am Roaming Next dass but Then i search for the Article how to Flash the Panel
            And respond success or failure
            Thx
            Thomas
              tkamsker
              Hello
              I now feel a little dumb because i found https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware which i s quite clear but i didn't find how to flash the panel due ? I have a lot of Arduino experience i do programs Granite devises Delta Servos so i have a good chance to achieve it but somehow i didn't find the panel please push me to the right direction thx thomas
                Alex9779
                No idea if there is some other source but I referred to https://miscsolutions.wordpress.com/paneldue/ when updateing the PanelDue FW...
                  Yes, see the link that Alex provided. For the 7.0 integrated version, use file PanelDue-v3-7.0i.bin from https://github.com/dc42/PanelDueFirmware/releases/tag/1.20.
                  5 out of 8
