    New beta firmware 2.02beta1
    Firmware installation
    16
    75
    10.5k
    • wilrikerundefined
      wilriker @GizmotronX5000
      @gizmotronx5000 Did you include it as a workspace path or as an absolute filesystem path in eclipse? I did the latter and explicitly have DuetWifiSocketServer not in my workspace at all.
      Manuel
      My Tool Collection
      • GizmotronX5000undefined
        GizmotronX5000
        It's an absolute file system path not included in my workspace. I don't have the duetwifisocketserver project, just the messageformats.h, which worked before.
        • wilrikerundefined
          @gizmotronx5000 I'm sorry, but now I run out of ideas. 😞
          Manuel
          My Tool Collection
            dc42 administrators @GizmotronX5000
            @gizmotronx5000 said in New beta firmware 2.02beta1:
            I get about 30 errors coming from "WiFiInterface.h". Most are of the form "symbol/type xxxxx cannot be resolved." I also get this error: make: *** [Duet2CombinedFirmware.elf] Error 1.
            it would help if you post the exact error messages.
            GizmotronX5000undefined 1 Reply Last reply Reply Quote 0
              GizmotronX5000 @dc42
              @dc42 Good point! I managed to get rid of the make.exe errors somehow. I nuked the project and just restarted it from the build instructions. It now compiles, but I still get the following errors, which are apparently not critical to the build.
                GizmotronX5000 @GizmotronX5000
                @gizmotronx5000
                I cleaned all of the projects and restarted Eclipse (again). Everything compiles without errors now. Magic!
                  Eclipse sometimes reports Semantic Errors spuriously, or generates them correctly but doesn't remove them when you correct the problem - especially if the correction involves an include file that is outside the project. These are generated by Eclipse, not by the compiler. Often they go away if you run index rebuild on the project and bring the file for which the errors were reported to the foreground. Other times you may need to delete them, then clean and build the project to make sure there are no compiler errors or warnings.
                  gdybzundefined 1 Reply Last reply Reply Quote 0
                  • gdybzundefined
                    gdybz @dc42
                    @dc42 I am getting the same [Duet2CombinedFirmware.elf] Error 1 that others have posted about. I had this code running yesterday but when I tried to use it today I'm getting the error even after cleaning, restarting, and running index rebuild. I did not change any code or even exit Eclipse overnight.
                    • brunofportoundefined
                      brunofporto
                      @dc42 I would like to suggest to create a topic for each new feature and link them at the OP of these "new beta" posts. So we can focus and the subjects does not get lost.
                      For example my experience with DAA not showing much improvement 🙂
                      By the way. Besides the DAA not having much effect I had no issues or new bugs with this beta.
                      • zerspaner_gerdundefined
                        zerspaner_gerd @dc42
                        @dc42 said in New beta firmware 2.02beta1:
                        Have you read https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M703_Configure_filament to see how M703 is intended to be used?
                        Yes, I have already read that!
                        I just mentioned that unfortunately it does not work in "Load Filament" Macro!
                        It works in other application cases.
                        Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
                        • wilrikerundefined
                          wilriker @zerspaner_gerd
                          @zerspaner_gerd said in New beta firmware 2.02beta1:
                          Do you mean that in the load.g macro for the filament (configured via context-menu for this filament in DWC) you are loading you want to add M703 to immediately also load the same filament's config.g?
                          Manuel
                          My Tool Collection
                          zerspaner_gerdundefined 1 Reply Last reply Reply Quote 0
                            zerspaner_gerd @wilriker
                            @wilriker Here is a picture of my attempt:
                            But yes, I think we mean the same!
                            • wilrikerundefined
                              @zerspaner_gerd Coincidently my loading macro looks exactly like your third line.
                              Anyway, the problem here certainly is that at this point in time the filament is not completely loaded in regards to firmware so it would not know which config.g to load with M703.
                              @dc42 and @chrishamm should this be like that? Is there a case where loading a filament (in software) could fail/abort? Otherwise the info about which filament is loaded could be saved as the very first step and this would resolve this race. I could look into changing this most likely on Monday.
                              Manuel
                              My Tool Collection
                                Chrishamm wrote and maintains the filament management code, so I'll leave this for him to answer.
