    Inconsistent delays during homing and other movements
    4.3k
    • synfinaticundefined
      synfinatic @synfinatic
      Oh, realized I should include the version info (M115):
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.0(RTOS) ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2018-06-05b3
      Also, I should mention that I've noticed sometimes various commands over the USB connection seem to have a delay. Ie: something like M115 might take a few seconds before it returns the firmware version.
        Phaedrux Moderator @synfinatic
        @synfinatic Can you post a copy of your config.g, and homeall.g files as you have them? I tried piecing it together from the github link you posted but it's a bit all over the place.
        Also, after it's behaved odly like that can you run an M122 to get a diagnostic dump and post that here as well.
          synfinatic
          0_1531615356465_center_xyz.g
          0_1531615163805_config.g
          0_1531615217517_homeall.g
          3_1531615425548_zhop_up.g
          2_1531615425546_probe_zm.g
          1_1531615425546_probe_y.g
          0_1531615425546_probe_x.g
          Here's the M122 after trying to home all axis (which took about 3min). Not sure if it normally takes a few seconds to spit out it's answer, but probably took at least 5sec for me.
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet Ethernet 1.02 or later + DueX5
          Board ID: 08DGM-95BLL-N6PSS-6JKD0-3S46K-9JSBL
          Used output buffers: 1 of 20 (8 max)
          Static ram: 28380
          Dynamic ram: 95596 of which 0 recycled
          Exception stack ram used: 508
          Never used ram: 6588
          Task NETWORK ready, free stack 324
          Task HEAT blocked, free stack 1256
          Task MAIN running, free stack 3656
          Last reset 00:11:21 ago, cause: power up
          Last software reset at 2018-07-14 13:14, reason: User, spinning module GCodes, available RAM 6244 bytes (slot 2)
          Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f000, BFAR 0xe000ed38, SP 0xffffffff
          Error status: 0
          Free file entries: 10
          SD card longest block write time: 0.0ms
          MCU temperature: min 31.9, current 43.3, max 43.5
          Supply voltage: min 0.0, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0
          Driver 0: standstill, SG min/max 0/205
          Driver 1: standstill, SG min/max 0/167
          Driver 2: standstill, SG min/max 0/0
          Driver 5: standstill, SG min/max 0/230
          Driver 6: standstill, SG min/max 0/221
          Driver 7: standstill, SG min/max 0/173
          Driver 8: standstill, SG min/max 0/177
          Expansion motor(s) stall indication: yes
          Date/time: 2018-07-14 17:47:34
          Slowest loop: 224.26ms; fastest: 3.03ms
          Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 236, MaxWait: 722287760ms, Underruns: 0, 2
          Scheduled moves: 19, completed moves: 19
          Bed compensation in use: none
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Stack records: 3 allocated, 0 in use
          Movement lock held by null
          http is idle in state(s) 0
          telnet is idle in state(s) 0
          file is idle in state(s) 0
          serial is ready with "M122" in state(s) 0
          aux is idle in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 228.12ms; fastest: 0.01ms
          HTTP sessions: 1 of 8
          Interface state: 5
          === Expansion ===
          DueX I2C errors 30269
          ok
            @synfinatic Just to chase things along, can you also post the macros that those homing macros call?
              synfinatic
              Here's a zip file (forums won't let me upload zip files) of the entire contents of my sd card: https://synfin.net/misc/duet-config.zip
                @synfinatic Thanks thats a lot easier.
                  Ok, so I pieced together everything that get called from Homeall.g
                  M906 Z600       ; set absolute motor drive current
                  ;; Set reduced physics parameters to help prevent missed steps.
                  M203 Z3000      ; maximum speed (mm/min)
                  M201 Z450       ; maximum acceleration (mm/min/s)
                  M566 Z0         ; instantaneous speed change (mm/min)
                  G91                             ; relative positioning
                  G0 Z10 F1800 S2                 ; unhomed move up
                  M913 Z100       ; restore motor current percentage to 100%
                  M906 Z1200      ; motor drive current
                  M203 Z9000      ; maximum speed (mm/min)
                  M201 Z900       ; maximum acceleration (mm/min/s)
                  M566 Z120       ; instantaneous speed change (mm/min)
                  M906 X1000 Y1000    ; set absolute motor drive current
                  M203 X4500 Y4500    ; maximum speed (mm/min)
                  M201 X900 Y900      ; maximum acceleration (mm/min/s)
                  M566 X180 Y180      ; instantaneous speed change (mm/min)
                  G1 X310 F6000 S1                ; +X probe move, fast. (*ADJUST* to 10mm larger than your X size)
                  M913 X100 Y100          ; restore motor current percentage to 100%
                  M906 X1200 Y1200        ; motor drive current
                  M203 X18000 Y18000      ; maximum speed (mm/min)
                  M201 X3600 Y3600        ; maximum acceleration (mm/min/s)
                  G1 X-5 F6000                    ; back off from the endstop
                  G1 X10 F120 S1                  ; +X probe move, slow
                  G1 X-1 F6000                    ; back off from the endstop
                  G1 Y310 F6000 S1                ; +Y probe move, fast (*ADJUST* to 10mm more than your Y size)
                  G1 Y-5 F6000                    ; back off from the endstop
                  G1 Y10 F120 S1                  ; +Y probe move, slow
                  G1 Y-1 F6000                    ; back off from the endstop
                  G90                             ; absolute positioning
                  G1 X304 Y303 F99999             ; move to directly above mechanical Z-switch
                  M558 P7 H5 R0.1 F1800 T99999 A1 B1
                  G31 P1000 X0 Y0 Z0
                  G30                             ; z-probe as configured
                  M558 P7 H5 R0.1 F120 T99999 A5 S0.01 B1
                  G31 P1000 X0 Y0 Z2.55
                  M558 P5 I1 H5 R0.1 F1800 T99999 A1 B1
                  G31 P1000 X0 Y25 Z0
                  G1 X150 Y150 Z150 F99999        ; move to a centerpoint
                  Gimme a minute to digest that.
                    synfinatic
                    I should mention it's not just homing. That's just the obvious example. Manual moves after a successful homing also tend to have random ~20sec delays before execution. The first few times it happened I thought it didn't register the click and I'd click the button again... so the commands would end up getting queued up and execute over time.
