    Cant get my nozzle close to bed at all when trying to print
    6.9k
    • Puppet172undefined
      Puppet172 @whosrdaddy
      How can i control my fans in the new server version because i only see control for Fan 0 and i have mine on 1&2
      Puppet172undefined 1 Reply Last reply Reply Quote 0
        Puppet172 @Puppet172
        @puppet172
        Nvm
          Puppet172
          Still not using the mesh bed compensation during print. Even after i updated. Any idea why?
            Phaedrux Moderator @Puppet172
            @puppet172 Did you add the M375 or G29 S1 command to load the height map to your config.g?
              Puppet172 @Phaedrux
              @phaedrux
              no where would i add that
              0_1530485751276_config (3).g
                Just add M375 anywhere in config.g.
                I put mine in the section where I configure the mesh size and z probe.
                  Puppet172 @Phaedrux
                  @phaedrux
                  That should fix it then?
                    That will load the height map if you've run a successful compensation probing. That will adjust the nozzle height based on the probe data to keep it at the specified height from the bed at all times.
                    Hopefully that will resolve your issue.
                      Puppet172 @Phaedrux
                      @phaedrux
                      if i change me trigger height should i run another mesh bed compensation( G29)
                        I'm not sure about that. As long as the probe is triggering consistently when you make the map the new trigger height should be applied after homing z and it should follow the height map correctly, but I could be wrong in my thinking there.
                        Regardless, I like to follow this order for bed leveling just to make sure.
                        Mechanically level your bed as well as you can first.
                        Measure your trigger height at least 10 times and take the average (or mode if it looks like a single value repeats most often).
                        Then run a compensation probing routine knowing that the results should be as accurate as possible.
                        Then you can varify that the height compensation is applied by moving to z=0.5 and jogging the head over the bed and see if the z axis is engaging to keep the distance the same as it moves.
                          Puppet172 @Phaedrux
                          @phaedrux @dc42
                          When im doing a mesh bed compensation It keeps getting to a point where the bed is a little higher there and it triggers the probe before it probes there. so i get this
                          Error: Z probe already triggered before probing move started
                          Is there anyway to get around this because all my axis's are level the bed just isnt
                          Thanks
                            You can try increasing your dive height a millimeter or two.
                              Puppet172 @Phaedrux
                              @phaedrux
                              Where is that?
                                @puppet172 @Phaedrux
                                Nvm found it
                                  The H value in the M558 command in config.g
                                    @puppet172 did it work?
                                      Puppet172 @Phaedrux
                                      @phaedrux @dc42
                                      Yeah it worked.
                                      And another question. When i re did my G29 to have more points to be more accurate, now when ever i print it is much higher off the print bed like a couple millimeters. Why would this be happening?
                                      Thanks
                                        @Phaedrux @dc42
                                        I don't think the bed level is working to well
                                          Yeah that's a bit too high maybe.
                                          Can we get some more details of your printer? Print surface? Slicer settings?firmware version?
                                          Puppet172undefined 2 Replies Last reply Reply Quote 0
                                            Puppet172 @Phaedrux
                                            @phaedrux
                                            Ok So my printer is massive its about 3 ft cubed and has two arms controlling the y and one controlling the x and finally 4 lead screws controlling the z. it is printing onto a piece of aluminum that is screw down to box tube then that screwed into the frame the bed is not level by itself. i have tried my best to get it level on its own but to no avail. On that aluminum sheet is 1 foot squares of PEI i bought off amazon and have pieced together to make a bed surface. i am using Cura 15.04.6 as a slicer, but have been thinking about buying Simplify 3d.
