    Help with BLTouch
    2.3k
      dc42 administrators @BPisLife
      @bpislife said in Help with BLTouch:
      @mike-mcg I think it is as easy as changing the motor direction "M569 P2 S0 to M569 P2 S1" and since you have two motors for z, M569 P4 S0 to M569 P4 S1.
      Try that and let me know.
      @Mike-McG, just to be clear: if it is the bed that moves in the Z direction (not the nozzle), then +Z should move the bed down and -Z should move the bed up. This is because the Z coordinate is the distance between the nozzle and the bed.
      Mike McGundefined 1 Reply Last reply Reply Quote 0
      • Mike McGundefined
        Mike McG @dc42
        @dc42 thanks I figured that out the motor Direction was wrong but the BL touch is not deploying when the G30 command is issued does the G30 command automatically call to the deployprobe.g file?
          dc42 administrators @Mike McG
          @mike-mcg said in Help with BLTouch:
          Yes (unless you are using very old firmware), unless you have previously sent M401 to deploy the probe yourself and not used M402 to retract it.
          • Mike McGundefined
            Mike McG
            I'm using 2.01 but it's still not deploying or retracting at G30 command
              Try sending M401 and M402 from the command line. If they don't deploy and retract the probe, check the wiring, the config.g file, and the deployprobe.g and retractprobe.g files.
              • Qdeathstarundefined
                Qdeathstar
                Did you cut the trace to make it 3.3v and not 5v? Also, is the bl-touch blinking red or steady red or off?
                Mike McGundefined 1 Reply Last reply Reply Quote 1
                • pro3dundefined
                  pro3d
                  Sorry if i missed it and I am late to this but did you post the deploy.g and retract.g? Did you do self test M280 Px S120? and M280 Px S160?
                  Valkyrie DIY High Temp 3D Printer
                  R&D - Engineering Designer - Viking 3D Printers
                  https://vkingprinter.com/
                  • Mike McGundefined
                    Mike McG
                    Well after very close examination of the trace on the back of the BL touch the trace was almost cut through but not enough it works thank you very much for all your help
                    • Mike McGundefined
                      Mike McG @Qdeathstar
                      @qdeathstar it was the 3. 3 volt logic Trace and now everything seems to be fine go figure something as small as a little Trace thanks for your help
                        I'm surprised that it didn't work without the trace cut.
                        • Mike McGundefined
                          Mike McG
                          I was thinking this morning I had to unplug The BLTouch To get toThe logic trace I don't think it was the trace Although the trace wasn't fully cut I think it was plugging it back in Afterwards Sounds more logical
                          The probe deploys And retracts When I do a homeall or homez But I can't get G 29 Were mesh Bed leveling To work Says something aboutIt must be home first Even if it has already ZYX all Show 0 I know that I'm missing something right?
                          Any ideas On today's Problem lol Thanks guys I really mean it I'am new to this board and the firmware So I'm in the learning curve
                          Thanks again
                            What do your homing files look like now?
