    effector tilting into bed on print
    22.0k
    • TimVukmanundefined
      TimVukman
      In looking at the video, I can absolutely state that the effector does not stay level as it moves from point to point. The base of the effector tilts through every movement. Is it possible that 360.21mm magnetic arms are too long to be used?
      Dougal1957undefined adavidmundefined 2 Replies Last reply Reply Quote 0
      • Dougal1957undefined
        Dougal1957 @TimVukman
        @timvukman can you put the Video in a cloud location so we can see it alternatively can you photograph the effector and carriages and paste that here?
        • adavidmundefined
          adavidm @TimVukman
          @timvukman the length itself is not a factor. The spacing of the rods (pairs must be parallel) and the difference in length of a given pair(lengths must be identical) are critical in avoiding effector tilt.
          I agree with the other poster, your next step should be to get the video and clear photos of the effector, carriages and arms uploaded. YouTube is pretty straightforward to upload to, but there are dozens of similar services.
            TimVukman
            Ok:
            I have a video uploading to YouTube. It is of the effector while it is executing a G32
            Hmmm if this worked, then my video is at https://youtu.be/xvyjY2aBhl8.
            Facinating
              TimVukman
              So, now that I have found out how easy it is to post videos on you tube, I will gladly entertain specific requests 🙂 for whatever may be helpful to isolate the issues.
              (personal vote goes toward operator malfunction. RTFM has already proved too hard to handle.)
                @timvukman can you post a pic that shows both the effector and the carriages it looks like the spacing of the rods maybe different at both the effector and carriage ends and that does produce that tilt effect
                  TimVukman
                  I can promise you that the rods are the same distance apart at the carriage end as they are at the effector end. That distance is 2 1/4 inches and it is the same at the top and bottom of each pair of rods.
                    @timvukman in that case can you state your Pulley sizes (No of teeth) and post your Config.g
                      Looking at that video, I can see that the effector is tilting a lot. Also, at the first probe point the fan duct fouls the bed (because of the tilt) before the nozzle can contact it.
                      My first thought was that the spacing of the ball centres was not the same at the top and bottom of the pairs of rods. But if you are certain that it is the same, then I can think of another explanation. You have mounted the ball studs on the sides of the effector, not on the top as is usual. This may mean that the range of movement of the joints is insufficient. Those ball joints can go to nearly 90 degrees away from the aligned position, but I think more than 90 degrees is required if the studs on the effector are mounted horizontally. I suspect that the Delrin rod ends are fouling on the neck of the ball studs at some positions.
                        Dougal1957
                        Good Catch David I never thought of that but it is more than Logical
                          TimVukman
                          I never considered the mounting of the balls. It certainly makes sense that it could be the problem. I had arrived at the conclusion that the rods must be the issue based on this machine printing very nicely before a couple of rods separated from their fish eye screw sockets.
                          I have no other option but a horizontal mount for the balls on the effector. To that end, I refurbished all of the rods / sockets and they are now secured with heat shrink tubing. I have replaced the magnetic rods with the originals and I am now working my way through the setup to reset the machine as a new install.
                          My latest tracking shows the Duet effector arriving on July 31. Until then, I will see what happens with the old rods. That should get us an environment that will confirm your suspicions.
                          Thanks so much for staying with me on this.
                            TimVukman
                            I am content with the initial settings. The printer will cycle between home and z=0 realiably.
                            I have determined and saved the trigger height at 0.528. That does change a little on occasion, 0.515 seems to be the other number that pops up.
                            M500 has been issued.
                            I believe I am ready to run G32. Agreed?
                              TimVukman
                              G32 results
                              G32
                              Calibrated 6 factors using 10 points, deviation before 1.141 after 1.055
                              12:02:09
                              PMG32
                              Calibrated 6 factors using 10 points, deviation before 3.913 after 0.461
                              Feedback? Possibility of printing?
                              I can watch the effector through the process and it is gliding like a flying saucer - base is flat.
                                You still have a large calibration deviation. What probing radius are you using? You could try reducing it until you get good calibration results, and then restrict your prints to that radius until you can sport out the effector.
                                • Danalundefined
                                  Danal @TimVukman
                                  @timvukman said in effector tilting into bed on print:
                                  Just my "eyeball" from the vid, so take with a grain of salt: The rods look WAY too long for the other dimensions of the printer.
                                  Curious, what are the rods (ball center to ball center), what are the horizontal extrusions (not counting the corners) and what are the vertical extrusions (again, not counting corners)?
                                  And, if you know, what "brand" of corners?
                                    TimVukman
                                    This is looking much better. I took 10 out of the radius for now.
                                    6:24:31 PMG32
                                    Calibrated 6 factors using 10 points, deviation before 0.945 after 0.943
                                    6:22:57 PMG32
                                    Calibrated 6 factors using 10 points, deviation before 0.954 after 0.949
                                    Look better?
                                      dc42 administrators @TimVukman
                                      6:24:31 PMG32
                                      6:22:57 PMG32
                                      Look better?
                                      The deviation is consistent now (i.e. the "before" deviation reported by G32 is close to the predicted "after" deviation of the previous G32). However the absolute deviation is still very high, which will make printing difficult.
                                        TimVukman
                                        Not sure what else can be done unless I further reduce the radius. Not a big deal. I'm ok with printing small things. That's what I am trying to get done at the moment. Just a toothpaste squeezer for my step daughter.
                                        This whole conversation does make me wonder or at least think I need to do something else going forward.
                                        Once I get the new duet effector, I can of course mount the balls vertically for the magnetic rods. Is that combination likely to deliver an acceptable level of quality.
                                        I have been giving serious consideration to replacing the plastic pieces that came with this printer with aluminum or some kind of metal. I would think metal parts would square up much better with the verticals that really are about the only metal that was in the kit. I have a feeling you would agree. Should I also expand the size of the verticals. Right now they are 20 x 20. I have seen the metal frame parts available with 20 x 40 openings for the verticals. Is that a worthwhile investment?
                                        Thanks
                                        Tim
                                          TimVukman
                                          Took another 10mm out of the radius
                                          7:10:42 PMG32
                                          Calibrated 6 factors using 10 points, deviation before 0.911 after 0.910
                                          7:08:56 PMG32
                                          Calibrated 6 factors using 10 points, deviation before 0.924 after 0.919
                                            Something is very wrong if you can't get below 0.9mm deviation. If you run mesh bed levelling, with the same radius set as you are using for auto calibration, what does the height map look like?
                                            What belts are you using?
                                            Did you remember to change the L parameter in M665 to the length of the rods you are now using?
