    Whats wrong?
    2.2k
    • peirofundefined
      peirof
      @dc42 said in Whats wrong?:
      That means the bed heater is turned on; although it will also be on if you use 24V VIN power and a separate 12V bed heater supply.
      Are connected to Duet..., bed and nozzle, with Tevo Little Monster default PSU, its 24v
        dc42 administrators @peirof
        @peirof said in Whats wrong?:
        add a screen capture from DWC, Machinne Propiety section..
        I think, in the other Duet, list more parts.... here only steppers. No?
        https://www.dropbox.com/s/dddqlbigeiodp3y/Duet Screen Capture.png?dl=0
        I have move carriges of towers by hand with no opposition (With power on)... Endstops, seems to be working, when i close the carriages to endstops, light turn off, and appears the status of "Endstops Hit" in DWC as YES
        Did you remember to send G91 to switch to relative mode before you sent the G1 S2 X10 and similar commands to test the motors?
        • peirofundefined
          peirof
          Yes,
          i have sended by console....
          G91
          and
          G1 S2 X10
          Nothing happens..
            Suggestions:
            1. Send M906 without parameters and confirm in the response that the motor currents have been set.
            2. Send M584 without parameters and check that the motor mapping is standard (X0, Y1, Z2).
            3. Send M122. In the report, check that the VIN voltage reads correctly and the stepper motor statuses are OK.
            4. Send M92 and check that the steps/mm reads back correctly.
            Which revision Duet do you have?
            • peirofundefined
              peirof
              ok... the results
              1. M906
              M906
              Motor current (mA) - X:1800, Y:1800, Z:1800, E:1200:1200:1200:1200:1200:1200:1200:1200:1200, idle factor 30%
              1. M584
              M584
              Driver assignments: X0 Y1 Z2 E3:4:5:6:7:8:9:10:11, 3 axes visible
              1. M122
              M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01beta1(RTOS) running on Duet WiFi 1.02 or later
              Board ID: 08DGM-956GU-DJMSJ-6J1F8-3S06T-KANZG
              Used output buffers: 3 of 20 (8 max)
              Static ram: 28452
              Dynamic ram: 96084 of which 0 recycled
              Exception stack ram used: 324
              Never used ram: 6212
              Tasks: NETWORK(ready,448) HEAT(blocked,1256) MAIN(running,3564)
              Mutexes: FilamentSensors(null) DHT(null) WiFi(NETWORK) TelnetGCodeReply(null) HttpGCodeReply(null) Telnet(null) HTTP(null) SD1(null) SD0(null) DirSearch(null) FileSystem(null) Aux(null) USB(null) MessageBox(null) ToolList(null) SPI(null) Malloc(null) NetworkGCodeInput(null) NetworkGCodeInput(null) FileInfoParser(null)
              Last reset 00:07:39 ago, cause: software
              Last software reset time unknown, reason: User, spinning module GCodes, available RAM 6256 bytes (slot 2)
              Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
              Error status: 0
              Free file entries: 10
              SD card longest block write time: 0.0ms
              MCU temperature: min 48.6, current 50.0, max 51.2
              Supply voltage: min 24.6, current 24.8, max 25.1, under voltage events: 0, over voltage events: 0
              Date/time: 2018-07-12 16:26:21
              Slowest loop: 253.50ms; fastest: 0.07ms
              Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
              Bed compensation in use: none
              Segments left: 0
              Movement lock held by null
              http is idle in state(s) 0
              telnet is idle in state(s) 0
              file is idle in state(s) 0
              serial is idle in state(s) 0
              aux is idle in state(s) 0
              daemon is idle in state(s) 0
              queue is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 316.15ms; fastest: 0.01ms
              HTTP sessions: 1 of 8
              • WiFi -
                Network state is running
                WiFi firmware version 1.21RC4(08b3)
                WiFi MAC address 60:01:94:73:55:68
                WiFi Vcc 3.20, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 15024
                WiFi IP address 192.168.1.58
                WiFi signal strength -60dBm, reconnections 0, sleep mode modem
                === Expansion ===
              1. M92
              M92
              Steps/: X: 160.000, Y: 160.000, Z: 160.000, E: 860.000:860.000:860.000:860.000:860.000:860.000:860.000:860.000:860.000
              *Note: Steps for mm in E, has to ve adjusted
              • peirofundefined
                peirof
                Can check, with a multimeter, if Duet shocket for steepers motors its sending voltage when Duet moves motors?
                For example...
                A- Multimeter in voltage mode
                B- Measure voltage beteewn PINs (i dont know beteewn what pins)
                C- Send with DWC G1 Z500 F100 (Z for 3 motors moves, and F100 slow=
                Can work?
                  Your outputs and M122 report all look OK, so I don't understand why it isn't working. Your WiFi firmware is a little old, but that won't affect the motors.
                  • Please answer my other question: what revision Duet is it? It's written on the top of the PCB, probably 1.03 if it is a recent purchase.
                  • After you send the G91 followed by the G1 S2 X10 command, are there any messages on the GCode Console tab of DWC?
                  • After you send those commands, does the stepper motor lock and become difficult to move by hand, or is it still easy to move by hand? (Only move the carriages slowly by hand).
                  • Please confirm that you have nothing connected to the Duet expansion connector.
                  • peirofundefined
                    peirof
                    Later try....
                    In New duet, duet 2,has changed the order of wires that join Duet with steppers motors?
                    • peirofundefined
                      peirof
                      This post is deleted!
                        Later try....
                        No, the wiring hasn't changed.
                        • peirofundefined
                          peirof
                          The answers:
                          • What revision Duet is it? It's written on the top of the PCB, probably 1.03 if it is a recent purchase.
                          Duet 2 v1.03
                          None
                          They move smooth
                          Confirmed, i have nothing connected
                            Are you able to measure the voltage between the ENN pin of the expansion connector and ground? It should be +3.3V with just USB power provided, and fall to 0V shortly after VIN power is applied.
                            There is another thread about a similar problem at https://forum.duet3d.com/topic/5956/webcontrol-usb-connecting-leds-light-up-but-motors-not-turning/8.
                            • peirofundefined
                              peirof
                              Measure voltage with USB connected. NO?
                              With steppers of, i have to read aprox 3.3V
                              With steppers moving, i have to read 0.0V
                              Correct?
                              Pins to check
                              link to Pins to check
                              • peirofundefined
                                peirof
                                Hi...
                                i have measure, and have 2.926V....
                                There is some system of check steppers drivers???
                                  Correct?
                                  Those are the correct pins to check. With USB power only supplied, you should get 3.3V between them. When you apply VIN power, it should drop to 0V.
                                  • peirofundefined
                                    peirof
                                    hi,
                                    i have do....
                                    1- With Usb only power..... V=1.72
                                    2- If i power on..... V=2.92
                                    3- If i power off.... Voltage drops slow until 1.72
                                      Those figures are not right. I think we need to exchange your Duet and examine it to see what is wrong.
                                      • peirofundefined
                                        peirof
                                        can you give me instructions?
                                          If you bought it from Duet3d then please complete the form at https://docs.google.com/forms/d/e/1FAIpQLSdyf6gGP_ncZachWi2HH7qx1kc5TE9WeEbz83VFBckm1JBXbQ/viewform. Otherwise, contact whoever you bought it from.
                                            Hi @peirof, I've just experienced a very similar fault on one of my bench test systems. So I suspect a firmware issue. I am investigating it now.
