    New beta Duet WiFi firmware bundle
    Firmware installation
    8
    32
    5.6k
    • Huguesundefined
      Hugues
      I installed and get wireshark listening my duet, to be sure i reinstalled the last bundle firmware but no timeout connection since 10min
      • RichRap3Dundefined
        RichRap3D
        No problems with the update for me, all installed fine.
        The print motion looks different to me, I can't quite put my finger on exactly what it is, but almost like accelerations have slowed down very slightly or maybe smoothed, but it may be just be me remembering what it was like in the last release.
        Anyone see or 'feel' and difference?
        Producing very good print results, so I'm happy.
        Cheers,
        Rich.
        • Huguesundefined
          Hugues
          I cannot confirm that the motion is slower in this new version but i notice a hudge difference when the model is like a low polygonal model with straight path than a curvy model. My extruder was clicking at 200mm/s on the polygonal and i've to slow down to 150 to get it work correctly, the hotend temperature was insanely high for PLA and on the curvy model with near the same loop length and without short curve, no problem.
          Did you feel this on the same model ?
          • Aussiephilundefined
            Aussiephil
            I've upgraded without any obvious issues and been connected on and off for 6 hours so far via the web page though no actual prints yet 🙂
            Upgrade was done via the web page for all the modules without any issues.
            Cheers
            Phil
            • mhackneyundefined
              mhackney
              David, I've been keeping statistics on disconnects the last few of days and been monitoring my network for the last day. Firstly, the original network issues that were antagonizing my original issue are gone so that is no longer a factor.
              My other 5 deltas are running Duet with a TP-Link wifi bridge and Duet Wifi are all on the same network. The other 5 are running 1.09z-ch firmware and 1.11 HTML and JS.
              In 72 hrs I've had 1 of the 5 disconnect one time but the other 4 have stayed connected (both printing and sitting idle over night) for 3 days.
              The Duet WiFi has disconnected 8 times in the same time period. The good news is, a simple click of Connect and it reconnects quickly.
              My 3D Printing blog: http://www.sublimelayers.com
              Coming this summer: "3D Printing Strategies - the art of perfecting your designs and prints"
                Michael, can you confirm that you are running DWC 1.11b-dc42 on the Duet WiFi?
                One of the items in the firmware plan is to rewrite the web server running on the ESP, using the Duet web server as a basis. That will hopefully reduce the disconnection rate further.
                • elmoretundefined
                  elmoret
                  This update seems to have resolved the timeout problem for me, 4 hours in without a disconnect.
                  How is the notification timeout supposed to work? Mine still don't auto-dismiss. Is it possible to make an option in the settings that when selected only shows the most recent notification instead of filling the whole browser window?
                  • briangilbertundefined
                    briangilbert
                    If I'm having to copy the DuetWiFiServer file onto the SD card by plugging it into my computer, what command do I need to run to ensure it gets installed?
                    Co-creator of the Zesty Nimble direct drive extruder
                    • mhackneyundefined
                      mhackney
                      David, I'm running 1.15-beta3 (2016-07-09) firmware on Duet WiFI
                      This machine has disconnected 3 times in the last 24 hrs since my report yesterday. My other 5 deltas running earlier Duets have not disconnected in the last 24 hrs. So to recap 96 hrs (4 days) I've only had 1 disconnect on a Duet 0.6 with a wifi bridge out of 5 printers total so:
                      Earlier Duets with WIFI bridges: 1 disconnect in (96hrs * 5 printers) = 1 disconnect in 480 hrs
                      Duet Wifi: 11 disconnects in 96 hrs
                      • elmoretundefined
                        elmoret
                        Update: 12 hours in, no disconnect error. Definitely the longest I've gone without a disconnect timeout, thanks David!
                          @mhackney:
                          It was the version of Duet Web Control that I wanted to know.
                          • mhackneyundefined
                            mhackney
                            Duet Web Control HTML: 1.11b-dc42, JS: 1.11b-dc42
