    Temperature safety checks
    16
    2.7k
      A few notes on posts above.
      • as Doug says, you can use M562 H# to clear a fault on heater number #
      • PanelDue displays the temperature in white on magenta if the heater is in the fault state
      • in the next release I will change it to pause or abandon the print when a heater fault occurs
        T3P3Tony administrators
        Hi James
        As Ian has said all channels on the board start numbering from 0 so when remapping drives (for example to use external drivers):
        1st drive = D0 (mapped to X axis by default)
        2nd drive = D1 etc
        1st heater = H0 (bed heater connection)
        2nd heater = H1 (1st extruder, E0 connection)
        3rd heater = H2 (2nd extruder, E1 connection)
        When defining a tool the drives ignore the XY and Z axis and start numbering from the extruders :
        0= first extruder drive
        Etc
        The details are in the documentation here
        https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer#Heater_and_thermistor_section
          deckingman
          Good tip about M562 - thanks guys.
          • peridotundefined
            peridot
            Maybe this is paranoia, but if thermal misbehaviour is detected, doesn't it make sense to shut down all heating and movement, and in fact use PS_ON to shut down the whole high-voltage end of things?
            I'm thinking of, for example, a situation where a heater MOSFET fails shorted: this shows up as an unexpected rise in temperature on the corresponding thermistor, detectable as a rising temperature in spite of the heater being nominally off, so the firmware knows something is wrong. Setting the PWM to zero won't do anything, since the MOSFET is shorted, but shutting down the 12/24V supply would prevent a fire.
            Of course, many people don't use the PS_ON pin - I do mostly because I have an ATX - but a separate 5V supply and a relay seem like a reasonable safety measure.
            • botundefined
              bot
              Maybe we could initiate a customized sequence, perhaps like a "fault.g" file that executes when a fault condition is encountered.
              *not actually a robot
                Smoothieware does an emergency stop on a heating fault, including turning the power off if possible. I'm considering implementing the same in RRF.
                I think it would be fairly simple to use the PS_ON output to control a SSR that controls the mains supply to the PSU.
                • botundefined
                  bot
                  Would there be any way to dump info of the current state before shutdown? Maybe XYZ(E) coordinates at the moment of fault, etc.
                  • peridotundefined
                    peridot
                    If it helps, Marlin also responds to non-approved thermal behaviour by shutting down everything including the main power. Perhaps it would make sense to have a detailed case-by-case test along the lines of: https://github.com/MarlinFirmware/Marlin/issues/2066 ?
                    I realize our 3D printers are too wimpy for their motion to be a hazard to life and limb, but it might still make sense to have a Big Red Button that also triggers a fairly thorough shutdown, say if the user notices unintended flames. But that might be best handled with a simple switch on the mains input.
                    clefranc created this issue in MarlinFirmware/Marlin
                    closed Thermistors malfunction tests results #2066
                    • jamesarm97undefined
                      jamesarm97
                      Ok, finally have the board connected and the temperature checks seem to work better now. I actually had an open in one of the extruder wires and it did the no rise alarm.
                      I did notice something with the bed temperature and don't know what it causing it. The gcode sets the bed to 55c then sets the extruder temp but after some time the bed acts like it stops heating. I get no alarms on the paneldue console or through the web console. The Active temperature shows the correct temperature (55) but the bed is showing around 33c and the light on the SSR is not on anymore.
                        What does DWC say the state of the bed is when it stops heating: off, or fault?