                      Other than calling a lot of nested macros I can't see anything obvious that should cause those delays.
                      You may want to try the latest firmware beta. https://forum.duet3d.com/topic/6070/new-firmware-2-01-beta-2-available
                        @synfinatic Are those clicks in the DWC or on the PanelDue? What version of DWC are you running? Try the new firmware beta 2 along with the DWC beta 2 from the same download link.
                          synfinatic
                          I have been testing via the webUI. I've upgraded the firmware and webcontrol files to the latest beta. Started the full homing (via web) and X & Y seemed to work fine. But it never dropped the gantry to home Z and then gave up. The console has the error:
                          Error: Z probe was not triggered during probing move
                          Which is accurate.
                          Rebooted the whole printer and started homing via the PanelDue. That worked perfectly. Moved it around in X, Y, Z, no problems. Re-homed a few more times (still using the PanelDue) and it worked great.
                          So then started using the WebUI again. Did a full home- worked fine. Tried moving in X and it moved in X and Y. Went back to the PanelDue and verified that DOES NOT happen when moving via the PanelDue. Did more moves via the webUI and seems like any X or Y moves diagonally in both X and Y. If I didn't know better I'd say my CoreXY printer was setup wrong, but this is only happening via the webui.
                          Update: I should mention that it doesn't move in X and Y when homing X or Y. It only does that during moves post-homing.
                            Can you confirm you are using this version of the DWC?
                            https://github.com/dc42/RepRapFirmware/releases/download/2.01beta2/DuetWebControl-1.21.2-b2.zip
                              synfinatic
                              Yeah, I uploaded the b2 DWC zip file via the UI after upgrading the firmware.
                              So I downgraded back to the release version and moving via the web (after homing via paneldue) only moves in a single axis at a time, but there's about a 5sec delay before executing the move. No delay with the paneldue.
                              I also tried re-homing via DWC, and it's slooooowwwwww again.
                                Hopefully from the information we've gathered someone will have a better idea of what might be going on.
                                BTW, have you printed anything yet? Does it execute a print properly?
                                synfinaticundefined 1 Reply Last reply Reply Quote 0
                                  synfinatic
                                  Back to beta2 firmware and DWC.
                                  Behaving the same as I described before with this version. The only additional info I can provide is I notice when doing a moves, they're not just running at angles, but reversed on the selected axis. Basically -100 Y causes the head to move +50Y and -50X. Same pattern for X moves. The head position values in the upper right corner of the DWC update correctly based on the physical movement of the head.
                                    If you manually go through the movement testing section for coreXY do you get the movements you expect?
                                    https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Movement_section
                                      synfinatic @Phaedrux
                                      @phaedrux Nope. Just finished wiring and slowly bringing the printer to life. Was acting so wonky I haven't even gotten to the gantry leveling step or even tried the extruder.
                                      Honestly, until upgrading to beta2 I was pretty much convinced my board was bad and I needed to RMA it with Filastruder. But b2 seems like an improvement (at least it seems more consistent) so not sure anymore
                                        @phaedrux It was fine under 2.0 and is fine under 2.01.beta2 via the PanelDue. Only has issues under 2.01beta2 via the DWC.
                                        BTW, thanks for the help. Feel like we made some progress. Hopefully someone else can provide some ideas.
                                          Have you been able to get any feedback from the creators of the config set?
                                            synfinatic
                                            I've been talking to a few other people with the same printer using the same config. Nobody has seen anything like this. They were thinking I had a bad board.
                                            Ran M122 again, just for comparison:
                                            M122
                                            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01beta2(RTOS) running on Duet Ethernet 1.02 or later + DueX5
                                            Used output buffers: 1 of 20 (12 max)
                                            Static ram: 28484
                                            Dynamic ram: 95808 of which 0 recycled
                                            Never used ram: 6272
                                            Tasks: NETWORK(ready,400) HEAT(blocked,1248) MAIN(running,3648)
                                            Owned mutexes:
                                            Last reset 00:31:18 ago, cause: power up
                                            Last software reset at 2018-07-14 19:28, reason: User, spinning module GCodes, available RAM 6272 bytes (slot 3)
                                            Error status: 0
                                            MCU temperature: min 39.1, current 43.4, max 44.0
                                            Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0
                                            Driver 0: standstill, SG min/max 0/204
                                            Driver 1: standstill, SG min/max 0/1011
                                            Driver 5: standstill, SG min/max 0/250
                                            Driver 6: standstill, SG min/max 0/258
                                            Driver 7: standstill, SG min/max 0/206
                                            Driver 8: standstill, SG min/max 0/253
                                            Date/time: 2018-07-14 20:33:41
                                            Slowest loop: 197.57ms; fastest: 2.97ms
                                            Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 236, MaxWait: 828444ms, Underruns: 0, 0
                                            Scheduled moves: 70, completed moves: 70
                                            Segments left: 0
                                            serial is idle in state(s) 0
                                            aux is ready with "M408 S0 R1" in state(s) 0
                                            === Network ===
                                            Slowest loop: 169.65ms; fastest: 0.02ms
                                            Interface state: 5
                                            === Expansion ===
                                            DueX I2C errors 6830
