Duet ethernet is not working
    allankisaiswaroop
    When i plugged ethernet cable to the Duet ethernet board it not lighting up and the other 3 lights (vin, 5v, 3.3v) are getting lightening up. please help in this
    undefined 1 Reply Last reply 5 Jul 2018, 19:05 Reply Quote 0
      T3P3Tony administrators @allankisaiswaroop
      @allankisaiswaroop sounds like there is either a faulty ethernet module or its not plugged into the board correctly. can you check that the ethernet module is plugged correctly into the main Duet board feel free to post some pictures so I can see as well.
      Can you connect to the Duet over the USB port using YAT under windows or a terminal under mac/linux. If so once you are connected send M122 and the post that here.
        allankisaiswaroop
        the ethernet module is plugged into the board and ethernet wire is plugged into it. and if i connect the usb to my computer its not showing port in my device manager of my computer
        This the duet ethernet board
        ![alt text](0_1530855015541_303194d8-3ef0-4828-8c23-3d85a17e3fa3.jpg image url)0_1530855018414_5a958795-60c6-436d-9af2-88b7a0f12558.jpg 0_1530855020039_9587b895-63ca-4228-9e4a-ffb8542f94b4.jpg 0_1530855022021_b36834d6-3930-4a00-8c1a-d109d52ce79c.jpg
        undefined 1 Reply Last reply 6 Jul 2018, 10:32 Reply Quote 0
          @allankisaiswaroop please can you contact who you purchased the board from as it will need to be replaced under warranty.
            allankisaiswaroop
            Hi sir,
            thank you for your reply. i bought it from you sir
            undefined 1 Reply Last reply 6 Jul 2018, 12:44 Reply Quote 0
              @allankisaiswaroop ok, I will ask @Roland to email you.
                allankisaiswaroop
                ok sir thank you.
                7 out of 7
