    DuetWIFI migration
    13.5k
      Thanks, I've implemented that and it's working. Just a few tests do to before I release a new beta.
      • mhackneyundefined
        mhackney
        David, I ended up writing a shell script to create the DuetWebControl.bin file that works on OS X and Linux. I have it building and I unpacked your .bin and mine and compared and they are the same layout, files, etc. I need to upload and test it first though as the concat stuff might have a bug. However, I did find several places in your dcwspiff.bat file that I believe have incorrect file paths:
        src\js\jquery-2.2.1.min.js+src\js\jquery.textarea_autosize.min.js+src\js\jquery.flot.min.js+src\js*jquery.resize.min.js*+src\js\jquery.flot.navigate.min.js+src\js\bootstrap.min.js+src\js\bootstrap-notify.min.js+src\js\bootstrap-slider.min.js+src\js*jzip.min.js*+src\js\model.js+src\js\viewmodel.js build\js\all.js
        should be jquery.flot.resize.min.js
        should be jszip.min.js
        I think I got that right!
        Once I have tested my .bin I'll send you the shell script and special instructions for linux and OS X (nothing special, just where to get mkspiffs, etc).
        cheers,
        Michael
        My 3D Printing blog: http://www.sublimelayers.com
        Coming this summer: "3D Printing Strategies - the art of perfecting your designs and prints"
          Thanks Michael, I'll incorporate those corrections in my new release. If you send me a pull request or just a copy of your MacOS script, I'll add it to github.
          • mhackneyundefined
            mhackney
            David, this is very perplexing. I built DuetWebControl on OS X and verified that it has all the correct files packaged properly. after uploading and restarting, DWC won't stay connected. So I reverted to the .bin from your GIT but the same problem is occurring. I then reverted to the .bin that was on the CF card with the beta Duet WiFi and it's still happening. Once this happens with this message:
            Error
            Could not establish a connection to the Duet firmware! Please check your settings and try again.
            not only can I not reconnect from the same browser, I attempted to connect with Firefox and Safari and they both report server not found. I was attending a wedding all day so haven't had time to investigate further but will do so tomorrow.
            • mhackneyundefined
              mhackney
              I see that you posted a 1.11b-dc42 so I tried it and the same thing happens and I also do not see the monospace font in the Configuration File panel so that is odd. Something is going on that doesn't make sense.
              • Toddimusundefined
                Toddimus
                @mhackney:
                For what it's worth…
                I tried to play with the DuetWiFi a bit today and loaded up the new firmware bundle from dc42's beta release earlier today. I don't have a PanelDue and didn't want to use the USB interface, so I did it from the WiFi interface. The main firmware loaded fine and I power cycled after it came back up. Version 1.15beta3 showed up on the web interface settings screen. Then, I uploaded both the webserver and WiFi chip firmware via the web interface. Ran M997 S1 and let it do it's thing for about 90 seconds and then did M997 S2. The blue light on the WiFi antenna lit up (which I never had noticed before), but it never went out. The web interface settings page never showed the newer web server firmware update version. I then power cycled the Duet and tried M997 S1:2 and waited about 5 minutes. After that, I did another power cycle and everything seems to be as it should be. The latest versions showed up on the web interface.
                  It takes a few minutes to update DuetWebControl. I am going to use the diagnostic LED to indicate firmware update in progress, but in the mean time the blue LED on the wifi module is a good indicator that the update is still in progress.
                  Updating DuetWiFiServer sometimes happens fast enough for DuetWebControl to reconnect after the green firmware updating bar has run its course, and sometimes not.
                  DuetWebControl doesn't yet understand what M997 S1 or S2 do, so it won't automatically refresh the web interface after M997 S2.
                  • mhackneyundefined
                    mhackney
                    Well, I've had no luck recovering. Here's how I got to this point:
                    installed and commissioned the stock beta Duet WiFi
                    made 1 print
                    updated PanelDue firmware to the latest
                    made 1 print
                    made my monospace font hack and rebuilt the DuetWebControl.bin
                    uploaded via the web interface (via iap4e.bin that was stock to the Duet WiFi)
                    web interface would not stay connected very long
                    thought maybe a problem with my build of DuetWebControl.bin
                    reverted to DuetWebControl.bin from David's GIT (pre v. 1.11b-dc42) via web interface
                    same problem, web interface drops connection
                    reverted to DuetWebControl.bin from the CF card that came with the Duet WiFi via web interface
                    reverted to DuetWebControl.bin v. 1.11b-dc42 via web interface
                    And Ive rebooted the Duet WiFi several times in the process, it just won't stay connected and I'm at a loss at what to do.
