    Stable firmware 2.01 (Duet 2) and 1.22 (Duet 06/085) released
    Firmware installation
    19
    65
    9.8k
    • wilrikerundefined
      wilriker @whosrdaddy
      @whosrdaddy OK, your file is larger than mine, so maybe there is a lower limit to this issue.
      Manuel
      My Tool Collection
      • Dougal1957undefined
        Dougal1957 @whosrdaddy
        @whosrdaddy Can you post the stl for the 2 that fail so we can try it? I have several file much bigger than those that are correct
        • whosrdaddyundefined
          whosrdaddy
          Sure, you can download it from here:
          wilrikerundefined Dougal1957undefined 2 Replies Last reply Reply Quote 0
          • wilrikerundefined
            @whosrdaddy With this file I can reproduce your issue:
            Manuel
            My Tool Collection
              @whosrdaddy this is what I get for that file
              It's not easy to read cos this forum is re-sizing the image but my file is 3 times the size of yours but gives 8.2mm hight and 39.xxx mtrs of filament. the diff may be the amount of infill mind
                whosrdaddy
                so we established there is an issue, it's not the file size because you have a 31MB file.
                Lets wait & see what @dc42 thinks about this...
                  Dougal1957
                  I Too am on the latest FW and DWC
                    The firmware has has to seek backwards through the file from the end to find the last Z move. With large files this can get very slow because of the way the FAT file system works, especially if the SD card is formatted using a small cluster size. So to prevent DWC timing out, recent firmware versions apply a time limit to this operation.
                    To speed up access and minimise the chance of reaching the time limit, format the SD card using the largest cluster size you can, which is 64kb for 4Mb cards and smaller (FAT16 format), and 32kb for larger cards (FAT32 format). Send M39 to find the current cluster size.
                    wilrikerundefined appjawsundefined 2 Replies Last reply Reply Quote 0
                      whosrdaddy
                      Thanks David, I understand now. It's not a big issue anyway, since I am currently printing non stop, I will try your advice later 🙂
                      • Qdeathstarundefined
                        Qdeathstar
                        I consider this to be a bug:
                        Now that you can upload g-code while you print, if you upload a file with the same name as the file you are printing, the print will switch from the file you were printing to the new file.
                          dc42 administrators @Qdeathstar
                          @qdeathstar said in Stable firmware 2.01 (Duet 2) and 1.22 (Duet 06/085) released:
                          I'll add this to the list of things to fix. The firmware already checks for trying to delete a file while it is being printed.
                          EDIT: I just found it was already on the list, but low priority.
                          BPisLifeundefined 1 Reply Last reply Reply Quote 0
                          • dragonnundefined
                            dragonn
                            Maybe add a warning/question? This helped my last time when I need to add a pause command into a running print.
                            • wilrikerundefined
                              wilriker @dc42
                              @dc42 said in Stable firmware 2.01 (Duet 2) and 1.22 (Duet 06/085) released:
                              I just ran M39 and got
                              SD card in slot 0: capacity 3.98Gb, free space 3.78Gb, speed 20.00MBytes/sec, cluster size 64kb
                              so my card is already formatted to the largest possible cluster size (it came this way I never touched it) and still I could reproduce @whosrdaddy's issue. Intersting why it works for @Dougal1957 with an even larger file though.
                              Just an idea: @Dougal1957 do you still have the stock SD card or do you maybe use a faster one? Also @dc42 do you know more details on the speed of the stock SD card?
                              Manuel
                              My Tool Collection
                                Dougal1957 @wilriker
                                @wilriker Prob not I go thru cards quite a lot (take them out put them down and lose them lol) M39 gives
                                SD card in slot 0: capacity 15.93Gb, free space 15.18Gb, speed 20.00MBytes/sec, cluster size 32kb
                                • appjawsundefined
                                  appjaws @dc42
                                  When uploading a laser file, which could be in excess of 30MB there is a large delay. I keep getting "could not fine end of file error".
                                  For Laser files, the Object Height, Layer Height and Filament Usage are not required or recorded in the file, so the firmware will ever obtain the data.
                                  appjaws - Core XYUV Duet Ethernet Duex5
                                  firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                                  Ormerod 1-converted to laser engraver, Duet wifi
                                  OpenSCAD version 2024.03.18
                                  Simplify3D 5.1.2
                                    @appjaws, what is the exact message you are getting, and when?
                                    • appjawsundefined
                                      appjaws
                                      DWC just sits after the file has been uploaded until it fills each box with N/A.
                                      The firmware is searching for this data when it doesn't need to for laser files.
                                      The "could not find end of file error" appears randomly during printing.
                                      I will see if I can nail the exact conditions later
                                      Edit. The "could not find end of file error" appears when the print starts
                                      Simplify3D 5.1.2
                                      • appjawsundefined
                                        appjaws
                                        This is a screen shot at the end of the Laser print.
                                        RepRapFirmware for Duet version 1.22 running on Duet 0.6
                                        Used output buffers: 3 of 16 (9 max)
                                        === System ===
                                        Static ram: 44652
                                        Dynamic ram: 41436 of which 4024 recycled
                                        Stack ram used: 136 current, 6084 maximum
                                        Never used ram: 2108
                                        Last reset 03:27:56 ago, cause: power up
                                        Last software reset at 2018-08-03 12:50, reason: User, spinning module GCodes, available RAM 1836 bytes (slot 2)
                                        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0xffffffff
                                        Error status: 0
                                        Free file entries: 10
                                        SD card 0 detected, interface speed: 21.0MBytes/sec
                                        SD card longest block write time: 1071.5ms, max retries 0
                                        MCU temperature: min 42.0, current 45.6, max 50.1
                                        Date/time: 2018-08-03 16:48:52
                                        Slowest loop: 1071.77ms; fastest: 0.09ms
                                        Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 100, MinFreeDm: 79, MaxWait: 2429950ms, Underruns: 1012201, 0
                                        Bed compensation in use: none
                                        Bed heaters = 0, chamberHeaters = -1 -1
                                        Segments left: 0
                                        Movement lock held by null
                                        http is idle in state(s) 0
                                        telnet is idle in state(s) 0
                                        file is idle in state(s) 0
                                        serial is idle in state(s) 0
                                        aux is idle in state(s) 0
                                        daemon is idle in state(s) 0
                                        queue is idle in state(s) 0
                                        Code queue is empty.
                                        === Network ===
                                        Free connections: 15 of 16
                                        Free transactions: 23 of 24
                                        Locked: 0, state: 4, listening: 20071c20, 0, 0
                                        Simplify3D 5.1.2
                                        • adri84djundefined
                                          adri84dj
                                          Good afternoon,
                                          I do not know if it's my problem, but I've made a couple of impressions with this latest firmware and the latest version of DWC, and it seems that the number of layers does not match the printed layers. My two impressions have finished in 52 of 50 layers
                                          Greetings.
                                            whosrdaddy
                                            @dc42:
                                            it is inconsistent, it seems not to depend on filesize.
                                            for completeness, this is my M39 output:
                                            SD card in slot 0: capacity 7.74Gb, free space 6.93Gb, speed 20.00MBytes/sec, cluster size 32kb
                                            I did not have this problem on 1.21 firmware.
