    Beginner Needs Help - Anycubic Kossel Plus + Duet WiFi -- HOW?
    141
    28.6k
    • Danalundefined
      Danal @Juice
      @juice said in Beginner Needs Help - Anycubic Kossel Plus + Duet WiFi -- HOW?:
      Ok thanks mindbender. I just finished measuring mine, i made a jig and measured as best i could with a steel ruler and all but 1 came out to about 266.5mm, not quite the 268 that they are supposed to be. Anycubic QC needs some work. The one arm is longer and fits the jig a fair bit tighter than all the others, it may be .1-.2 mm longer. Does anyone have any suggestions on what i should do in this situation?
      Be sure and set M665 L to 266.5, even if it seems to make things worse at first; getting that right is foundational to getting all the other settings.
      With regard to the difference, I wouldn't count on getting anything better from Anycubic. Also, I was getting decent prints with stock arms where one was .9mm longer. So... accept it until you upgrade it... If you can, "pair" the arms as best as possible to a given carriage. Longest two together, etc.
      • Danalundefined
        Danal @mindbender9
        @mindbender9 said in Beginner Needs Help - Anycubic Kossel Plus + Duet WiFi -- HOW?:
        and eyeballed to center position in each eye.
        Tip for the future: When measuring center-center between holes that are identical, measuring to the same end (e.g. "right" or "top") of each hole is equivalent, and much more precise than eyeball center.
        Having said that, I would NOT take your machine apart again.
        And, just checking basic assumptions: You have M665 L271, correct?
        mindbender9undefined 1 Reply Last reply Reply Quote 0
        • Juiceundefined
          Juice @mindbender9
          @mindbender9 I've had my printer for 2 months now and i suppose i could see if they'd send me a new rod, but I think i'll just put my efforts into upgrading to magnetic ones. We both have the same model with rods that are not the 268mm that they are quoted as being. Who knows what length of rod i'll end up with.
          @Danal Do you have magnetic arms on your anycubic kossel? If so, did they fit the effector and carriages without any modifications?
          Thanks
          • mindbender9undefined
            mindbender9 @Danal
            @danal said in Beginner Needs Help - Anycubic Kossel Plus + Duet WiFi -- HOW?:
            LOL - No argument here.
            Yes, config.g still has M665 L271 set. I'm working on the bed issues and will remove the stock bed mounts and pursue the direct attached method.
            Thanks for the help! I'll start up a test print when I get home from work.
            • Danalundefined
              Danal @Juice
              I did mod my printer to have mag ball "Haydn Huntley - Blue Eagle Labs" rods. I actually ordered them from either Amazon or Ultibots, I don't remember. I have a linear, NON plus, so I used 218mm. For a plus, they will be different. I printed adapters for the existing effector, and printed adapters for the carriages that more-or-less completely replace the plastic part of the carriage. Found both on Thingiverse.
              The effector is not on the printer right now because I am trying something different (also mag ball).
              This one mod made the most difference in print quality of anything I did. I highly recommend it.
              0_1528324319867_AKL Mag Ball Carriages.JPG 0_1528324402124_AKL Mag Ball Effector Adapter Crop.jpg
              3mmundefined 2 Replies Last reply Reply Quote 0
              • 3mmundefined
                3mm @Danal
                @Danal , @mindbender9
                I did mod my printer to have mag ball "Haydn Huntly" rods. I actually ordered them from either Amazon or Ultibots, I don't remember. I have a linear, NON plus, so I used 218mm. For a plus, they will be different. I printed adapters for the existing effector, and printed adapters for the carriages that more-or-less completely replace the plastic part of the carriage.
                I mod'd my 'AC kossel linear plus' (although that is what I bought, it isn't what I received), but in any case I got the Hayden diagonal-rod mag-ball rod arms from UltiBots.
                MindBender, I recommend that you work to establish a relationship with a quality robotics vendor and UltiBots is a good one in my estimation.
                Solve the problems, get yourself a Smart-Effector and mag-ball terminated diagonal-rods, that'll fix the parts problems, the bowl-shaped bed and all the messing around trying to figure out what those cheeseballs over at AnyCubic sent ya. And with the Smart-Effector solution...everything snaps together, so-to-speak. Plus you get a in-built build area illumination 3x bright white LEDs, everything has connectors for easy removal/re-connection, and a slick z-probe auto-sensing height-sensor (everything in this art requires tweaking) and it works really well too. One of the points alot of folks miss about the Smart-Effector is that its a low mass unit, compared to the heavy effector that AnyCubic implemented. Low mass is very tastey in delta printing.
