Emergency Stop! Please wait while firmware is restarting
Just as a data point, I have two Delta printers on:
Firmware Name: RepRapFirmware for Duet 2 WiFi/Ethernet Firmware Electronics: Duet WiFi 1.02 or later Firmware Version: 2.0(RTOS) (2018-06-05b3) WiFi Server Version: 1.21 Web Interface Version: 1.21.2-b2 Emergency Stop works correctly from the Web interface (had to use it earlier today), and I have not seen an print failures (of any kind) across about six or eight prints, longest being about 10 hours.
Thank you for the reply.
Yes, I imagine that the problem is specific to me and is caused by some error in my part.
To clarify, the emergency stop works perfectly when I select it from Duet Web Control.
The problem is that the Emergency Stop is somehow being automatically activated (or initiated) in the middle of a print.In the middle of a print the machine stops and displays "Emergency Stop! Please wait while firmware is restarting". At that point the machine resets itself and the current print is abandoned.
I was hoping that there was a way to isolate the cause using the information available in the Duet Web Control. Or at least determine if the problem is being caused by hardware, software or my gcode.
That would be pretty darn frustrating.
Just for debugging: Next long print, maybe disconnect all the web clients?
If the printer restarts automatically after the emergency stop and you are able to send commands without you needing to do reset the board explicitly, then the firmware has executed M112 followed by M999. That can normally only happen if the Emergency Stop button in DWC is clicked, or the Emergency Stop button in PanelDue is pressed. Both of those actions will send both commands.
If DWC reports "The firmware still reports to be halted after an emergency stop. Would you like to reset your board now?" when you try to send a command from DWC after the Emergency Stop has occurred, then the firmware has executed just M112, or you have a M580 trigger set up to do an emergency stop when the state of an endstop input changes.
HTH David
Thanks for the reply and for the help.
You helped me to isolate the problem.
I believe the problem originated with the cabling I used for the PanelDue. I used 22 Gage, 4 conductor, stranded copper wire to connect the PanelDue to the Duet. With this wire the PanelDue was always a bit "buggie" and never really worked consistently. I don't know if it was the cable itself or a combination of the cable type and length.
I unplugged the PanelDue and retried the previous print and it worked perfectly.
So, I assume that the PanelDue was initiating an Emergency restart due to the cabling.Thanks for the help.
Can anyone recommend a cable that can adequately carry the signal from the Duet to the PanelDue roughly 40 inches?
I use a Cat5 patch cable. Gives you 4 extra wires for lights or an on/off switch.
Plus the shielding is a plus.
I would tend to think a noise or ground loop problem would cause the device to lock up rather than cause it to send unintended commands over serial. That is unless there is an analog input somewhere for E stop that is getting affected. Not sure what the max spec is but 40" doesn't seem particularly long.
The cable type isn't critical provided that the resistance per conductor is no higher than 0.1 ohms. Unshielded 4-core cable works well.
If you have a M575 P1 command in config.g, make sure it includes the S1 parameter so that the firmware ignores commands from the PanelDue port that have invalid checksums.
DC42,
I have another question that is not related to this exact topic.
I have built a large Kossel based on the instructions you posted in your blog.
Can you tell me what retraction settings you use for PLA?
I am using Simplify3D and have been tweaking these settings but haven't achieved the results I am after.Below are the settings I am currently using:
- Retraction Distance: 3.00mm
- Extra Restart Distance: 0.00
- Retraction Vertical Lift: 6.00
- Retraction Speed: 25.0
- Temp.: 205°C
- Speed: 50mm/s -
I use 6mm retraction (was 7mm before I changed the Bowden tube to Capricorn), no extra restart distance, 0.3mm vertical lift, 60mm/sec retraction speed. Also pressure advance 0.2sec in M572.
