    Driver Fault?
    3.5k
    • Bobblejotundefined
      Bobblejot
      honestly i don't know, i only finished building up this printer with the new board today and started working through everything, and like i said everything else when i have connected them and tested has worked perfectly and first time. The only thing i have noticed is if i shut down and restart the printer then do G91 followed by G1 S2 X10 it moves up smoothly when i do this for Y the first time you can here it try but nothing happens, if i do it again you cant hear anything. On Z when i try it it doesn't do anything at all .
      So basically i am at a loss, was hoping to be printing this weekend as well 😞
        T3P3Tony administrators
        Yes looks like a replacement and diagnosis is the way to go. Roland will contact you directly to arrange sending out a replacement.
        Sorry to ruin your weekend printing plans, all the boards were tested on our test rig before sending them out so this is very puzzling.
          Just in case it's a power sequencing issue, please try starting up with just USB power applied, then apply 12 or 24V power and then try to get the motors to move. Every time the Firmware sees the main power appear, it will re initialise the motor drivers.
          Also please check that you have at least 11V on the Vin terminals. The drivers cut out if they consider the voltage is too low.
          What feed rate are you specifying in your G1 commands?
          Please also post your config.g file.
            Bobblejot
            For me to, plus there hasn't been any worrying smells and looking at the board there doesn't seem to be anything out of the ordinary, the PT100 daughter board and the IR sensor seem to work well though from what i can tell so thats a plus πŸ™‚
            I would be interested in finding out myself what the diagnosis uncovers, if thats possible. Normally its just clients industrial kit i blow up usually more careful with my own πŸ™‚
              Bobblejot
              Hi dc, i will check your suggestions in the morning and post a copy of my config, tidied everything away for tonight. I was using a conservative feedrate of 500.
              Thanks for all your help and suggestions and i will let you know how i get on in the morning.
                I will be out of contact for most of today. Hopefully Tony will see this thread and sort out a replacement board for you
                • Eddiieundefined
                  Eddiie
                  OH NO!! I have the same problem.
                  I upgraded from Duet to Duet Wifi and no motors will move. 3 LEDs are lit on the board for X Y Z, strange the one for the extruder is not.
                  Also using driver extender board. Those steppers aren't working either.
                  Everything was working on the Duet.
                  Running 1.15c firmware.
                  HELP!
                  Here is my current config.g
                  ; Configuration file for Mini Kossel kit from Think3DPrint3D for testing Duet WiFi
                  ; Communication and general
                  M111 S0                             	; Debug off
                  ;M550 PMiniKosselWiFiTest		; Machine name and Netbios name (can be anything you like)
                  M550 PMini Kossel		    ; Machine name and Netbios name (can be anything you like)
                  M551 Preprap                        	; Machine password (used for FTP)
                  ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
                  M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xEB 	; MAC Address
                  ;*** Wifi Networking
                  M552 S1				; Enable WiFi
                  M555 P2                           	; Set output to look like Marlin
                  M575 P1 B115200 S1			; Comms parameters for PanelDue
                  G21                                 	; Work in millimetres
                  G90                                	; Send absolute coordinates...
                  M83                                 	; ...but relative extruder moves
                  ; Axis and motor configuration
                  M569 P0 S1				; Drive 0 goes forwards
                  M569 P1 S1				; Drive 1 goes forwards
                  M569 P2 S1				; Drive 2 goes forwards
                  M569 P3 S0				; Drive 3 goes forwards
                  M569 P4 S0				; Drive 4 goes forwards
                  M569 P5 S0				; Drive 4 goes forwards
                  ;M350 X16 Y16 E16 I1    			; Set 16x microstepping with interpolation
                  M350 X128 Y128 Z128 E16 I1
                  M574 X2 Y2 Z2 S1			; set endstop configuration (all endstops at high end, active high)
                  M574 E S0							; set Extruder endstops to active low
                  M906 X800 Y1000 Z800 E800
                  ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration
                  ;M665 R113.50 L216.0 B85 H327.189
                  M665 R113.48 L216.0 B85 H327.330
                  M666 X0 Y0 Z0					; put your endstop adjustments here, or let auto calibration find them
                  ;M666 X-0.25 Y-0.25 Z0
                  ;M666 X3.50 Y-0.25 Z0
                  ;M906 X1000 Y1000 Z1000 E1000:1000:1000:1000:1000:1000 I60		; Set motor currents (mA) and increase idle current to 60%
                  M201 X1000 Y1000 Z1000 E1000		; Accelerations (mm/s^2)
                  M203 X20000 Y20000 Z20000 E3600		; Maximum speeds (mm/min)
                  M566 X1200 Y1200 Z1200 E1200		; Maximum instant speed changes mm/minute
                  ; Thermistors
                  M305 P0 T100000 B3950 R4700 H30 L0	; Put your own H and/or L values here to set the bed thermistor ADC correction
                  M305 P1 T100000 B3974 R4700 H30 L0	; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
                  ;M305 P2 T100000 B3974 R4700 H30 L0	; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
                  M570 S360				; Hot end may be a little slow to heat up so allow it 180 seconds
                  M106 P1 H-1 				; disable thermostatic mode for fan 1
                  ; Tool definitions
                  ;M563 P0 D0 H1                       	; Define tool 0
                  ;G10 P0 S0 R0                        	; Set tool 0 operating and standby temperatures
                  M563 P1 D1 H1                      ; Define tool 1
                  G10 P1 S0 R0                       ; Set tool 1 operating and standby temperatures
                  M563 P2 D2 H1						; Define tool 2
                  G10 P2 S0 R0
                  ;*** If you have a single-nozzle build, comment the next 2 lines
                  ;M563 P1 D1 H2                      	; Define tool 1
