    Laser Filament Monitor - test results
    Filament Monitor
    16
    139
    20.9k
    • wilrikerundefined
      wilriker @T3P3Tony
      @t3p3tony said in Laser Filament Monitor - test results:
      we got the best readings at 9mm gap but that is not conclusive.
      Strange, I could swear I saw 7mm in the first post but checked and it says 9mm. 😕
      I wanted to start with what you tested. So it's good that my print of the housing today failed already at the brim. 😂
      worth trying a variety of gaps.
      I already sliced all (integer) gaps 4-9mm to accommodate this. 🙂
      @tinkerz There also is an open variant of @dc42's original housing so a filament window is not necessarily bad but it has to be tested as well.
      Manuel
      My Tool Collection
      tinkerzundefined 1 Reply Last reply Reply Quote 0
      • wilrikerundefined
        wilriker @T3P3Tony
        @t3p3tony Did you use the open or closed version of the housing for the above tests? It does not say so in the text.
        Manuel
        My Tool Collection
        • tinkerzundefined
          tinkerz @wilriker
          @wilriker Thanks for clearing that up about there being both opened and closed. I saw the closed but also saw the one making reference to divergence of the light with the angled window. Guess I just assumed they had eliminated that already. Carry on all! 😉
            T3P3Tony administrators @wilriker
            @wilriker sorry, used the open version. I have also tried closed won other tests without a conclusive improvement, possibly due to internal reflection.
            • Qdeathstarundefined
              Qdeathstar
              Sure, i will re-run the last test. The light blue filament is about 2 years old, so im not sure if that might have something do do with the reading. I think it might have detected some real slippage there.
                Qdeathstar
                White ABS - Matterhackers - Benchy Test
                Calibrated Steps/mm 424
                M591 D0
                Duet3D laser filament monitor on endstop input 3, disabled, allowed movement 40% to 120%, check every 3.0mm, current position 2.5, brightness 88, shutter 7, measured minimum 43%, average 71%, maximum 87% over 3970.6mm
                • brunofportoundefined
                  brunofporto
                  If you put the sensor AFTER the extruder, and aligned with the markings made by the extrusion gear, the texture will allow better readings for any type of filament. These optical flow mouse sensors work better with textures than with bright surfaces after all.
                    T3P3Tony administrators @Qdeathstar
                    @qdeathstar youch serious under reading on ABS!
                    • kraegarundefined
                      kraegar
                      I'm kind of surprised. I printed my housing out of Carbon Fiber PETG. Had someone ask for some printer parts, so I'm printing in the same Carbon Fiber PETG, and it's very very close.
                      Duet3D laser filament monitor on endstop input 3, disabled, allowed movement 40% to 120%, check every 3.0mm, current position -1.9, brightness 77, shutter 17, measured minimum 91%, average 97%, maximum 112% over 9128.9mm
                        T3P3Tony administrators @kraegar
                        @kraegar thats much better results... very workable.
                          Qdeathstar
                          I am under reading again using transparent-green ABS
                          Hatchbox Transparent Green - Benchy Test
                          Duet3D laser filament monitor on endstop input 3, disabled, allowed movement 40% to 120%, check every 3.0mm, current position 4.6, brightness 83, shutter 17, measured minimum 45%, average 69%, maximum 89% over 3968.1mm
                          Matter Hackers Black ABS - Partial Benchy Test
                          Steps/mm 424
                          M591 D0
                          Duet3D laser filament monitor on endstop input 3, disabled, allowed movement 40% to 120%, check every 3.0mm, current position -8.1, brightness 89, shutter 17, measured minimum 93%, average 96%, maximum 99% over 366.2mm
                          Im a little lower than my previous Black ABS test, but the steps/mm is also lower for this test (so it makes sense).. But I'm not way down near my white ABS or Transparent Green ABS....
                          Materhackers Lime Green (Opaque Neon) ABS Filament - Benchy Test
                          M591 D0
                          Duet3D laser filament monitor on endstop input 3, disabled, allowed movement 40% to 120%, check every 3.0mm, current position -3.2, brightness 94, shutter 13, measured minimum 75%, average 91%, maximum 98% over 3974.8mm
                            @qdeathstar looks like color of pigment is playing more of a part than the filament material for those ABS's
                            @DC42 It would be great to have the ability to set the 100% amount in much the same manner as the mm/revolution of the magnet can be set in that version.
                              dc42 administrators @T3P3Tony
                              I think it would be confusing to change the 100% amount. Also, if the sensor under-reads the average amount for a particular filament, you are also likely to get much bigger variation for that filament. For example, the post by @Qdeathstar gives 93% to 99% for one filament, and 45% to 89% for another. So simply adjusting the 100% amount wouldn't be sufficient.
                              Instead I think you should use the new M703 command in conjunction with the filament management facility to set up appropriate R limits in the M591 command for the filament in use.
                              wilrikerundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 1
                              • wilrikerundefined
                                wilriker @dc42
                                @dc42 said in Laser Filament Monitor - test results:
                                I had the same thought.
                                Manuel
                                My Tool Collection
                                  T3P3Tony administrators @dc42
                                  Hi David, sure can set the limits to whatever, I was just thinking that it would be nice to "zero" the filament on the average for that type. Actually I might have zeroed it on the low reading as I don't care if it reads an "over extrusion" since the failure modes we are generally interested in lead to under, not over extrusion.
                                  • wilrikerundefined
                                    wilriker
                                    😠 Something seems to not want me to use this sensor. Second attempt to print the housing failed also. This time my fan shroud was somehow coming loose (never ever had this before) and knocked the print of the bed. 🤦
                                    Manuel
                                    My Tool Collection
                                      Qdeathstar
                                      Ok, last ABS test
                                      Matterhackers Light - Blue ABS filament - Benchy Test
                                      Calculated Steps/mm 424
                                      M591 D0
                                      Duet3D laser filament monitor on endstop input 3, disabled, allowed movement 40% to 120%, check every 3.0mm, current position -2.4, brightness 92, shutter 11, measured minimum 0%, average 93%, maximum 102% over 3975.4mm
                                      wilrikerundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                                      • wilrikerundefined
                                        wilriker @Qdeathstar
                                        @qdeathstar You seem to like ABS. 😉
                                        Manuel
                                        My Tool Collection
                                          @qdeathstar said in Laser Filament Monitor - test results:
                                          Ok, last ABS test
                                          M591 D0
                                          minimum 0?
                                          do you mind checking that again?
                                          Qdeathstarundefined 1 Reply Last reply Reply Quote 0
                                            Qdeathstar
                                            Yes, i can rerun that test later today. I think that might have been a real slippage, as this blue filament feels pretty slippery. I also noticed while i was loading it it didn't move the first time i pressed "extrude" but i chalked it up to me accidentally pressing the "retract" button instead. Its about 2 years old....
