Duet Wifi keeps wrecking my printer, not happy!
71
7.6k
    Danal @SplatHammer
    @splathammer said in Duet Wifi keeps wrecking my printer, not happy!:
    @deckingman No, as I said nothing custom just the output of the online configuration program. My gcode and mcode knowledge is precisely 0 at the moment so I had to rely on the online tool. if it isnt default in the original software or in the output of the configuration tool its not on my machine.
    M500 on RAMPS writes some stuff to EEPROM. M500 on Duet writes some stuff to "/sys/config_override.g". So your past ramps knowledge may have caused you to enter a command that created that file without you realizing it...
    Take a look, in the "system editor" and see if config_override.g is present or not.
      deckingman @SplatHammer
      @splathammer Yes I feel you pain. By the way, I have no affiliation with Duet - I'm just a user like you (although it's fair to say that I am a huge fan of the product).
      I think you've been unlucky that's all. There are a lot of users who get the board and it works out of the box. Of course it may seem like there are a lot of users with problems on these forums but those who don't have problems don't bother to post. Or if they do post, it's just a one off question in the majority of cases. Hang on in there if you can. Things are moving in the right direction. We'll get to the bottom of it between us and you'll end up a happy bunny.
      undefined 2 Replies Last reply 1 Sept 2018, 07:51 Reply Quote 1
        SplatHammer @deckingman
        @deckingman I do really like the board or I wouldnt still be trying to get it working properly!
        I have a question, is there a command which will create a running log which will constantly write to file? Like last time I will be watching todays print like a hawk ready to pull the plug if there is a problem so I need to know if there is a way of logging which wont be lost when the board looses power and which will have the last few commands saved.
          @deckingman By the way thanks for all the help, you have spent so much time on this I did actually think you worked for them!
          One thing that would help is if the temperature here dropped, its been 37C - 42C in the shade here for a couple of months and it is getting pretty tiring, especially as sleep is really difficult. of course 2 of our 3 aircons decided to pack up in the first couple of weeks and as they are mounted way up on our 3 storey house I need to hire a cherry picker to put in new ones which will have to wait until autumn. The heat makes thinking hard and frustration/anger easy!
          undefined 1 Reply Last reply 1 Sept 2018, 08:42 Reply Quote 0
            @splathammer I'm no expert on logging - DC42 is the man. I'd imagine that constantly writing to say the SD card would bugger things up, and there is also limited memory available to hold a log file. The only thing do know is that M122 reports a load of stuff which must have been logged. So running that command after things go pear shaped and reporting back what it shows would help people like DC42 diagnose what's happening.
            For info - DC42 writes the firmware and his company is one half of Duet. Tony and Roland are the other half of Duet. The rest of us are all just users (plus a couple of distributors) trying to help each other.
            Yes, sleep deprivation is a killer. Every Mole hill becomes a mountain.โ˜บ
            undefined 2 Replies Last reply 2 Sept 2018, 16:24 Reply Quote 0
              streamliner
              @deckingman Hey Ian, I hope you're well! I've had to go a bit dark on the forums and email lately due to our multiple impending launches. Just skimmed over this and I wanted to indicate one thing about logging. Logging, similar to the way most software systems/operating systems handle it, is done at prescribed 'levels' on the duet.
              If you send an M111 you'll get a list of modules; On a Duet Maestro, this is what I am provided:
              M111
              Debugging enabled for modules: none(15)
              Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) WiFi(14)
              While enabling all of the modules will most certainly fill your sdcard quickly, my recent troubleshooting has really only utilized Platform and Move; and with intense testing my Log file is only a few kb in size. I personally will likely keep my 'Platform' logging set to on no matter what.
              I don't suppose your schedule is open today for a bit of a chat, is it? I wanted to discuss some firmware retract stuff with you, as well as some recent slicing milestones. ๐Ÿ˜ƒ
              Thanks,
              David@M3D
              undefined 1 Reply Last reply 1 Sept 2018, 13:43 Reply Quote 0
                MortarArt
                This is a massive long shot, but I have seen a printer (not a Duet) execute a downwards move, when instructed in gcode to move slightly up. In fact it's even repeatable. My Mendel Max 3, using a RAMBO will do the following:
                Home all routine:
                Home X
                Home Y
                Move Z up 10
                Move XY to center of bed
                Move Z down until probe reports
                Move Z up 1
                ... any intervening commands are irrelevant, unless Z shifts up or down.
                Manual 'move Z up' less than 9 will result in a downward movement.
                For example, Manual 'move z up 1' will result in moving Z down 8 ... a crash of about 6mm. Which isn't fun.
                  deckingman @streamliner
                  @streamliner said in Duet Wifi keeps wrecking my printer, not happy!:
                  Thanks,
                  David@M3D
                  I'm hardly ever in a position where I can just drop everything and have a chat but you can always email me. Of course, I can only discuss what works (or doesn't work) with a 5 colour Diamond mixing hot end. It may or may not read across to the quad.
                    @deckingman Just tried to update the firmware. Note the use of the word "TRIED". It detected I had uploaded the combined firmware file, asked if I wanted to install it then said it couldnt find it. Tried it multiple times, tried putting "-2.01" after the name and it said it couldnt rename it. Tried to do the upload all at once install variation and it instantly upgraded the web control without asking. Took out the sd card, deleted the firmware then tried again, same crap about not being able to find the file. So it detected the file had been uploaded, knew what it was but says it cant find it, wow impressive!
                    I am not going to try one of the "fallback" installation methods, I am going to try printing a scaled down version of my last print attempt and see what happens.
                    I did check the sd card and its ok.