                                • chrishammundefined
                                  chrishamm administrators
                                  At present it is not intended to use M703 in the load.g macro because DWC already sends it after the filament has been loaded and because the filament name is NOT assigned until the load.g macro has finished AFAIR. A better place for M703 would be your tpost*.g macro because you usually want to apply different settings when you select a tool that is loaded with a different material.
                                  At present DWC does the following when you load/change a filament:
                                  1. A tool is selected using a T-code (if the selected tool is different)
                                  2. If a filament is already assigned to the tool, it is unloaded via M702 which runs the unload.g macro of the old filament
                                  3. M701 is invoked with the corresponding filament name, which runs the corresponding load.g. Do only the loading here (e.g. set temperatures, ask the user to insert filament and eventually load it)
                                  4. M703 is invoked which runs config.g of the corresponding filament (if present). There you can set extrusion factors, pressure advance, temperatures and possibily the speed factor to use
                                  Duet software engineer
                                  brunofportoundefined 1 Reply Last reply Reply Quote 0
                                    brunofporto @chrishamm
                                    @chrishamm said in New beta firmware 2.02beta1:
                                    Would be interesting to call the config.g for filaments with another name to avoid consfusion. Something like fconfig.g 😄
                                    • spwundefined
                                      spw
                                      @dc42 great work on adding S parameter to control laser PWM
                                      I have a suggestion to make it more compatible with other laser engravers and Laserweb software:
                                      When S parameter is not provided it should keep the previous PWM value instead of turning off the laser, the G0 should turn off the laser
                                      Example output from Laserweb:
                                      G0 X86.61 Y21.34
                                      G1 X86.61 Y21.34 S255.00 F1300
                                      G1 X86.61 Y21.33
                                      G1 X86.62 Y21.33
                                      G1 X86.62 Y21.33
                                      G1 X86.62 Y21.33
                                      G1 X86.62 Y21.33
                                      G0 X91.07 Y16.73
                                      G1 X91.07 Y16.73 S255.00 F1300
                                      G1 X91.07 Y16.73
                                      G1 X91.07 Y16.73
                                      G1 X91.06 Y16.73
                                      G1 X91.06 Y16.73
                                      G1 X91.06 Y16.72
                                      G1 X91.06 Y16.72
                                        dc42 administrators @spw
                                        @spw, it's a shame they chose to make it work that way. It would have been much safer to default to zero power. Anyway, I'll change it. I'll also need to make sure that the laser is turned off at pause and on again at resume. Tedious...
                                        • samlogan87undefined
                                          samlogan87
                                          Hi everyone,
                                          I upgraded to this version a week back as I was having issues with the official release before this. One thing I have noticed with this is that the extruder temperature is not always set when loading the GCode. I am using Cura 3.4.1 and printing directly to the printer via the plugin. Looking at the start of the g code it is setting the temperature, but when you start a print, the bed heats up and the extruder is set to 0 degrees.
                                          Here is the start of the gcode file:
                                          ;FLAVOR:RepRap
                                          ;TIME:6266
                                          ;Filament used: 11.8932m
                                          ;Layer height: 0.2
                                          ;Generated with Cura_SteamEngine 3.4.1
                                          T0
                                          M190 S50
                                          M104 S200
                                          M109 S200
                                          M82 ;absolute extrusion mode
                                          ; Startup Gcode
                                          G91 ; Relative Positioning
                                          G1 Z5 ; Move Z down 1mm
                                          G90 ; Absolute Positioning
                                          G28 XY ; Home XY
                                          M561 ; Clear any bed transform
                                          G32 ; Start 3-point probe sequence
                                          G28 Z ; Home Z
                                          M375 P"heightmap.csv" ; Load heightmap
                                          G1 Z20.0 F6000 ; Move Z to 20
                                          G1 X10 Y10 ; Move Head to front left
                                          M582 T1 ; check levels of inputs that give rise to trigger #1
                                          G92 E0 ; Zero Extruder
                                          G1 F200 E30 ; Prime the extruder
                                          M83 ;relative extrusion mode
                                          Can anyone shed any light on this? Is it the plugin or the firmware?
                                          Kind Regards,
                                          Sam
                                          Custom Core-XY
                                            @samlogan87
                                            If you upload the file directly and print it from the DWC does it set the temp properly?
                                            If you set your temp manually from the DWC does it heat up?