                That's my two centavos here in LA, Ca, United States of Mexico!!
                3mm
                There are 10 types of people: Those who understand binary and those who don't.
                • Juiceundefined
                  Juice
                  I've decided to stick with my original rods since before i undertook the upgrade, the machine was printing good, 20 mm calibration cubes printed within 0.1 mm deviation, so i guess the small difference in that one rod isn't enough to make a huge difference in print quality.
                  What would make a huge difference is the 3mm difference in rod spacing between effector and carriages that i didnt notice during the upgrade!! 🤦 I upgraded to robotdiggs carriages and they have 20mm spacing while the anycubic effector has 43mm. I spent 2 days scratching my head over why i couldn't get good calibration even though everything seemed to be within good tolerance. Then I realized that i never measured the effector. Luckily i have a spare one that does have 40mm spacing and now i can use my V6 without any modifications...although i do lose 37mm in build height. Anyway, first calibration with new effector got me 0.031 deviation, and that's without a probe. Now, on to the minor things so i can get printing again.
                  Stick with it mindbender, you'll get yours running well too!
                  • 3mmundefined
                    3mm @Danal
                    @danal
                    Hi Danal.....your mag-ball effector-adapter strategy is clever.
                    3mm
                    • Danalundefined
                      Danal @Juice
                      Deviation is part of the story. Here's another part:
                      Bottom is stock AKL rods. Top is Haydn magnetic. Otherwise identical. Even same G-Code file.
                      Middle is a different experiment, not relevant to this discussion.
                      Juiceundefined 1 Reply Last reply Reply Quote 0
                      • Juiceundefined
                        Juice @Danal
                        @danal The parts that i printed before i started my upgrade weren't as good as your top print but were much better than your bottom print, even better than the middle one. That was with the old trigorilla board, i have yet to do any prints with the duet. That said, i am sure that having those sweet magnetic arms would be beneficial, its just that if i can get good quality prints with the arms i have, i'll hold off on the upgrade until i have some money burning a hole in my pocket. 😁
                        Ok, made my first print with the duet upgraded anycubic kossel. Looks pretty good to me. X & Y dimensions need tweaking though. 0_1528556110256_IMG_20180609_114303.jpg
                          mindbender9
                          So more weird results.
                          I've attached the DC42 IR Sensor to the hot-end (effector?) and connected the sensor to the Duet following the instructions. I've changed my M558 P-value to P1 and followed the first half of the instructions on David's webpage for the IR sensor (Link).
                          • If I put an object right near the bottom of the sensor, the LED lights up solid. I take my hand away, the LED turns off. Nice.
                          • On the Duet device webpage, the Z-Probe value remains at a value of 280 no matter what the Z-height is. It fluctuates between 279-280, and that's it.
                          • With 12V power applied, I enter M558 P1 then I enter G31 P500 Z1.0 on the G-Console. After setting the Z-height manually with 2 sheets of paper, I raise the nozzle 5mm up as instructed, then G92 Z0 to set Z=0.
                          • Following the instructions, I enter G30 S-1 and the nozzle buries itself into the bed again HARD. Here's a screenshot of the Console:
                          • If I press "Home All" the assembly raises itself up to the top but doesn't click the end-stops. I then get an error:
                          G28
                          Error: G0/G1: insufficient axes homed
                          Error: Homing failed
                          Here's the config files:
                          • config-override.g (I commented the weird values out again):
                          ; Delta parameters
                          ;M665 L271.000 R152.869 H301.792 B85.0 X6.799 Y4.280 Z0.000
                          ;M666 X2.286 Y-0.607 Z-1.679 A0.00 B0.00
                          ; Heater model parameters
                          M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
                          M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                          M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                          M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                          M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                          M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                          M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                          M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                          • config.g:
                          ; Configuration file for Duet WiFi (firmware version 1.20 or newer)
                          ; generated by RepRapFirmware Configuration Tool on Sun May 13 2018 19:16:40
                          G90					; Send absolute coordinates...
