    Stable firmware 2.01 (Duet 2) and 1.22 (Duet 06/085) released
    Firmware installation
    19
    65
    9.8k
    • whosrdaddyundefined
      whosrdaddy @whosrdaddy
      Ok, I sliced a smaller file and now I can see the object height. I suppose the firmware does not attempt to read the height for larger files?
      • wilrikerundefined
        wilriker @whosrdaddy
        @whosrdaddy I just uploaded the largest GCode file I could find on my hard drive (just a little under 11 MiB) and it got the height correctly from it. I also checked the file and it does not contain a comment with object height, so RRF must have scanned for the last rise in Z.
        Don't get me wrong, I don't wanna say you don't have a problem, just that I cannot reproduce it.
        Could you try to slice the same source file with another slicer?
        Manuel
        My Tool Collection
          whosrdaddy
          Well did as requested and it seems it has nothing to do with the slicer, used exactly the same STL files:
          wilrikerundefined Dougal1957undefined 2 Replies Last reply Reply Quote 0
          • wilrikerundefined
            @whosrdaddy OK, your file is larger than mine, so maybe there is a lower limit to this issue.
            Manuel
            My Tool Collection
            • Dougal1957undefined
              Dougal1957 @whosrdaddy
              @whosrdaddy Can you post the stl for the 2 that fail so we can try it? I have several file much bigger than those that are correct
                whosrdaddy
                Sure, you can download it from here:
                • wilrikerundefined
                  @whosrdaddy With this file I can reproduce your issue:
                  Manuel
                  My Tool Collection
                    @whosrdaddy this is what I get for that file
                    It's not easy to read cos this forum is re-sizing the image but my file is 3 times the size of yours but gives 8.2mm hight and 39.xxx mtrs of filament. the diff may be the amount of infill mind
                      whosrdaddy
                      so we established there is an issue, it's not the file size because you have a 31MB file.
                      Lets wait & see what @dc42 thinks about this...
                        Dougal1957
                        I Too am on the latest FW and DWC
                          The firmware has has to seek backwards through the file from the end to find the last Z move. With large files this can get very slow because of the way the FAT file system works, especially if the SD card is formatted using a small cluster size. So to prevent DWC timing out, recent firmware versions apply a time limit to this operation.
                          To speed up access and minimise the chance of reaching the time limit, format the SD card using the largest cluster size you can, which is 64kb for 4Mb cards and smaller (FAT16 format), and 32kb for larger cards (FAT32 format). Send M39 to find the current cluster size.
                          wilrikerundefined appjawsundefined 2 Replies Last reply Reply Quote 0
                            whosrdaddy
                            Thanks David, I understand now. It's not a big issue anyway, since I am currently printing non stop, I will try your advice later 🙂
                            • Qdeathstarundefined
                              Qdeathstar
                              I consider this to be a bug:
                              Now that you can upload g-code while you print, if you upload a file with the same name as the file you are printing, the print will switch from the file you were printing to the new file.
                                dc42 administrators @Qdeathstar
                                @qdeathstar said in Stable firmware 2.01 (Duet 2) and 1.22 (Duet 06/085) released:
                                I'll add this to the list of things to fix. The firmware already checks for trying to delete a file while it is being printed.
                                EDIT: I just found it was already on the list, but low priority.
                                BPisLifeundefined 1 Reply Last reply Reply Quote 0
                                • dragonnundefined
                                  dragonn
                                  Maybe add a warning/question? This helped my last time when I need to add a pause command into a running print.
                                  • wilrikerundefined
                                    wilriker @dc42
                                    @dc42 said in Stable firmware 2.01 (Duet 2) and 1.22 (Duet 06/085) released:
                                    I just ran M39 and got
                                    SD card in slot 0: capacity 3.98Gb, free space 3.78Gb, speed 20.00MBytes/sec, cluster size 64kb
                                    so my card is already formatted to the largest possible cluster size (it came this way I never touched it) and still I could reproduce @whosrdaddy's issue. Intersting why it works for @Dougal1957 with an even larger file though.
                                    Just an idea: @Dougal1957 do you still have the stock SD card or do you maybe use a faster one? Also @dc42 do you know more details on the speed of the stock SD card?
                                    Manuel
                                    My Tool Collection
                                      Dougal1957 @wilriker
                                      @wilriker Prob not I go thru cards quite a lot (take them out put them down and lose them lol) M39 gives
                                      SD card in slot 0: capacity 15.93Gb, free space 15.18Gb, speed 20.00MBytes/sec, cluster size 32kb
                                      • appjawsundefined
                                        appjaws @dc42
                                        When uploading a laser file, which could be in excess of 30MB there is a large delay. I keep getting "could not fine end of file error".
                                        For Laser files, the Object Height, Layer Height and Filament Usage are not required or recorded in the file, so the firmware will ever obtain the data.
                                        appjaws - Core XYUV Duet Ethernet Duex5
                                        firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                                        Ormerod 1-converted to laser engraver, Duet wifi
                                        OpenSCAD version 2024.03.18
                                        Simplify3D 5.1.2
                                          @appjaws, what is the exact message you are getting, and when?
                                          • appjawsundefined
                                            appjaws
                                            DWC just sits after the file has been uploaded until it fills each box with N/A.
                                            The firmware is searching for this data when it doesn't need to for laser files.
                                            The "could not find end of file error" appears randomly during printing.
                                            I will see if I can nail the exact conditions later
                                            Edit. The "could not find end of file error" appears when the print starts
                                            Simplify3D 5.1.2
