    Auto Level Question/Issue?
    3.8k
      dc42 administrators @jkdp
      @jkdp said in Auto Level Question/Issue?:
      ok my print finished. I've changed the S parameter in my config.g from (M671 X:-150:-150:800:800 Y-10:850:850:-10 S0) to (M671 X:-150:-150:800:800 Y-10:850:850:-10 S3) and when I run the autolevel (g32) still no corrections are made to leadscrews it only shows me in my g-code console "Bed equation fits points [25.0, 25.0, -0.047] [25.0, 720.0, 0.219] [650.0, 720.0, 0.641] [650.0, 25.0, 0.391]" the paramaeters do not change no matter how many times I run it.
      The S parameter in the last G30 command in bed.g needs to match the number of leadscrews. You must be using S3 in that command, but you need S4 because you have 4 leadscrews according to your M671 command. So it's doing old-style 3-point bed compensation instead.
      • jkdpundefined
        jkdp
        I already have the s4 command
        m561
        G28 ; home
        M401 ; deploy Z probe
        G30 P0 X5 Y5 Z-99999 ;probe near front right (FR) lead screw
        G30 P1 X5 Y720 Z-99999 ;probe near rear right (RR) lead screw
        G30 P2 X650 Y720 Z-99999 ;probe near real left (RL) lead screw
        G30 P3 X650 Y5 Z-99999 S4 ;probe near a front left (FL)
        G30 p4 X325 Y350 z-99999
        M402 ; retract probe
        G29 S1
        • jkdpundefined
          jkdp
          ok for reference I just attempted it this way, and also got no leadscrew adjustment.
          m561
          G28 ; home
          G30 P3 X650 Y5 Z-99999 ;probe near a front left (FL)
          G30 p4 X325 Y350 z-99999 S4
          G29 S1
            Phaedrux Moderator @jkdp
            @jkdp That print turned out quite well!
              m561
              G28 ; home
              G29 S1
              But was that with M671 X:-150:-150:800:800 Y-10:850:850:-10 S4 in config.g?
              • jkdpundefined
                jkdp
                Yes I had s4 and still not getting any leadscrew adjustments only the "Bed equation fits points [0.0, 0.0, 0.026] [0.0, 720.0, -0.016] [650.0, 720.0, 0.155] [650.0, 0.0, 0.018]" parameter.
                They've been turning out pretty good, a few settings left to adjust with the retraction settings and have a slight wobble in 2 screws, have 2 more coming in, just waiting to change them out.
                thanks
                  I think I need to ask for clarification on what you're expecting to happen, because I'm not sure really.
                  You say you want to get your motors back into sync, but don't want to home to zmax with endstops due to the time it takes to travel.
                  You're using G32 to run bed.g before a print and loading a heightmap for grid compensation with g29 s1.
                  What are you expecting G32 (bed.g) to do? When it runs do you see the z motors turning at all?
                  When the print starts, do you see the z motors turning to compensate for the bed surface? (G29)
                  • jkdpundefined
                    jkdp
                    what I want to happen is lets just say new build. I want to run g28 home, all axes, then a g29 to prepare a heightmap and then run g32 before a print to sync my motors so they are perfectly plane. and then start a print.
                    when I run g32 the z motors are turning, when a [print starts it does compensate for bed surface. but What I want to know is why it does not level the motors prior to a print when I run g32, even if I run it numerous times it does not show me different parameters.
                    • jkdpundefined
                      jkdp
                      basically I want the leadscrew adjustment to be made prior to printing
                        m561
                        G28 ; home
                        G29 S1
                        You are defining 5 probe points and using S4 on the last-but-one. So the final probe point will be ignored. You should either delete the final (G30 p4) point, or move the S4 parameter to that one.
                        However, I am not sure that is causing the problem. Please run M671 without parameters and check the response, to ensure that your M671 command in config.g was accepted.
                        • jkdpundefined
                          jkdp
                          SOME PROGRESS!! got this msg:
                          10‎:‎09‎:‎58‎ ‎PM
                          M671 Z leadscrew coordinates are not configured
                          • jkdpundefined
                            jkdp
                            I think my error be in my mapping or in my lead screw position if someone can look over that.
                            • jkdpundefined
                              jkdp
                              in the "settings" tab - under "Machine Properties" shouldn't all 4 z motors be 0_1534040600645_de.png listed there?
                              • jkdpundefined
                                jkdp
                                is the location of my m671 command in my config.g file in the correct location I do have it after the m669 and m667 but....
                                • jkdpundefined
                                  jkdp
                                  I found the problem. Stupid user error... I've been battling with this past 3 months.....
                                  M671 X:-150:-150:800:800 Y-10:850:850:-10 S1
                                  I have a : in front of the x axis coordinate X:-150
                                  Ugh...
                                  But Thank you very much guys administrator and Phaedrux wouldn't have been able to figure this one out without you guys.
                                  • jkdpundefined
                                    jkdp
                                    also one other question should I have
                                    M92 X160 Y80 Z1605 E418 ; Set steps per mm
                                    or should I have this
                                    M92 X160 Y80 Z1605:1605:1605:1605 E418 ; Set steps per mm
                                    with the same idea for all parameters with z axis movement settings with-in config.sys
                                    • jkdpundefined
                                      jkdp
                                      correction config.g
                                      • jkdpundefined
                                        jkdp
                                        ALSO one other thing now when I run g32 I get the leadscrew adjustment made 🙂 but I am not able to see a heigh map from the gui.??
                                          Do you mean g29?
                                          Can you view the height map in the DWC?
                                            You need only one Z motor current in your M906 command. It will be applied to all the Z motors.
                                            To generate a height map, you must run G29.