                          M83					; ...but relative extruder moves
                          M555 P1					; Set firmware compatibility to look like RepRapFirmare
                          ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
                          M665 R134 L270 B85 H285		; Set delta radius, diagonal rod length, printable radius and homed height
                          M666 X0 Y0 Z0			; Put your endstop adjustments here, or let auto calibration find them
                          M550 Pduettest
                          M552 S1					; Enable network
                          M586 P0 S1				; Enable HTTP
                          M586 P1 S0				; Disable FTP
                          M586 P2 S0				; Disable Telnet
                          M558 P1 X0 Y0 Z0 H5 F1000 T5000 ;I1 		; Set Z probe type to DC42 and the dive height + speeds
                          G31 X0 Y0 Z1.0 P500				; Set Z probe trigger value, offset and trigger height
                          M557 R130 S20					; Define mesh grid
                          M569 P0 S1					; Drive 0 goes forwards
                          M569 P1 S1					; Drive 1 goes forwards
                          M569 P2 S1					; Drive 2 goes forwards
                          M569 P3 S1					; Drive 3 goes forwards
                          M350 X16 Y16 Z16 E16 I1				; Configure microstepping with interpolation
                          M92 X80 Y80 Z80 E96				; Set steps per mm
                          M566 X1200 Y1200 Z1200 E1200			; Set maximum instantaneous speed changes (mm/min)
                          M203 X18000 Y18000 Z18000 E1200			; Set maximum speeds (mm/min)
                          M201 X1000 Y1000 Z1000 E1000			; Set accelerations (mm/s^2)
                          M906 X1000 Y1000 Z1000 E800 I30			; Set motor currents (mA) and motor idle factor in per cent
                          M84 S30						; Set idle timeout
                          M208 Z0 S1					; Set minimum Z
                          M574 X2 Y2 Z2 S1				; Set active high endstops
                          M305 P0 T100000 B4267 C0 R4700			; Set thermistor + ADC parameters for heater 0
                          M143 H0 S120					; Set temperature limit for heater 0 to 120C
                          M305 P1 T100000 B4267 C0 R4700			; Set thermistor + ADC parameters for heater 1
                          M143 H1 S275					; Set temperature limit for heater 1 to 275C
                          M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                          M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                          M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                          M563 P0 D0 H1					; Define tool 0
                          G10 P0 X0 Y0 Z0					; Set tool 0 axis offsets
                          G10 P0 R0 S0					; Set initial tool 0 active and standby temperatures to 0C
                          M501
                          homedelta.g:
                          ; homedelta.g
                          ; called to home all towers on a delta printer
                          G91                        ; relative positioning
                          G1 S1 X290 Y290 Z290 F1800 ; move all towers to the high end stopping at the endstops (first pass)
                          G1 X-5 Y-5 Z-5 F1800 S2    ; go down a few mm
                          G1 S1 X10 Y10 Z10 F360     ; move all towers up once more (second pass)
                          G1 Z-5 F6000               ; move down a few mm so that the nozzle can be centred
                          G90                        ; absolute positioning
                          ;G1 X0 Y0 F6000            ; move X+Y to the centre
                          Entering the command "G30 S-1" is hanging me up. I've tried to do an auto-calibration and the nozzle took a number of measurements in the air above the bed ranging from 3mm - 130mm.
                          Can anyone make sense of this? I have not resolved the bed angle issue yet, but this is something else entirely. Please help! Thanks!
                            That suggests that either you have connected the OUT pin of the IR sensor to the wrong pin, or there is a bad connection in that wire. It should be connected to the pin labelled IN on the Probe connector. That's the pin on the opposite end of the connector to the 3.3V pin.
                            • Danalundefined
                              Danal
                              Also, homing MUST work before anything else.
                              homedelta.g should have much larger values in the first G1 command larger than the physical printer, so that the carriages go all the way to the switches, something like
                              G1 S1 X400 Y400 Z400 F1800
                                mindbender9 @dc42
                                @dc42 said in Beginner Needs Help - Anycubic Kossel Plus + Duet WiFi -- HOW?:
                                Ah ok. Thanks @dc42 - I'll reterminate the wire when I get home.
                                  mindbender9 @Danal
                                  Thanks @Danal - I'll update homedelta.g when I get home.
                                  Is this related to why the "G30 S-1" command to bury the nozzle hard into the bed (when it shouldn't move the Z position)?
                                  Danalundefined Juiceundefined 2 Replies Last reply Reply Quote 0
                                  • Danalundefined
                                    Danal @mindbender9
                                    Very likely.
                                    • Juiceundefined
                                      Juice @mindbender9
                                      @mindbender9
                                      I see your M558 H parameter is still set to 5. Change it to 30mm as suggested by dc42 a few weeks back. I crashed my probe into the bed a few times over before i found that post. I believe that H parameter sets the height the probe moves to before actually doing any probing. If 5mm takes the probe below the bed before probing starts, it will crash every time.
