    effector tilting into bed on print
    22.0k
    • TimVukmanundefined
      TimVukman
      I started G32 from the duet display. (pushed on the keyboard picture, entered G32 and return) The machine goes through the process. At the end, the process stopped centered on the bed.
      There was no text displayed in the little screen.
      While running, the effector does not dive far enough to click the Effecter switch at every position. It clicks on most, but certainly not all.
      I have cleared the log file in the browser
      "1:01:18 PMG32
      12:57:55 PMG32
      12:57:47 PMMessage Log cleared!"
      That's all I see.
        TimVukman
        Software Information
        Firmware Version: 2.0(RTOS)RC6 (2018-05-29b4)
        WiFi Server Version: 1.21
        Web Interface Version: 1.21
        Web Interface by Christian Hammacher
        Licensed under the terms of the GPL v3
          TimVukman
          I should have added above that I cleared the log before I ran G32 from the browser window.
          Nothing shows. That's the version of the log that is displayed
            @timvukman said in effector tilting into bed on print:
            G30 P6 X0 Y0 H0 Z-99999 S6 ;Center
            If it is probing all the points including the centre one at the end, then it looks like it isn't processing the S6 part of the final G30 command. So I suggest you try deleting and re-typing that line in case it contains a non-printing character. You could also try changing S6 to something non-sensical such as S20, which should provoke an error message
              TimVukman
              Hi
              10:53:22 AMG32
              10:50:12 AMMessage Log cleared!
              This is the result of clearing the log and running G32. Please note that the value in Bed.g for S in the last G30 is S30.
              I have retyped the line
                TimVukman
                I deleted Bed.g. That was noticed! G32 would not run since the Macro was deemed missing
                • Danalundefined
                  Danal
                  Try generating a completely new bed.g here:
                  http://www.escher3d.com/pages/wizards/wizardbed.php
                    TimVukman
                    I would appreciate so clarification on the G31 in Config.g
                    Here is mine
                    G31 P500 X11 Y0 Z-1.209
                    I am clear on Z-1.209 as that is my actual trigger height at center
                    I am clear on the P500 as that is the value of the Z probe for a mechanical switch
                    I'm not so clear on the X and Y values. In reading the documentation here,
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_G30_Single_Z_Probe
                    for the G31 code,
                    "Xnnn Probe X offset(note)1
                    Ynnn Probe Y offset(note)1
                    Notes
                    (note)1X and Y offsets of the Z probe relative to the print head (i.e. the position when the empty tool is selected) can be specified. This allows you to calculate your probe coordinates based on the geometry of the bed, without having to correct them for Z probe X and Y offset."
                    I do not see how this functions. My understanding is that these values should identify the location of the actual switch relative to the nozzle since in my case, the nozzle contacts the bed to trip the switch.
                    In my G31 above, is it not saying that my nozzle is 11mm closer to the X pillar than my switch is? This would make the switch think it is measuring a value for X0, Z0 when the nozzle is physically at X0, Y0. I'm going to have to measure the 11mm. I don't think it is correct and I don't know where it came from. I might be a number from the manufacturer.
                    • Danalundefined
                      Danal @TimVukman
                      Yes. Conceptually correct.
                      Imagine a printer where the Z-Probe just triggered, and that the particular nozzle and Z-probe on our imaginary printer are mounted such that the probe triggers when the bed is 8.492mm below the nozzle, and the probe is mounted so that the probe's "sensor center" is 10mm in the plus X direction from the nozzle, and 5mm in the minus Y direction.
                      That would result in:
                      G31 X10 Y-5 Z-8.492
                      If, in your case, the nozzle IS the probe, the G31 will probably look something like this:
                      G31 X0 Y0 Z-0.1
                      Zero for X and Y, because the nozzle is the probe. Z- because the nozzle has to move a tiny bit "up" to sense, thus making it as though "the sensor is mounted a fraction above the nozzle". -0.1 is a starting guess. It may be -0.05 or -0.15 or ...
                        TimVukman
                        Thanks Danal
                        Here is the new beg.g file
                        ; bed.g file for RepRapFirmware, generated by Escher3D calculator
                        ; 10 points, 6 factors, probing radius: 10, probe offset (0, 0)
                        G30 P0 X0.00 Y10.00 Z-99999 H0
                        G30 P1 X8.66 Y5.00 Z-99999 H0
                        G30 P2 X8.66 Y-5.00 Z-99999 H0
                        G30 P3 X0.00 Y-10.00 Z-99999 H0
                        G30 P4 X-8.66 Y-5.00 Z-99999 H0
                        G30 P5 X-8.66 Y5.00 Z-99999 H0
                        G30 P6 X0.00 Y5.00 Z-99999 H0
                        G30 P7 X4.33 Y-2.50 Z-99999 H0
                        G30 P8 X-4.33 Y-2.50 Z-99999 H0
                        G30 P9 X0 Y0 Z-99999 S6
                        My bed is 220mm. I used 100mm as the radius in the formula
                        I get no messages, and nothing is recorded in the g-code console.
                        I watched it very carefully as something caught my eye while doing this so many times.
                        The effector goes off to a spot between my X and Z columns and lowers, but not enough to trip the Z switch, and then it moves left to just past the Z column and dips down again without triggering. It then centers and triggers.
