Weird G32/G29 Error
No, i had the problem since yesterday and didnt use a BL-Touch. I had an Orion and before an IR Probe. Just updated today from 1.21 to 2.0 and made the config complete new but both changed nothing. There aren`t deployprobe.g or an retractprobe.g in my sys.
So it was working correctly with firmware 1.21 before? If so then it looks like the changes to the config files caused the problem.
No the error started at FW 1.21 and i did an upgrade to exclude an FW error. also G30, Homez and homeall did work but G32 and G29 doesnt do whats in bed.g or in M557
What did you do that triggered the error: a firmware upgrade from a version earlier than 1.21, or something else?
I run the FW 1.21 a couple of weeks, two weeks ago i changed from IR Probe to Orion. I first thought i made a mistake at my config.g yesterday, so i build a new one today. As this didn`t worked i made the FW Update to exclude an Firmware Issue.
Then i thought something on the Board is broken but G30, homeall and homez worked as they should.
Dont shure if this also is a part of the problem, but my last 3 Thermistor and Thermistor Cables made Heater Faults if the cable is moved in the wrong way...
Tried it again, Setup Firmware again, Homeall works like a charm. Start G32, first start point should is defined in bed.g as X40 Y40 but he tried to move to X-90 Y-90? What am i doing wrong?
Do you have any deployprobe.g. or retractprobe.g files that shouldn't be there?
@dc42 No, even after the new Installation of the Firmware isn't there a deployprobe.g or an retractprobe.g
Please share your config.g and bed.g files.
config.g
; Configuration file for Duet WiFi (firmware version 1.20 or newer)
; generated by RepRapFirmware Configuration Tool on Sat Jun 30 2018 19:52:00 GMT+0200; General preferences
M555 P1 ; Set firmware compatibility to look like RepRapFirmareM667 S1 ; Select CoreXY mode
M550 PHEVO ; Set machine name
M552 S1 ; Enable network
;*** Access point is configured manually via M587
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M92 X80 Y80 Z800 E2673 ; Set steps per mm
M566 X1000 Y1000 Z1000 E240 ; Set maximum instantaneous speed changes (mm/min)
M203 X12000 Y12000 Z250 E40 ; Set maximum speeds (mm/min)
M201 X800 Y800 Z250 E1000 ; Set accelerations (mm/s^2)
M906 X800 Y800 Z800 E500 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 X280 Y280 Z250 S0 ; Set axis maxima; Endstops
M574 X1 Y1 S1 ; Set active high endstops; Z-Probe
M574 Z1 S2 ; Set endstops controlled by probe
M558 P8 I1 R0.4 Z1 F300 ; Set Z probe type to unmodulated and the dive height + speeds
G31 P500 X140 Y140 Z-0.1 ; Set Z probe trigger value, offset and trigger height
M557 X20:280 Y20:280 S20 ; Define mesh grid; Heaters
M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
M307 H1 A469.9 C164.2 D9.6 B0; Fans
M106 P0 S1 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 F1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic saving after power loss is not enabled
M106 P1 S0
M572 D0 S0.08 ;Pressure Advancebed.g
; bed.g
; Probe the bed at 4 points
G30 P0 X40 Y40 H0 Z-99999
G30 P1 X40 Y140 H0 Z-99999
G30 P2 X40 Y270 H0 Z-99999
G30 P3 X140 Y270 H0 Z-99999
G30 P4 X270 Y270 H0 Z-99999
G30 P5 X270 Y140 H0 Z-99999
G30 P6 X270 Y40 H0 Z-99999 S0 -
In your G31 command you have specified that the Z probe is offset from the nozzle by 140mm (which is a very large offset) in both X and Y. So in order to put the probe at 40,40 the firmware has to put the nozzle at -100,-100.
facepalm feels like an idiot, doesn`t see that. Redefine the offset in G31 and everythings fine now. Thanks!