                                      Have you tried doing a manual calibration without a probe again, just to eliminate any fussiness with probes for now? I gave up using my probe as it wasn't consistent enough, probably a result of the frequent bed crashes. Manual calibration was quick, easy and accurate enough.
                                        mindbender9
                                        All -
                                        I've made the two changes as instructed:
                                        M558 P1 X0 Y0 Z0 H30 F1000 T5000
                                        Progress so far:
                                        • The auto probe calibration works with the Z probe except for the far XY edge where it drags along the bed (the IR sensor is positioned off the side of the bed - it sees nothing so the nozzle eats the bed). This is amazing progress, though. Because reterminating the IR Z probe connectors got it to work (in theory).
                                        • However, it looks like the printer still thinks that Z=5.3 is the same thing as Z=0. When I try to print something like the XYZ calibration cube, the nozzle drops down to Z5.30 (5.3mm above the bed) and spews filament onto the bed. Recalibrating (and entering M500 to save settings) doesn't resolve the issue. What might be causing this stubborn behavior in the printer?
                                        Here are my config files:
                                        config.g:
                                        M550 Pduettest
                                        M558 P1 X0 Y0 Z0 H30 F1000 T5000 ;I1 		; Set Z probe type to DC42 and the dive height + speeds
                                        G31 X0 Y0 Z2.02 P500				; Set Z probe trigger value, offset and trigger height
                                        M501
                                        config-override.g:
                                        ; Delta parameters
                                        M665 L270.000 R134.000 H285.000 B85.0 X0.000 Y0.000 Z0.000
                                        M666 X0.000 Y0.000 Z0.000 A0.00 B0.00
                                        bed.g:
                                        ; bed.g
                                        ; called to perform automatic delta calibration via G32
                                        M561 			; clear any bed transform
                                        G31 X0 Y0		; don't want any probe offset for this - ADDED 5/21/2018
                                        G28			; home the printer
                                        M401			; deploy the Z probe
                                        ; bed.g file for RepRapFirmware, generated by Escher3D calculator
                                        ; 10 points, 6 factors, probing radius: 105, probe offset (0, 0)
                                        ;M98 Pdeployprobe.g
                                        G30 P0 X0.00 Y105.00 Z-99999 H0
                                        G30 P1 X90.93 Y52.50 Z-99999 H0
                                        G30 P2 X90.93 Y-52.50 Z-99999 H0
                                        G30 P3 X0.00 Y-105.00 Z-99999 H0
                                        G30 P4 X-90.93 Y-52.50 Z-99999 H0
                                        G30 P5 X-90.93 Y52.50 Z-99999 H0
                                        G30 P6 X0.00 Y52.50 Z-99999 H0
                                        G30 P7 X45.47 Y-26.25 Z-99999 H0
                                        G30 P8 X-45.47 Y-26.25 Z-99999 H0
                                        G30 P9 X0 Y0 Z-99999 S6
                                        ;M98 Pretractprobe.g
                                        ; DEFAULT SETTINGS - Set by the RepRapFirmware Wizard
                                        ; Probe the bed at 3 peripheral and 0 halfway points, and perform 3-factor auto compensation
                                        ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
                                        ;G30 P0 X0 Y84.9 H0 Z-99999
                                        ;G30 P1 X73.53 Y-42.45 H0 Z-99999
                                        ;G30 P2 X-73.53 Y-42.45 H0 Z-99999
                                        ;G30 P3 X0 Y0 Z-99999 S3 ;H0
                                        M402 ; retract the Z probe
                                        G1 X0 Y0 Z150 F15000 ; get the head out of the way of the bed
                                        homedelta.g
                                        ; homedelta.g
                                        G1 S1 X400 Y400 Z400 F1800 ; move all towers to the high end stopping at the endstops (first pass)
                                        Any suggestions? Thanks!
                                        • Danalundefined
                                          Danal
                                          The probe is going off the side of the bed because your offset from the probe to the nozzle is set to zero.
                                          In bed.g:
                                          and in config.g:
                                          The X and Y in G31 should accurately describe the distance from the probe to the nozzle.
                                          • Danalundefined
                                            Danal
                                            As for Z 5.3, etc.
                                            What is the physical offset of the probe to the nozzle in the Z direction?
                                            G31 is telling the printer this is 2.02. Is it really? At the moment the probe triggers (like with your finger), what is the EXACT Z dimension to the tip of the nozzle, as compared to the probe?