                    • mhackneyundefined
                      mhackney
                      Interesting, I just rebooted (power off and on) and when it came up and was able to connect for 30ish seconds, I looked at the Settings->General page and see:
                      Firmware Name: n/a
                      Firmware Version: n/a
                      Web Interface Version: HTML: 1.11, JS: 1.11a-dc42
                      And this should have been the 1.11b-dc42
                      So something is amiss, I am going to reinstall the firmware and all other components via bossac over USB.
                      • mhackneyundefined
                        mhackney
                        Ok, this is a bummer. When I erase/reset DuetWiFI I do not see the device show up in /dev on OS X. I've done this hundreds of times on other Duets and was able to do it on this board. I seem to be in a funky state. So without a serial port, I can't reinstall the firmware. I am going to try to do this from a Windows 10 laptop.
                        • mhackneyundefined
                          mhackney
                          Why does this seem like deja vu all over again!?
                          Now on a Windows 10 laptop. I've used bossac from this machine successfully.
                          I hook up USB, press erase for a few seconds and then reset. I hear the Windows device "bee bop" sound. I see COM3 show up in Device Manager->Ports (COM & LPT). I run:
                          bossac –port=COM3 -U true -e -w -v -b DuetWiFiFirmware.bin -R
                          (at the same level where the firmware is located) and get:
                          no device found on COM3
                          And now I have no firmware installed so it did actually erase.
                            Michael, please see the firmware upload instructions at https://duet3d.com/wiki/Updating_main_firmware. You can't use bossac because it doesn't support the SAM4 processor used on the Duet WiFi.
                            • mhackneyundefined
                              mhackney
                              ok! That would make sense then! I'll do that now, sorry for not reading!
                              • Toddimusundefined
                                Toddimus
                                It might have assigned another com port to the duet. You can see if it found the new port and get its number…
                                I don't know windows 10 very well but in windows 7, it's under device manager then scroll down the list to COM/LPT ports and it hopefully shows up.
                                Or you could just try COM 4 in the bossac command. I bet that's it. 🙂
                                • mhackneyundefined
                                  mhackney
                                  I had to go to Backup procedure #2 but get this:
                                  Connecting…
                                  [ERROR] Could not connect to /dev/tty.usbmodem14431 at baudrate 57600:
                                  Serial error: could not open port /dev/tty.usbmodem14431: [Errno 2] No such file or directory: '/dev/tty.usbmodem14431'
                                  So on to Emergency proceedure?
                                  • mhackneyundefined
                                    mhackney
                                    Toddimus, thanks but you probably didn't read David's reply, can't do it with bossac on the Duet WiFi!
                                    • mhackneyundefined
                                      mhackney
                                      EDITED, stay tuned
                                      • mhackneyundefined
                                        mhackney
                                        Ok, I am able to install firmware with SAM-BA from Windows 10. I can now connect from Pronterface on Windows or Mac.
                                        I then did Backup procedure #1 with the original .bin files that were installed on the CF when I got it.
                                        I reenabled WIFI by sending M552 S1 from Pronterface. And connected from a web browser and got this 3 seconds later:
                                        Communication Error
                                        An AJAX error has been reported, so the current session has been terminated.
                                        Please check if your printer is still on and try to connect again.
                                        Error reason: timeout
                                        Note that I had placed all 3 .bin files (including DuetWebControl.bin) on the CF card for Backup procedure #1. Does M997 S0 also install it? Or do I need to do this manually with the web interface?
                                        • mhackneyundefined
                                          mhackney
                                          Forgot to mention, after doing the above the Settings->General panel shows:
                                          firmware version 1.13 (2016-06-13)
                                          Web interface: 1.11 JS: 1.11a=dc42
                                          Is this the as-sent stock configuration?
                                          • mhackneyundefined
                                            mhackney
                                            David, are you sure that the reported version # for the DuetWebControl.bin you uploaded yesterday is 1.11b-dc42?
                                            I've attempted to upload this version 3 times now to verify that I can upload and I get the 1.11a-dc42 version even after a hard reboot.
                                            At this point I am not able to stay connected to the web interface for very long at all. Interestingly, if I am quick and get an upload started, it seems to complete that successfully and then drops the connection a few seconds later. Perhaps it isn't actually uploading the new web control. Is there another way to install the web control?
