    24V Pump - can I connect direct?
    3.7k
    • Hergonowayundefined
      Hergonoway @dc42
      Based on your recommendations, is the schematic below the right one for connecting an air pump directly to the Duet ?
      Delta goes BrrrRRRRrrrrrRRRRrrr
        Yes it is. The flyback diode is optional if the Duet is revision 1.02 or later, but having one close to the motor will help to reduce any interference generated when you PWM the motor.
        • SM3Dundefined
          SM3D
          @dc42 and @benkay just wanted check with both of you my wiring before connecting to my duet 1.01. I followed the post and wired the pump accordingly. Here are the pictures:
          Please let me know whether it is correct or not. I surely do not want to blow my Duet.
          Cheers,
          Vasan
          Good judgement comes from experience but experience comes from bad judgements
          Hergonowayundefined 1 Reply Last reply Reply Quote 0
            Hergonoway @SM3D
            @sm3d seems correctly set
            • SM3Dundefined
              SM3D
              Thanks @Hergonoway will update whether berd air is effective or not
              Cheers,
              Vasan
              • benkayundefined
                benkay
                Looks correct to me...although I understand that the later boards have the diode in-built so not strictly necessary to add one there.
                Tevo Little monster with Duet Wifi and Smart Effector / magball arms upgrades.
                Original Prusa i3 Mk3
                  Hergonoway @SM3D
                  @sm3d In my case, putting the thermistor didn't closed the circuit as it should, so for now and until @dc42 finish his tests regarding what should be used I don't use the thermistor. For info I'm running the air pump MAX in 24v sold by makerhive.
                  • SM3Dundefined
                    SM3D
                    @Hergonoway I have trouble running the pump with thermistor from PWM controlled fan ports but I could run them with always on fan ports. Here is my post about it:
                    https://forum.duet3d.com/topic/5449/not-able-to-pwm-for-berd-air-pump/10
                    I even shorted the legs of thermistor and tried from PWM fan ports but no luck. If you have any ideas please post it.
                    Cheers,
                    Vasan
                    • BenDieselundefined
                      BenDiesel
                      So I have a 24v berdair hooked directly up. I usually run at 25 to 30% and have the Pam set to 255khz.
                      The motor get rather warm. Almost to hot to tuch. Should I be concerned?
                        Hergonoway
                        255K is way to high try 25K (F25000). In my case the sound and the temp dropped a lot.
                        Note that I've directly connected the 1/8" ID Tygon tube to the metal tube, it reduce pressured area and reduce heat from the pump mechanism (the white plastic part)
