    *Unofficial* 1.22.0-gtj1 Release *Unofficial*
    PanelDue
    3.2k
    • gtj0undefined
      gtj0 @dragonn
      @dragonn OK, which firmware file do you use?
      dragonnundefined 1 Reply Last reply Reply Quote 0
      • dragonnundefined
        dragonn @gtj0
        @gtj0 PanelDueFirmware-v3-5.0.bin now I will try PanelDueFirmware-v3-5.0-nologo.bin
        • dragonnundefined
          dragonn
          nologo.bin - the same problem. Interesting that after boot it works for a 1-2 seconds, even the touchpad is responsive, then it crashes.
          • gtj0undefined
            gtj0
            When you first started the panel after the firmware install, were you asked to recalibrate your screen?
            • dragonnundefined
              dragonn @gtj0
              @gtj0 Yes, it asked my ever time when I re-flash the firmware.
              • gtj0undefined
                gtj0 @dragonn
                @dragonn OK, I'm looking through what I changed to see where the issue might be. It's odd though since you have the same panel resolution (800x480) as the 7i I have. When you first start the panel, see if you can quickly get to the Setup screen, then tap "Macro Columns" and set it to 1. Then go back the Control screen and see if it still crashes.
                • dragonnundefined
                  dragonn @gtj0
                  @gtj0 I set macro columns to 0 and then it works. Hmmm I think I see what is the problem, when I entered settings after flashing from old to new version marco columns was set to 255 :D. And it doesn't work when I set macro columns to auto, then it shows 255 too :P.
                  • dragonnundefined
                    dragonn
                    I found another bug - I clicked STOP on panel Due to kill my printer and disable heaters, the firmware did restart and DWC showed heaters active temp 0C but on PanelDue the didn't update, still was set 280C witch was not true.
                    • gtj0undefined
                      gtj0 @dragonn
                      @dragonn AhHa! OK, I made something unsigned when I should have made it signed. An easy fix and I'll do it tonight.
                      • gtj0undefined
                        gtj0 @dragonn
                        @dragonn said in *Unofficial* 1.22.0-gtj1 Release *Unofficial*:
                        That's not a bug it's a feature 🙂
                        I really dislike when the DWC forgets the temperature you've set when you turn the heater off. The PanelDue now remembers it but maybe I need to clear it if the printer has been reset and the PanelDue reconnects.
                        • dragonnundefined
                          dragonn @gtj0
                          @gtj0 I think we need to be consistent across DWC and PanelDue if you want to have you work merged. It will be confusing if DWC works another way then PanelDue witch such critical things like heaters.
                          • gtj0undefined
                            gtj0 @dragonn
                            @dragonn You maybe right but I also don't want to go down the route of not being able to fix things in PanelDue that are "broken" in DWC. I'll revert that for now and maybe add an option in setup for it later.
                            • gtj0undefined
                              gtj0
                              Update to fix the Macro Column initialization and revert the "sticky temps" feature...
                              https://github.com/gtjoseph/PanelDueFirmware/releases/tag/v1.22.0-gtj2
                                dc42 administrators @dragonn
                                If your panelDue controller is version 2.0 (check the back of the board) then you will need a v2 build, not a V3 build.
                                • dragonnundefined
                                  dragonn @dc42
                                  @dc42 Checked, I have v3.0 :P, didn't know 2.0 isn't the latest version.
                                  @gtj0 I can confirm that now everything works fine. About the sticky temps, I think we need a better solutions, maybe something like 'restore' button when you open the change temp menu.
                                  BTW. do you have plans to fix/add option to select with fan is controlled with PanelDue? My part cooling fan is connected to number 3 and not one :P. Would be nice to allow user selecting witch fan is controlled by PanelDue.
                                  gtj0undefined 2 Replies Last reply Reply Quote 0
                                  • gtj0undefined
                                    gtj0 @dragonn
                                    I am just about to upload a new version that has a new setup option for turning Sticky Temps on or off. There are a few other fixes as well.
                                    I didn't but I could. There's only 1 more slot left for storing config data though so @dc42 would need to weigh in. At some point we may need to start reading extended config info from a file on the printer but I don't know how @dc42 would feel about that. 🙂
                                    • dragonnundefined
                                      dragonn @gtj0
                                      @gtj0 reading config from Duet could be a really good idea, but it wouldn't limit the usage of PanelDue with other firmware's.
                                      • gtj0undefined
                                        gtj0
                                        I just created 1.22.0-gtj3
                                        https://github.com/gtjoseph/PanelDueFirmware/releases/tag/v1.22.0-gtj3
                                        Changes since last release:
                                        The ability to remember the active and standby temps when
                                        heaters are turned off is back and controlled by a new
                                        setup option. The default is "off" to be compatible with
                                        the DWC.
                                        Fixed an issue where the tool selection button wasn't
                                        cycling through the states correctly.
                                        Fixed an issue where the number of macro columns
                                        wasn't taking effect until a panel reset
                                        dragonnundefined 1 Reply Last reply Reply Quote 1
                                        • dragonnundefined
                                          dragonn @gtj0
                                          @gtj0 Look like everything works fine for me :D.
                                          gideonundefined 1 Reply Last reply Reply Quote 0
                                          • gideonundefined
                                            gideon @dragonn
                                            @gtj0 the firmware number also changes on the display to 1.22 or not because I used it but remains at 1.21.3 release. stand