                    I belong to the local pistol shooting club and if i have many more problems with this thing it is going to make a very nice if rather expensive target ; )
                    undefined 1 Reply Last reply 2 Sept 2018, 16:30 Reply Quote 0
                      fcwilt @SplatHammer
                      @splathammer
                      What version were you updating from and to?
                      Certain combos require specific procedures.
                      Aside from those few special cases I have found updating to be reliable and that is on all four of my printers.
                      undefined 1 Reply Last reply 2 Sept 2018, 16:42 Reply Quote 0
                        @deckingman I just got it to install! I suddenly noticed the error message said it couldnt find "DuetWiFiFirmware.bin" and the file is named Duet2CombinediFirmware.bin on github AND in the installation instructions. What a load of CยทยทP!
                        undefined undefined 2 Replies Last reply 2 Sept 2018, 18:00 Reply Quote 0
                          SplatHammer @fcwilt
                          @fcwilt Just got it to install, the error message I got listed a different name than the name of the file you download from github. I renamed it to the name in the error message and it installed and is running. It was 1.9 to 2.01
                          The download is Duet2CombinedFirmware.bin but it has to be renamed to DuetWiFiFirmware.bin
                          Would be nice if they included that in the ยทยทยทยทยทยทยท instructions!
                          undefined 1 Reply Last reply 2 Sept 2018, 18:06 Reply Quote 0
                            Hi. Sorry I've been busy all day otherwise I would have stepped in earlier and saved you some grief. I see you've got it sorted and from now on, you'll be able to use the combined firmware without any problems. It changed around 1.21. It is documented here and in the release notes https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Upgrading_a_Duet_WiFi_or_Ethernet_to_firmware_1_21_or_later_from_1_20_or_earlier.
                            I've been caught out myself before when upgrading firmware and I've now learned to always read the release notes which you can find here. https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md
                            Suggest you bookmark that link and refer to it whenever you upgrade the firmware.
                            I'll save you some time with the next thing you are going to run into which is that you can't jog or move axes until they are homed, and when you try you'll get an error message "insufficient axes homed". It's in the release notes and was introduced as a user request. There are a couple of ways around it. The easiest IMO is to add M564 H0 to config.g which will restore the old behaviour. If not and if you try to home X or Y and those homing macros have a Z move in them, you'll need to add S2 to those Z moves.
                            It is all in the release notes.
                            Cheers
                            undefined 1 Reply Last reply 2 Sept 2018, 20:31 Reply Quote 0
                              fcwilt @SplatHammer
                              Glad to hear you got it working.
                              As you see that was one of the combos that needed special handling as mentioned in Duet doc section on firmware upgrading.
                              A problem I faced as well.
                                @deckingman I have just tried to print another item - a 1/2 scale version (resliced and with an new version of Slic3r) and it has just done the same thing - it hit the top right corner, went to move to the next position) and rammed the hotend into the bed and dragged it along. this thing is a piece of non consumer grade , pre-alpha buggy crap and I have had enough. I am going to send the piece of excrement back and demand a refund. They are lucky I dont sue for a replacement hotend and nozzles, I would if it wasnt for the fact that for setup purposes I used cheap chinese copies and hadnt used the real E3D ones I have.
                                Here are some pics of the whole show.
                                Thank you so much for all your help, you have been incredibly kind and generous with your time. Hopefully we will meet again another forum on a happier thread!
                                undefined undefined 2 Replies Last reply 2 Sept 2018, 20:34 Reply Quote 0
                                  SplatHammer @SplatHammer
                                  I
                                  By the way, the first pic was from before all the upgrades, the other 2 are form this print. The report showed no anomalies.
                                    SplatHammer @dc42
                                    @dc42 I have upgraded all software and firmware, checked SD card, re-calibrated everything and just tried to print a newly sliced (with a new version of Slic3r) and had exactly the same crash I have had so many times before. I will be contacting you for a refund, returning this board and replacing it with something that doesn't repeatedly damage my very expensive printer.
                                      @splathammer Man, I don't know what to say (except that maybe if I had been unlucky enough to experience the problems you have that I'd likely feel the same way). Did the crash happen on layer change or at some random point in the file.?
                                      If you can make the gcode file that were trying to print available, I'll give it a go on my machine if it helps. It would eliminate anything to do with slicer settings.
                                      undefined 2 Replies Last reply 2 Sept 2018, 22:25 Reply Quote 0
                                        fcwilt
                                        It's too bad you have having a unsatisfactory experience.
                                        But given all the folks who don't have your problems and given the history of problems like this either your board is defective or you have done something wrong in wiring/configuration/etc.
                                        undefined 1 Reply Last reply 2 Sept 2018, 22:10 Reply Quote 0
                                          SplatHammer @fcwilt
                                          @fcwilt I would love to hear how it can print the first layer perfectly (or at least part of it) and then do a kamikaze dive into the bed and it be my fault, either in configuration or wiring! It homes z perfectly and I have tried it a hundred times, lowers the bed when homes each axis, positions the bed correctly to print the first layer then does the suicide job after a random interval. by the way I am an engineer and also have a comp sci degree, worked in R&D (hardware) in the telecoms industry for years then worked as a consulting engineer and project manager on major telecoms installations from Australia to Turkey and Europe , started playing with computers in 1975 and am an electronics and robotics hobbyist so I am not exactly a tech newbie. The thing is everything works perfectly until x point in the print, usually part way through the first layer, then BANG. I have tried process of elimination and there is nothing left! Maybe the board is defective but as I desperately need to start using the printer I think I am going to go for something basic that works. I have been trying to get this going for 2 months in my spare time and am now out of time. My 2 ramps based small printers worked first time and have not had a single problem ever. this has NEVER worked.
                                          undefined 1 Reply Last reply 2 Sept 2018, 23:04 Reply Quote 0
                                          34 out of 71
