    Movement without Homing
    4.5k
    • SnowCrashundefined
      SnowCrash
      I seem to remember reading somewhere about the possibility of manually overriding the precondition of 'homing' for moving the effector.
      However, I couldn't find the right command in the Duet's gcode list or the forum.
      Could someone please remind me how this could be done?
      Thanks!
      SnowCrash
      ps I have a Delta if it makes a difference.
        M564 H0
        https://duet3d.dozuki.com/Wiki/GCode#Section_M564_Limit_axes
        SnowCrashundefined 1 Reply Last reply Reply Quote 1
          SnowCrash @Phaedrux
          Thanks, @phaedrux 🙂
            That command does not apply to delta printers. Normal movement on a delta can only be done after homing.
            You can do individual motor moves before homing using G1 S2 moves. See the wiki page on configuring RRF for a delta printer.
            SnowCrashundefined 1 Reply Last reply Reply Quote 0
              SnowCrash @dc42
              Thanks for the clarification & pointer, @dc42.
              I read the relevant doc and I think I'll use G1 S1 as I'd like the endstops to be sensed and stop the axis movement at the top limit - is this correct?
              Also, am I correct in understanding that S1 means 'moving with endstop sensing' and S2 means 'moving without endstop sensing'?
              Lastly, as I'm going to use the S parameter, there's no need to use G90 & G91 for this operation, right?
                That's all correct, except that you need to put a delta printer into relative mode (G91) before it will accept G1 S1 and G1 S2 moves.
                  SnowCrash @dc42
                  Got it, thanks @dc42!
