Question on Z-Offset and Start Script, Also Nozzle Adjustment.
Yes I have calibrated it where it extrudes exactly 100mm of filament when that is what I select to extrude. Verified with measurements.
I will run another print for awhile this evening and post back a picture as I really need to get this sorted and I'm a bit lost on where to go from here.
I don't believe it is over extrusion though as it looks great up until that point.
What type of printer is it?
Can you also post your config.g?
Are you using anything like variable layer height in Cura?
If you manually command the z axis to move 100mm does it actually move 100mm when measured?
Are you using mesh grid compensation? -
@phaedrux Thanks for the quick reply.
This is a modified Flashforge Dreamer with E3D Titan being used.
I will post my conf.g in about an hour as I do not have access to it right now.
I do use variable layer height, but for testing I have just been using .1mm layer height.
Not sure on the Z distance, that is one thing I was going to check. I have not yet though, but will here soon as I get a chance.
I am using the Auto Compensation from Duet as I do not have a probe.Hopefully this helps.
@phaedrux My Z Axis was off .5mm during a 100mm test. I have since corrected this.
It prints great for a few later and then it starts grinding through the filament and quits feeding. It didn't get balled up this time.
It looks like it is messing up on the second layer every time now. First layer looks great!
What material are you printing? It looks like the second layer isn't bonding at all. I've seen that happen when trying to print ABS with too little heat and too much cooling fan.
Does your nozzle have a blockage? Can you do an atomic pull on the hot end?
@phaedrux I'm printing with PLA. No blockage as I already checked and put in a new nozzle.
It keeps grinding the filament after a layer or two.
I'm not sure this is a problem with a setup of the board at this point.
Not sure what could be causing it.
Can you extrude into free air without issue? Trying to eliminate the extruder as possible issue.
Can you run an M122 in the console and post resulting diagnostic?
I notice in your config that you have 2 extruders specified. Are they the same? Some of the values differ.
M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation M92 X100 Y100 Z400 E624:582 ; Set steps per mm M566 X1200 Y1200 Z18 E300:300 ; Set maximum instantaneous speed changes (mm/min) M203 X6000 Y6000 Z180 E1200:1200 ; Set maximum speeds (mm/min) M201 X1000 Y1000 Z100 E5000:5000 ; Set accelerations (mm/s^2) M906 X1000 Y1000 Z1000 E1000:1600 I30 ; Set motor currents (mA) and motor idle factor in per cent
Do you have other filament to test with? Perhaps your PLA has gone stale.
Or perhaps the hotend is not getting as hot as you expect it to? That could explain the poor adhesion.
Can you verify the temperature of the hotend with a thermocouple?
Are the temps stable?
Have you run a PID tune on the hotends yet?
Are you sure your thermistor values in config.g are correct?Sorry for the shotgun blast of ideas.
I only have one extruder so I'm not sure why it shows two or how exactly to fix that.
As for extruding into free air. It appears to do this just fine (have extruded several hundred mms this way).
I can try with other filament yes even though before the build I was using this filament.
I am using a PT1000 sensor and it shows the temp at room temperature is accurate. I'm not sure how to very if it is accurate when heated up though.
The temps do remain stable.
Here is the diagnostic.
M122
Used output buffers: 4 of 32 (10 max)
RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later
Board ID: 08DGM-956GU-DJMSN-6J1FA-3SN6P-TUNZF
Static ram used: 16152
Dynamic ram used: 100448
Recycled dynamic ram: 2184
Stack ram used: 1224 current, 4512 maximum
Never used ram: 7776
Last reset 00:00:22 ago, cause: software
Last software reset at 2018-08-01 18:15, reason: User, spinning module GCodes, available RAM 7776 bytes (slot 1)
Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x04417000, BFAR 0xe000ed38, SP 0xffffffff
Error status: 0
Free file entries: 10
SD card longest block write time: 0.0ms
MCU temperature: min 27.0, current 27.5, max 28.4
Supply voltage: min 24.3, current 24.4, max 24.6, under voltage events: 0, over voltage events: 0
Date/time: 2018-08-01 18:16:13
Slowest main loop (seconds): 0.014056; fastest: 0.000046
MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
Bed compensation in use: none
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi firmware version 1.21RC4(08b3)
WiFi MAC address 00:00:00:00:00:00
WiFi Vcc 3.34, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 17088
WiFi IP address 0.0.0.0
WiFi signal strength -39dBm, reconnections 0, sleep mode modem
Socket states: 2 0 0 0 0 0 0 0
=== Expansion ===
- WiFi -
That is fine. I appreciate the help as I'm stuck on what to do.
I am fairly certain I have the thermistor values correct in config.g.
I have not PID tuned them and I'm not really familiar with the process.
According to this: https://duet3d.dozuki.com/Wiki/Connecting_thermistors_or_PT1000_temperature_sensors#Section_PT1000_sensors
I don't think you have your PT1000 configured correctly.You currently have
M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
but should have
M305 P1 X501 R4700
That could explain your actual temperature being different from what's reported.
Here is the wiki for tuning the heaters.
https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
Getting the temps correct will be first step.
Okay, I will check this out and report back. Thanks!
I can confirm it does the same thing with different filament.
I looked at the config and everything as far as the heaters go looks correct. This is the settings.
M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
M305 P1 X200 ; Configure thermocouple for heater 1
M143 H1 S280 -
Heater 0 is the bed.
Heater 1 is the hotend for extruder 1. -
Wow, I upped the temp by 20 degrees and it is now printing fine.
I guess it was grinding filament because it wasn't hot enough to melt it properly.
Looks like I will be PID tuning it when I figure out how.
Thanks for the help man!
@justinds89 said in Question on Z-Offset and Start Script, Also Nozzle Adjustment.:
I guess it was grinding filament because it wasn't hot enough to melt it properly.Your slicer may be configured to reduce the extrusion temperature after the first layer. Also, if your print cooling fan is directing too much air at the heater block and the nozzle instead of at the print, the nozzle temperature may drop a little when the print cooling fan turns on, which is usually at the start of the second layer.
