    Whats wrong?
    2.2k
      Are you able to measure the voltage between the ENN pin of the expansion connector and ground? It should be +3.3V with just USB power provided, and fall to 0V shortly after VIN power is applied.
      There is another thread about a similar problem at https://forum.duet3d.com/topic/5956/webcontrol-usb-connecting-leds-light-up-but-motors-not-turning/8.
      • peirofundefined
        peirof
        Measure voltage with USB connected. NO?
        With steppers of, i have to read aprox 3.3V
        With steppers moving, i have to read 0.0V
        Correct?
        Pins to check
        link to Pins to check
        • peirofundefined
          peirof
          Hi...
          i have measure, and have 2.926V....
          There is some system of check steppers drivers???
            dc42 administrators @peirof
            @peirof said in Whats wrong?:
            Correct?
            Those are the correct pins to check. With USB power only supplied, you should get 3.3V between them. When you apply VIN power, it should drop to 0V.
            • peirofundefined
              peirof
              hi,
              i have do....
              1- With Usb only power..... V=1.72
              2- If i power on..... V=2.92
              3- If i power off.... Voltage drops slow until 1.72
                Those figures are not right. I think we need to exchange your Duet and examine it to see what is wrong.
                • peirofundefined
                  peirof
                  can you give me instructions?
                    If you bought it from Duet3d then please complete the form at https://docs.google.com/forms/d/e/1FAIpQLSdyf6gGP_ncZachWi2HH7qx1kc5TE9WeEbz83VFBckm1JBXbQ/viewform. Otherwise, contact whoever you bought it from.
                      Hi @peirof, I've just experienced a very similar fault on one of my bench test systems. So I suspect a firmware issue. I am investigating it now.
                        dc42 administrators @dc42
                        @dc42 said in Whats wrong?:
                        Hmm, I can't reproduce the problem since I reset the board. But i definitely had a similar issue: firmware thinking that everything was normal, but motors not turning.