                        I think it is doing the same thing 10 times and then stops.
                        Do you think maybe I've got a couple of axis motors mixed up?
                        I will check, but that is going to make me feel terrible if this has been for a dumb mistake.
                        If that's the case, it would still home properly, right? and I could still set my trigger height?
                        I'll update soon
                        Tim
                          TimVukman
                          my columns are
                           Z
                          Y X
                          Is this correct?
                            TimVukman
                            Ok, The correct wires from the board go to the correct motors.
                            Whew!!
                              dc42 administrators @TimVukman
                              If you have deployprobe.g and retractprobe.g files in /sys that you didn't create yourself, delete them.
                              • Danalundefined
                                Danal
                                Looking at the printer, Z tower (motor, endstop) in the back, X to your left, Y to your right.
                                Then check movement. Make all moves with web control, if any validation step fails, stop and report back:
                                1. Home All (or G28) Validation: Proper home move.
                                2. Move Z downward, so web commands will be "negative" buttons. Move -50. Validation: Effector moves down, and stays centered between towers.
                                3. Move Y +100. Validation: Effector should move STRAIGHT TOWARD Z TOWER; and effector does not change height above bed at all. Yes, confusingly enough, Y+ is straight toward Z tower. 🙂
                                4. Move Y -100. Validation: Effector moves back to center, does not change height above bed.
                                5. Move X +100. Validation: Effector moves to a position NOT aligned with ANY tower... it will be between the Z and Y towers, about 2/3 toward the Y tower. (Of course, it is 90 degrees from the Y axis we found in step(3)... and 90 degrees is about 2/3 off from the 120 degree spacing of the towers). Height above bed should not change.
                                That validates every kind of move.
                                  TimVukman
                                  Confirmed to have worked properly and registered in the system (web buttons Home X, Home Y, and Home Z turned blue. X is 0. Y is 0. Z is 198
                                  Confirmed that effector moved down 5 shots of 10 and is still centered. X is 0. Y is 0. X is Z is 148
                                  Effector has moved to sit directly in front of the Z column. Height is 148. X is 0, Y is 80. Diagonal rods are almost, but not quite vertical.
                                  Effector has moved back to about center. Height is 148 X is 0, Y is -15
                                  It looks about right. X is 84.1 Y is -12.6 Z is 148
                                  I took the top apart before I did what was above, because I had a small gap on one rail.
                                  I had my motors / columns as described above which mean that I needed to swap X with Y to match the positions as you described them. I swapped the end stops as well.
                                  One significant observation came when I removed the bed to trace the wires. On the left side, the bracket that clips on the rail and holds the female nut for the bed was not sitting down flat on the rail. It look like one end bent into the side of the rail. There was a definite fold line in the clip. I straightened that and put the clip back in place. It is now sitting flat. I believe that to be cause of the problem, IE the be was 1/8" higher there.
                                  I ran Auto Delta Configuration from the browser interface. The start is not registered in the G-Code Console. There are no messages indicating pass, fail, or error in the G-Code Console.
                                  There have been no changes in Config-Override.g.
                                  I noticed that in my bed.g file, I had entered the radius as 10 instead of 100.
                                  Fixed, created a new bed.g file.
                                  The Auto Configuration certainly changed where it was probing and now appears appropriately spread out.
                                  The was no on screen message during or after running Auto Configuration. There are no new messages in the G-Code Console. There are no changes or additions to the H values in the Bed.G file. There are no changes in Config-Override.g,
                                    Did you see my earlier reply?
                                      TimVukman
                                      Hi dc42
                                      Yes, I read it, but I did not delete the files as I forgot about it in swapping everything else around. I have now deleted the files and am pleased to report that I got a message on the screen and in G-Code console at the end of the AutoConfig.
                                      "G32
                                      Calibrated 6 factors using 10 points, deviation before 2.988 after 0.107"
                                      M665 reported different settings than those that I entered in my Config.g.
                                      **M665
                                      Diagonal 360.200, delta radius 124.727, homed height 204.383, bed radius 85.0, X -0.501°, Y -4.385°, Z 0.000°**
                                      **× M666
                                      Endstop adjustments X2.88 Y1.39 Z-4.27, tilt X0.00% Y0.00%**
                                        TimVukman
                                        Ok
                                        I ran Auto Configuration again, and I should not have done that.
                                        My effector left the area defined by the bed. I killed it with emergency stop after one of the magnetic rods popped off the carriage. I don't think M500 was a good idea.
                                        I have my original values for Config.g G31 written down.
                                        Please advise as to how I should proceed. I will leave it alone until I hear back.
                                          Your Y tower angle offset of more than 4 degrees sounds suspicious. If the 3 sides of your base and upper triangles are all of equal lengths, it should be much smaller than that.
                                          Your endstop adjustments are also rather large, assuming you attempted to get all 3 endstop switches at more of less the same height (getting them equal to within 1mm isn't normally difficult).
                                          What type of Z probe are you using?
                                            TimVukman
                                            When you mention y tower offset, are you referring to the -4.385 that was returned in M665?
                                            This was an FLSun kit, so my verticals are all the same length(3) as are each of the cross members(9)
                                            As I recall, the end stops were not too hard to adjust. Maybe I should redo them after all the moving I have been doing?
