X Axis Stopped funtioning
axis grinds axis stopped skipping stepps cant home x axis x axis not moving
1.1k
    enix
    I'm new to the duet, but have been in 3D printing for about 4-5 years now. I moved from RAMPs and similar controllers running Marlin FW. I love the board and, while different, it was quite easy to get up and running. I did all the normal calibrations and such and have been printing for over a week now, with great results, but then all the sudden, in the middle of a print, the X axis skips several steps (usually in the negative direction).
    I re-homed the axis and it functioned fine, so I considered that maybe it caught a blurb on the print and skipped. So I started a new print and it didn't even finish the first layer before skipping a lot. I cleared the area and tried to move the X axis on its own from the web interface and it was very loud and choppy. I verified the belt is not loose and that it is just the motor humming like it is missing the steps. I shut off the idle hold to the printer and moved the axis by hand and it moved easily as it always has. So then I tried homing it and the axis just made the grinding noise I had been hearing and barely moved. At this point, I am thinking that the motor burnt or had an issue, so I swapped it with a new one. I made sure the coils are correctly wired and connected and tried again but got the same result. I double checked all wires were good and coils connected correctly again but can't seem to find the issue. Is it possible the driver has gone out? As I said, it had been printing fine for over a week straight (at least 10 hours a day on 1.75 hr prints), and now I can't do simple 10mm movements or home the axis. Any help would be appreciated.
    undefined 1 Reply Last reply 8 Jun 2018, 19:39 Reply Quote 0
      T3P3Tony administrators @enix
      @enix can you post M122 results please, while the X axis is causing issues.
        enix
        6:04:11 PMM122
        Used output buffers: 3 of 32 (9 max)
        RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later
        Board ID: 08DGM-956GU-DJ3SN-6J1FA-3SJ6Q-KAN3F
        Static ram used: 16152
        Dynamic ram used: 100408
        Recycled dynamic ram: 2224
        Stack ram used: 1224 current, 4400 maximum
        Never used ram: 7888
        Last reset 00:04:31 ago, cause: power up
        Last software reset at 2018-06-07 21:00, reason: User, spinning module GCodes, available RAM 7888 bytes (slot 1)
        Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
        Error status: 0
        Free file entries: 10
        SD card longest block write time: 0.0ms
        MCU temperature: min 29.7, current 35.7, max 36.0
        Supply voltage: min 12.2, current 12.3, max 12.4, under voltage events: 0, over voltage events: 0
        Date/time: 2018-06-08 18:04:10
        Slowest main loop (seconds): 0.014005; fastest: 0.000046
        MaxReps: 1, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 239, MaxWait: 3670778439ms, Underruns: 0, 0
        Scheduled moves: 2, completed moves: 2
        Bed compensation in use: none
        Heater 1 is on, I-accum = 0.0
        Segments left: 0
        Movement lock held by null
        http is idle in state(s) 0
        telnet is idle in state(s) 0
        file is idle in state(s) 0
        serial is idle in state(s) 0
        aux is idle in state(s) 0
        daemon is idle in state(s) 0
        queue is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
        HTTP sessions: 1 of 8
        • WiFi -
          Network state is running
          WiFi firmware version 1.21RC4(08b3)
          WiFi MAC address 5c:cf:7f:76:69:b6
          WiFi Vcc 3.33, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 16064
          WiFi IP address 192.168.1.101
          WiFi signal strength -38dBm, reconnections 0, sleep mode modem
          Socket states: 2 0 0 0 0 0 0 0
          === Expansion ===
          enix
          I got that just after trying to home the X axis only. A window popped up with "Error: G0/G1: insufficient axes homed" after it stopped making the grinding noise.
            enix
            And here is my config.g file. In case it helps...
            ; Configuration file for Duet WiFi (firmware version 1.20 or newer)
            ; generated by RepRapFirmware Configuration Tool on Sun Jun 03 2018 15:43:28 GMT-0400 (Eastern Daylight Time)
            M550 PBob ; Set machine name
            M551 Preprap ; Set password
            M552 S1 ; Enable network
            M586 P0 S1 ; Enable HTTP
            M586 P1 S0 ; Disable FTP
            M586 P2 S0 ; Disable Telnet
            M569 P0 S0 ; Drive 0 goes backwards
            M569 P3 S0 ; Drive 3 goes backwards
            M92 X100 Y100 Z405.887 E150.96 ; Set steps per mm
            M566 X720 Y720 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
            M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
            M201 X1000 Y1000 Z250 E250 ; Set accelerations (mm/s^2)
            M906 X1000 Y1000 Z1000 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X250 Y250 Z320 S0 ; Set axis maxima
            M574 X1 Y1 S1 ; Set active high endstops
            M574 Z1 S2 ; Set endstops controlled by probe
            M558 P1 H4 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
            G31 P500 X-2 Y-19 Z0.35 ; Set Z probe trigger value, offset and trigger height
            M557 X15:235 Y15:235 S20 ; Define mesh grid
            M143 H0 S85 ; Set temperature limit for heater 0 to 85C
            M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
            M143 H1 S260 ; Set temperature limit for heater 1 to 260C
            M106 P0 S0.5 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
            M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
            M106 P2 S1 I0 F500 H1 T80 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
            M563 P0 D0 H1 ; Define tool 0
            T0 ; Select first tool
              The most like causes are a bad crimp connection in the motor cable, or a faulty driver. It's rare for stepper motors to develop electrical issues, although occasionally they seize up due to swarf.
              To test this, with power off swap the X and Y motor connectors over where they plug into the Duet. Power up and send M564 H0 to allow jogging before homing. Then try jogging the X and Y motors:
              • When you ask to jog X, it will jog the Y motor, which is plugged into the X output. If that works, the problem is the X motor cable. If it shows the same problem, then the problem is most likely with the driver.
              • When you ask to jog Y, it will jog the X motor. If that doesn't work, the problem is the cable.
              If it looks like a driver problem, you can use M564 X4 Y1 Z2 E3 in config.g (before any M906 or M350 commands) to map the X motor to the E1 driver, and plug the X motor cable into the E1 output.
              If these tests confirm that the X driver is faulty, please ask your supplier to repair or replace the Duet under warranty.
                enix
                Thank you very much for the reply. I don't know why I didn't think to try that, probably the frustration of the issue. Either way, that helped me solve it. Turns out it was a wire issue. I couldn't get any sort of continuity variance, but changing it out for a new one fixed the issue. Thanks again.
                6 out of 7
