    Magball arm adapter
    Order discussion
    1.5k
    • boldnutsundefined
      boldnuts
      Hi, is it possible to just buy the Smart Effector for delta pcb magball arm adapters on there own?
        T3P3Tony administrators @boldnuts
        @boldnuts the arms are made by Haydn Huntly he makes them in all sorts of lengths:
        https://plus.google.com/+HaydnHuntley
        • boldnutsundefined
          boldnuts
          Hi sorry I meant the pcb adaptors that you guys make that normally comes with the smart Effector
            If T3P3 doesn't have any spares, I have a set left over from prototyping. They don't have as many holes in them as the current production ones, but they have the 4 in a 20mm square for the carriage plus the 2 for the magballs.
            boldnutsundefined 1 Reply Last reply Reply Quote 0
            • boldnutsundefined
              boldnuts @dc42
              @dc42 That would be great thanks, which would be the best way for me to purchase them from you, I am in the UK
                Please use the contact form at http://escher3d.com/pages/contact/contactindex.php.
                • fcwiltundefined
                  fcwilt
                  Just out of curiosity why do need them?
                  • boldnutsundefined
                    boldnuts
                    For a Tevo little monster, I have the smart effector but no adapters
                    • Danalundefined
                      Danal
                      Using the "factory" adapters is fantastic idea.
                      If, and only if YOU want to do so, you can also print adapters that fit HWIN style carriages. Specifically, these are for 9mm belts. They would also work fine for 6mm belts.
                      https://www.thingiverse.com/thing:2795329
                      • fcwiltundefined
                        fcwilt @boldnuts
                        @boldnuts said in Magball arm adapter:
                        If you are looking for adapters for rails in a delta I can provide you with a STL for the required spacing (or most any other spacing) and you could print your own.
                          @boldnuts if you want to purchase the production version then please email info@duet3d.com otherwise getting a prototype from David should be cheaper.