                  ;G10 P1 S0 R0                       	; Set tool 1 operating and standby temperatures
                  ;M92 E663:663                       	; Set extruder steps per mm
                  ;M92 X100 Y100 Z100				; Set axis steps/mm
                  ;M92 E97:97:97:97:97:97 	           ; Set extruder steps per mm explicitly for all the extruders - 6 for Duet085+Dt4 test (663)
                  M92 X100 Y100 Z100 E97:97:97:97:97:97:97				; Set axis steps/mm
                  ; Heater stuff
                  ;M307 H1 A163.2 C132.0 D7.4			; Set PID control for Heater1 - M307 H1 to view current settings
                  ;M307 H1 A163.2 C132.0 D7.4 B1       ; Use bang bang
                  ;M307 H0 A90 C700 D10
                  M307 H1 A198.0 C206.9 D9.9 B0        ; Set Hot end
                  M307 H0 A44.1 C346.6 D6.3 B0         ; Set Bed
                  ; Z probe and compensation definition
                  ;*** If you have a switch instead of an IR probe, change P1 to P4 in the following M558 command
                  ;M558 P1 X0 Y0 Z0			; Z probe is an IR probe and is not used for homing any axes
                  ;G31 X0 Y0 Z4.80 P500			; Set the zprobe height and threshold (put your own values here)
                  M558 P4 X0 Y0 Z0					; Z probe is a switch and is not used for homing any axes
                  G31 X0 Y0 Z12.5 P500				; Set the zprobe height and threshold (put your own values here)
                  ;*** If you are using axis compensation, put the figures in the following command
                  ;M556 S78 X0 Y0 Z0                   	; Axis compensation here
                  M208 S1 Z-0.2				; set minimum Z
                  T0					; select first hot end
                  Firmware Name: RepRapFirmware for Duet WiFi
                  Firmware Version: 1.15c (2016-09-05)
                  WiFi Server Version: 1.02
                  Web Interface Version: 1.12
                  • Dougal1957undefined
                    Dougal1957
                    @Eddiie:
                    HELP!
                    Which Driver Extender board are you talking about If you mean the DUEX4 then it is not compatible with the DuetWiFi Don't know what effect plugging one of them in may have?
                    Doug
                      Eddiie The Duex4 is definitely not compatible so unplug that at try again. Can you connect over the web interface? If so what happens when you home the axis?
                          Bobblejot
                          Morning,
                          So new day same outcome, went through everything again as below:
                          M584 returns:
                          Driver assignments: X0 Y1 Z2 E3:4:5:6:7:8:9
                          M906 returns:
                          Motor current (mA) - X:1000, Y:1000, Z:1000, E:800:800:800:800:800:800:800, idle factor 30%
                          M92 returns:
                          Steps/mm: X: 800.000, Y: 800.000, Z: 800.000, E: 417.000:417.000:420.000:420.000:420.000:420.000:420.000
                          Config.g
                          M111 S0                             	; Debug off
                          M550 PHex3D		; Machine name and Netbios name (can be anything you like)
                          M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED 	; MAC Address
                          M575 P1 B57600 S1			; Comms parameters for PanelDue
                          M569 P3 S1				; Drive 3 goes forwards
                          M569 P4 S1				; Drive 4 goes forwards
                          M665 R140 L290.8 B132.5 H340		; set delta radius, diagonal rod length, printable radius and homed height
                          ; M350 X16 Y16 E16 I1    		; Set 16x microstepping with interpolation
                          ; M92 X80 Y80 Z80			; Set axis steps/mm
                          M350 X64 Y64 Z64 E16 I0 		; Configure microstepping without interpolation
                          M92 X800 Y800 Z800	 		; Set steps per mm
                          M906 X1000 Y1000 Z1000 E800 I30		; Set motor currents (mA) and increase idle current to 60%
                          M84 S30 				; Set idle timeout
                          ; Thermistors
                          M305 P0 T100000 B3950 R4700 H0 L0	; Put your own H and/or L values here to set the bed thermistor ADC correction
                          ; M305 P1 T100000 B3974 R4700 H30 L0	; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
                          M305 P1 X200				; Modified for PT100 first nozzle thermistor
                          M570 S180				; Hot end may be a little slow to heat up so allow it 180 seconds
                          ; Tool definitions
                          ; M92 E663:663                       	; Set extruder steps per mm
                          M92 E417:417                       	; Set extruder steps per mm for E3D Titan
                          Vin Voltage = 24.02 vdc
                          Powered off the board and powered up solely on usb power, waited a few minutes and turned on 24v supply. Tried the motors again with the same results, X is ok Y & Z don’t move at all 😞
                          Firmware Name:
                          Firmware Version:
                          1.15b (2016-08-25)
                          1.02
                          1.12
                          Is there anything else i can try?
                            Bobblejot
                            Just updated Firmware to 1.15c for the sake of it but still the same, on the plus side the new firmware update process is very nice.
                              I think the best bet is for us to send you a replacement and you send that one back for diagnosis. I have emailed you directly.
                                Bobblejot
                                Hi Tony, thanks for that just seen your email and replied.
                                • Eddiieundefined
                                  Eddiie
                                  @T3P3Tony:
                                  I unplugged the board and the steppers home now.
                                  How was I to know they were not compatible?
                                  • curieosundefined
                                    curieos
                                    https://duet3d.com/wiki/Pre-production_hardware_limitations_and_known_firmware_issues
                                    This page, as well as a few other places on the forum/Wiki.
                                    She/Her
                                    I work at a local 3D printing shop.
                                    Printers: Micron+ w/Duet 3 Mini, in-progress adaptation of the Jubilee REL onto an E3D MS, Prusa i3 MK3S.
