    Printable Radius
    • Craigundefined
      Craig
      I am just setting up a new delta and was using the RepRap Configuration tool. I came across a term I do not understand. It is called printable radius and has a max setting of 85 in the program. My printer has a print diameter of 330mm and I would think my print radius would be half of that or 165mm. Where am I going wrong?
        T3P3Tony administrators @Craig
        @craig the printable radius is the radius of the print bed that you want to keep the effector inside:
        The default is 85 and it wont go higher than your diagonal rod length.
        • Craigundefined
          Craig
          Thanks for the timely advice.
          • Danalundefined
            Danal
            Two things:
            1. Printable radius is essentially the size of your bed. You MAY need to reduce this a few mm if there is anything that would prevent the tip of the nozzle reaching certain points, such as the edges of the effector, or a cooling fan, or similar, hitting belts or a tower.
            2. Keep in mind that the online generator is a "help get started" aid and it is NOT the be-all end-all for every possible configuration or setting. For example, it won't allow printable radius over 260. I have a printer with a printable radius of 304. Set this directly in the M665. Here is mine, for my large-ish delta:
            M665 L720.280 R329.188 H626.825 B304.0 X-0.454 Y-0.014 Z0.000
