    40mm cooling fan duct for Smart Effector - thoughts?
    Smart effector for delta printers
    11
    39
    6.8k
    • RGN01undefined
      RGN01
      I've uploaded an improved version for the BerdAir type cooling. It only needs support on the bed - I've included sacrificial support for the rest of it.
      Mine prints perfectly in PETG with only minimal support plastic to remove.
      Richard
      Hergonowayundefined 1 Reply Last reply Reply Quote 0
      • benkayundefined
        benkay
        Looks great. With the new easy-print version for berd-air….is this file universal for standard v6 and volcano?
        Tevo Little monster with Duet Wifi and Smart Effector / magball arms upgrades.
        Original Prusa i3 Mk3
        • benkayundefined
          benkay
          • RGN01undefined
            RGN01
            Yes, I use the same for both.
            Richard
            • Hergonowayundefined
              Hergonoway @RGN01
              @rgn01
              Hi love your design, could you share the stp/step files ? at least for the "Duct_-_no_accessories_v1.00" part ?
              I'm struggling right now in Fusion 360 with the stl, there more than 45k meshes
              Delta goes BrrrRRRRrrrrrRRRRrrr
              RGN01undefined 1 Reply Last reply Reply Quote 0
              • RGN01undefined
                RGN01 @Hergonoway
                @hergonoway Unfortunately the CAD package I use does not support STP files so I can't do that.
                Richard
                • BenDieselundefined
                  BenDiesel
                  That fan I a cool idea. I used this one for a 40mm noctua on mine
                  https://www.thingiverse.com/thing:2844881
                    Hergonoway @RGN01
                    @rgn01 I was sad at first because working with this amount of mesh kill my Fusion360... and working from mesh is really not my cup of tea... but your idea of using a 40mm fan made its way into my mind 🙂 I've ended up designing my version from scratch in order to handle 3mm holes for fan with hexa nut lock and working as a shield with berdair support (for original tube size but also 1/8" tube size), so thank you !!
                    Chipsa82undefined RGN01undefined 2 Replies Last reply Reply Quote 0
                    • Chipsa82undefined
                      Chipsa82 @Hergonoway
                      @hergonoway that is pretty much the ultimate mount for the effector ;)) would you mind sharing the model? thanks!
                      • Chipsa82undefined
                        Chipsa82 @RGN01
                        @rgn01 Cool! is that a 40/20 blower fan?
                        • RGN01undefined
                          RGN01 @Hergonoway
                          @hergonoway that looks very good. Sorry I couldn't help directly and save you the trouble of redesigning it!
                          • RGN01undefined
                            RGN01 @Chipsa82
                            @chipsa82 on the early photos with a blower, yes. The Noctua on the later version is a 40 x 10. I have shared my version on Thingiverse https://www.thingiverse.com/thing:2844881
                              Hergonoway @Chipsa82
                              @chipsa82 I'll post it on thingiverse in few days, need to rework some clearance for that damn screw under the fan duct 🙂
                              First prototype print works like a charm
                                Hergonoway @RGN01
                                @rgn01 did you encountered some issue with a noctua? In terms of CFM I mean.
                                I was a bit concerned to the amount of air during first prints. Didn't try ABS or more exotic high temp materials.
                                I swapped recently to adda fan (because 24v) (réf AD0424HB-G7, but ad0424hs-g70 works almost the same) works really well if you managed to find one under 10$.
                                • RGN01undefined
                                  RGN01 @Hergonoway
                                  @hergonoway No, I've used the same 40x10 Noctua on my other printer with a e3d Chimera printing two colour with ABS and it works just fine.
                                  • Mystaundefined
                                    Mysta
                                    @Hergonoway I wasn't able to find your file on thingiverse, mind linking it?
