    Pressure advance issue?
    • JoduWeiundefined
      JoduWei
      Idk how that can happen...
      My bowden tube is ~80cm long
      M572 D0 S0.18
      PET-G @240°
      • JoduWeiundefined
        JoduWei
        This post is deleted!
          deckingman
          Why do you think it's a pressure advance issue? How did you arrive at the setting you are using? Have you tried turning pressure advance off completely to see if that cures the problem?
          JoduWeiundefined 1 Reply Last reply Reply Quote 0
          • JoduWeiundefined
            JoduWei @deckingman
            @deckingman
            Because its a fairly new setting in my config. I cant say if the problem appears without pressure advance on that model, because i dont want to print another 4 hours, before i know whats causing this.
            I printed a cube and changed the setting every 10mm.
              Did you reduce retraction a bit after enabling pressure advance? That may be necessary.
