    Problems setting up duet ethernet on a Rostock Max V2
    1.4k
      I suggest you start by testing the motors individually as described at https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter#Section_Testing_the_motors_individually.
      You appear to be using a version of Notepad that does not like text files with Unix-style line endings. I recommend you use Notepad++ instead.
      • Brmattundefined
        Brmatt
        I tried doing this as follows: typing the G91 command into paneldue then trying G1 S2 command for each axes and nothing happens. Perhaps I wasn't supposed to do them in paneldue?
        • Brmattundefined
          Brmatt
          ok I got those commands to work now. It seems my Y axesis moving the wrong way. Resetting that now.
          • Brmattundefined
            Brmatt
            Ok they are all moving fine now, however the x y and z coordinates are all wrong and it still doesnt listen to the endstops. Pressing the homing button moves all the axes down maybe 5 mm. Is it supposed to do this?
              dc42 administrators @Brmatt
              @brmatt said in Problems setting up duet ethernet on a Rostock Max V2:
              It sounds like your endstops register as triggered when not, and vice versa. Test them using M119. If I am right, fix it by changing S0 to S1 or vice versa in your M574 command in config.g.
              Brmattundefined 1 Reply Last reply Reply Quote 1
              • Brmattundefined
                Brmatt @dc42
                @dc42 Ok it looks like you were right. M119 said they were all triggered when they were not. However after changing it I tried homing again and it went straight up and did not stop on the endstops at all.
                  Have you tested that M119 does report the endstops as triggered when you press them (assuming they are microswitches)?
                  I suggest you look at the Commissioning tests section of https://duet3d.dozuki.com/Wiki/Step_by_step_guide.
                  • Brmattundefined
                    Brmatt @dc42
                    @dc42 I looked through there and I didn't see anything that looks wrong. I believe my endstops are plugged in correctly (If I switch which way I have them plugged in various lights turn on such as the red bed heat light). Something in the firmware still?
                      Please test them as I suggested in my previous reply. If they are simple microswitches then they should be connected to the outer 2 pins of each endstop connector, leaving the centre pin not connected. See the wiki page on connecting endstops.
                      • Brmattundefined
                        Brmatt @dc42
                        @dc42 hmm ok let me try changing the wire arrangement in the connector.
                          After connecting them correctly, you may need to change S0 back to S1 in the M574 command.
                          • Brmattundefined
                            Brmatt @dc42
                            @dc42 Yep you're exactly right. After re configuring the connectors from the stock arrangement the endstop lights are on but you are correct in that I have to change that parameter back.
                            • Brmattundefined
                              Brmatt
                              Alright it now homes perfectly. Now onto my second question haha. First thanks for all your help. Your activity on the forum is life saving. So as i briefly stated the extruder doesn't respond to any input from the paneldue. My only suspicion is maybe since I have no E0 endstop plugged in I need to change that parameter in config but that doesn't seem like it should cause that. Any thoughts?
                              • Dougal1957undefined
                                Dougal1957 @Brmatt
                                @brmatt have you heated the hotend if not then you need to allow Cold extrusion with M302 command the parameters of which I believe now depend on the version of Firmware on your board
                                Brmattundefined 1 Reply Last reply Reply Quote 0
                                • Brmattundefined
                                  Brmatt @Dougal1957
                                  @dougal1957 oh interesting I see. Thank you.
