    My custom Cartesian
    My Duet controlled machine
    14
    152
    23.5k
    • Witchdoctrundefined
      Witchdoctr
      Just wanted to say thank you for your build log.
      I went a very similar route to you, started with an Anet A8 and am now left with a box full of spare bits that looks suspiciously like an Anet A8 (Only thing left is the stepper motors and guides)...
      The Duet was a bit of a pain to configure after using Marlin but the first test benches turned out like a dream with your settings.
      So thanks again!
      • wilrikerundefined
        wilriker @Witchdoctr
        @witchdoctr said in My custom Cartesian:
        I'm glad that this helped you. 🙂
        Manuel
        My Tool Collection
        • wilrikerundefined
          wilriker
          @OBELIKS Can you measure the length of your Anet stock steppers? I just measured the length of the newer 0.9A steppers and they are not 40mm but only 37.3mm long.
          So compared to the 48mm long Wantai steppers (would you be so kind to measure their length as well?) that is an extra of over 10mm and I have a feeling that I will not be able to fit them everywhere. 😕
          Manuel
          My Tool Collection
          OBELIKSundefined 1 Reply Last reply Reply Quote 0
          • OBELIKSundefined
            OBELIKS @wilriker
            @wilriker sure, tomorrow. I wrapped up for today.
            P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
            Original Prusa i3 MK3S
            • OBELIKSundefined
              OBELIKS
              Eh, I needed to fetch a beer from the storage. So I hopped in to the "workshop"
              Anet steppers are 37,8mm long and Wantai real length is 46,8mm.
              And the beer is imperial IPA with 10% alcohol. And it is brilliant.
              wilrikerundefined 1 Reply Last reply Reply Quote 3
              • wilrikerundefined
                wilriker @OBELIKS
                @obeliks said in My custom Cartesian:
                Thanks for that! 👍 Will measure on the weekend of I can fit them. Biggest issue might be Y axis as my heat bed holder has only a certain width cutout for the motor.
                I am all but a beer type but happy that you have something you enjoy. 🙂
                Manuel
                My Tool Collection
                • OBELIKSundefined
                  OBELIKS
                  If it's aluminum bed holder, just chop it.
                  • wilrikerundefined
                    wilriker @OBELIKS
                    @obeliks It is aluminium. Though, I have some concerns of messing with the statics of it if I chop it. But first I need to find out if it will be an issue after all. 😁
                    Manuel
                    My Tool Collection
                    • wilrikerundefined
                      wilriker
                      OK, I looked into the dxf file that is used to cut the bed holder and it has a clearance of 58mm for the Y motor. 46.8mm motor + 6mm damper leaves 5.2mm for the thickness of the motor holder (which I am not absolutely sure but I think is 3mm) and some clearance to compensate any amount of mounting skew... this will be tight... And as you can see on the image of the seller below there is not much room for removing further material without coming really close to some existing holes
                      heat bed holder
                      Manuel
                      My Tool Collection
                      • OBELIKSundefined
                        OBELIKS
                        Damper? I think those will not be needed.
                        As I said these are a lot quieter.
                        You should measure on the printer itself. Any other theoretical calculations will be off, by my experience.
                        • wilrikerundefined
                          wilriker @OBELIKS
                          @obeliks For the current motors the dampers make a huge difference especially for the Y motor. I feel a little hesitant to assume that the "long" silent motors are even more silent without the damper - and they would at least have to be equal in noise to the current setup. But still it is tempting. 😉 And 5dB are nearly 4-times louder/quieter (depending on reference).
                          I never measured the actual difference when adding the damper, though, except for listening at them.
                          And of course I will have to also measure on the printer itself to be sure about the cutout.
                          Manuel
                          My Tool Collection
                          • OBELIKSundefined
                            OBELIKS @wilriker
                            @wilriker A question regarding the dampers. Are they stiff enough not to introduce backlash?
                            • wilrikerundefined
                              wilriker @OBELIKS
                              @obeliks Actually I don't even know that. I guess so because they feel very stiff. But of course it introduces another elastic element besides the belt into the system. So it will at least add a very minimal amount of backlash.
                              Now that I think of it my ghosting problems with infill visible on the outside of a Benchy might be backlash issues...
                              Manuel
                              My Tool Collection
                              • OBELIKSundefined
                                OBELIKS
                                Do you have a picture of that Benchy?
                                • wilrikerundefined
                                  wilriker @OBELIKS
                                  @obeliks This is the best one I could find (and not a good one to be honest):
                                  Given this is actually printed on the original acrylic frame but sadly the aluminium frame did not improve in this very issue in any way.
                                  And this is not just visible because the filament is a tiny amount transparent but also you can feel it.
                                  EDIT: There already was belt tensioner in use and I used glass-fibre reinforced belts from the start - I never used the steel-reinforced belts that came with the A8.
                                  Manuel
                                  My Tool Collection
                                  • OBELIKSundefined
                                    OBELIKS
                                    This is not really ghosting, what value do you have for the perimeter/infill overlap?
                                    • wilrikerundefined
                                      wilriker @OBELIKS
                                      @obeliks I knew that this would come up. It's at 10%. And I am using 2 perimeters with 0.4mm each so a total wall thickness of 0.8mm.
                                      Manuel
                                      My Tool Collection
                                      • OBELIKSundefined
                                        OBELIKS
                                        😃 Haha
                                        IDK, usually these kind of issues are down to slicer, temperature, filament errors. But you probably checked those before.
                                        Just one more, is this PETG? I have seen something like that with it.
                                        • wilrikerundefined
                                          wilriker @OBELIKS
                                          @obeliks No it is PLA actually. But I see the same with PETG. That is one thing I have yet to get rid of - but maybe I need to try harder instead of all the time tinkering on the printer. 😂
                                          Regarding the filament I checked its width and AFAIR it had a little over-diameter but not enough to adjust anything. And temperature was determined by temperature tower.
                                          Manuel
                                          My Tool Collection
                                          • OBELIKSundefined
                                            OBELIKS
                                            You know what. Send me sliced file, I'll try it here. We will be able to definitely rule out slicers if it is all OK on my front.
