    inconsistent behavior - duet wifi on latest beta
    2.3k
      I would suggest doing a full backup and format of the SD card just to make sure it's working properly.
      The SD card association has a formatter that will format it properly for the card type.
      https://www.sdcard.org/downloads/formatter_4/
      Do you have a spare card you can test?
      • Mentaluproarundefined
        Mentaluproar
        Before I transferred the board I did wipe the card with the SD formatter tool and completely redid it. It used to erase itself on my old machine too but once I got the config where I liked it and left it alone, it stopped happening, so I thought it was a firmware bug.
          Can you grab a M122 diagnostic the next time it happens? Might shed some light.
          • Danalundefined
            Danal @Mentaluproar
            @mentaluproar said in inconsistent behavior - duet wifi on latest beta:
            After you rebuilt the card and put it in a Duet... did you issue the M commands to update firmware in both the Duet and the WiFi module? Or equivalent?
            Shot in the dark here... but I'm wondering if there is somehow an incompatibility between what is running in flash on the controllers vs. something on the card. Maybe.
              Mentaluproar
              No. I thought the firmware did little more than load what was in the card to memory. What are those M codes?
              • Danalundefined
                Danal
                M997 S0:1U date firmware modules 0 and 1. This should be what you want for a Duet Wifi
                S0 - main firmware
                • Older releases filename was sys/RepRapFirmware.bin (Duet) or sys/DuetWiFiFirmware (Duet WiFi).
                • Latest releases, filename is /sys/Duet2CombinedFirmware.bin
                • File sys/iap.bin (Duet) or sys/iap4e.bin (Duet WiFi) must also be present.
                1 - web server firmware
                • Filename sys/DuetWiFiServer.bin (Duet WiFi only)
                Latest released binary files Here: https://github.com/dc42/RepRapFirmware/releases I do recommend the very latest releases, I'm running them on a couple of different Detlas, no issues.
                AFTER you do those upgrades, you may also want to refresh DWC (Duet Web Control), just to be sure. Upload the whole zip file (don't unzip) through the Settings>General>Upload web stuff. https://github.com/chrishamm/DuetWebControl/releases
                  Mentaluproar
                  @danal said in inconsistent behavior - duet wifi on latest beta:
                  M997 S0:1
                  Error: M997: File DuetWiFiServer.bin not found
                  interesting....
                    Mentaluproar
                    reinstalled firmware. probing still crashes into tower. config.g has not disappeared yet so far.
                      Sometimes, the delta homing flys off the plate and into a pillar, sometimes it probes normally
                      I assume you mean probing, not homing. If you have old deployprobe.g and retractprobe.g files in /sys on the SD card, delete them.
                        Mentaluproar
                        no probing files. I must have configured something wrong. delta tries to probe larger than the bed.
                          Mentaluproar
                          I'm dumb. I made a typo in the M665 line.
                            Mentaluproar
                            config.g disappeared again. Twice. I can undelete it every time without a problem. Given how FAT32 works, I'm thinking something in the firmware is telling it to delete the file.
                              dc42 administrators @Mentaluproar
                              Which firmware and DWC versions are you using?
                              I don't think the current firmware and DWC versions ever delete config.g. When you edit it in DWC and save it, I think it first deletes config.bak if it exists, then renames config.g to config.bak, then uploads the new config.g. Or chrishamm may have implemented it another way, such as uploading to config.new first and then doing a double rename. Either way, if the process fails you should still have the old config.g renamed to config.bak.
                                Mentaluproar
                                config.bak is generally there. I think it has vanished before too but I can't remember.
                                • kungfueinsteinundefined
                                  kungfueinstein
                                  its just disappeared for me too. this is not the first time. Also having problems opening the DMS file to restore the bak.
                                    dc42 administrators @kungfueinstein
                                    @kungfueinstein said in inconsistent behavior - duet wifi on latest beta:
                                    When it disappeared, were you editing it and trying to save it? Or was it after you uploaded a new file to /gcodes?
                                    How many files do you have in the /sys folder? There is a limit to how many files in a folder the firmware can return to DWC. Although this normally affects only the /gcodes folder, it could affect /sys if you have a lot of files in it.
                                      Mentaluproar
                                      I've only had the files necessary for operation in the sys folder. I only ever notice config.g isn't there when I go to edit it. Sometimes I'll realize I forgot to do something after it goes to reboot the board, so I'll wait, then go back to system editor and see the file is gone.
                                      I don't know if this is relevant, but if I reload the page (like if it's on a tab and my mac has to reload the tab because I was doing lots of other things) the board will repeat the last few instructions sent to it. Even if it is printing, it will interrupt the print to home and calibrate. This happens every time on safari, and a little less frequently on firefox.
                                      Basically, once it's all dialed in, the board works great, but interacting with it in any way leads to unpredictable results. Still nowhere near as bad as octoprint though.
