    Starting Print in mid air???
    1.7k
    • vernon1xxundefined
      vernon1xx
      I am having an issue with slicing. The starting G-code I am using may be faulty. The printer homes well and moves to begin the print. However, it will not lower itself to the bed. Instead it begins the print in mid-air about 10mm of the bed. I have tried several iterations of starting code but alas no luck. In the latest I inserted several Z0 variations (no luck) and M565 Z-.945. Can anyone direct me and provide me with instruction to move forward?? Here is the latest Cura Starting code I have tried (below).
      G21 ;metric values
      G91 ;Relative positioning
      G1 Z-1 ;Move Z down 1mm
      G90 ;absolute positioning
      M82 ;set extruder to absolute mode
      M107 ;start with the fan off
      G28 X0 Y0 ;Home XY
      M561 ;Clear any bed transform
      G1 X345 Y565 ;Move probe to center of bed
      G32 ;Start 2-point probe sequence
      G29 S1 ;Load height map
      G1 Z20.0 ; Move Z to 20
      M565 Z-.945 ;Set Z offset
      G92 E0 ;zero the extruded length
      G1 F200 E3 ;extrude 3mm of feed stock
      G92 E0 ;zero the extruded length again
        Phaedrux Moderator @vernon1xx
        @vernon1xx I don't see you homing Z in there anywhere. But you are moving it around a lot.
        I don't think M565 is a valid gcode for reprap. Did you mean something else?
        How are you homing your printer?
          vernon1xx
          Thank you for your reply! I have tried numerous iterations!!!!! The M565 was just one of many to get Z to zer0 (0). I will modify to the following, changing line 7 to G28: "home all". Line 10 to G30: "single probe". Remove line 14 that references M565. Thoughts???
          G21 ;metric values
          G28 ;Home XYZ
          G30
            Well let's start at the beginning.
            Can you post your config.g and homing files?
            How are you homing Z? Z Probe? What kind? Have you measured the trigger height?
            After you home z, what happens if you try and move the head manually to Z0? Are you right touching the bed?
            If you disabled all bed compensation does it work better or worse? You may need to redo your mechanical bed level, and recalibrate your trigger height, and run G29 again to generate a new heightmap.
            • punamenonundefined
              punamenon
              Your start code seems overly complicated. Most worrisome to me is why are you setting your Z offset at the beginning of every print? This should be set with G31 "trigger value" in config.g.
              I showed how to do it in the video here: https://youtu.be/BgkJVgFnPaE?t=21m47s
              Once that is set correctly, you should be able to use a very simple start script. Mine is this:
              G28 ;Home All
              G29 S1 ; Load old Bed Map -- remove the S1 to build a new bed height map
              G0 X0 Y0 Z5 ; Move print head to front left corner 5mm off the print surface in preparation for printing
              G92 E0 ; Set the extruder to zero
              G1 E8 ; prime the nozzle
                vernon1xx
                I only tried that version of start code once after many others. I really appreciate the assistance!!! I will post my config files and associated info ASAP!
                  vernon1xx
                  Please find attached my config.g, and homing files. I am using a BLtouch to home Z. I configured the Z-probe offset in the config.g by moving the nozzle to the bed and entering G92 Z0. I then went to the G-code console and entered the command G30 S-1. The result was stopped at height of 0.974 the first time and 0.976 the second and so on. I updated the Z-probe trigger height to 0.97. I am able to home Z and actuate to the table. It allows me to move no farther than that. Thank you for the help, please let me know if I need to change anything or post additional files/info. I will view the video and try to disable all bed compensation.
                  Config.g ☺
                  M550 PMy printer ; Set machine name
                  M552 S1 ; Enable network
                  ;*** Access point is configured manually via M587
                  M586 P0 S1 ; Enable HTTP
                  M586 P1 S0 ; Disable FTP
                  M586 P2 S0 ; Disable Telnet
                  M569 P0 S0 ; Drive 0 goes backwards x
                  M569 P1 S1 ; Drive 1 goes forwards y1
                  M569 P2 S1 ; Drive 2 goes forwards z1
                  M569 P3 S0 ; Drive 3 goes backwards y2
                  M569 P4 S1 ; Drive 4 goes forwards z2
                  M569 P5 S1 ; Drive 5 goes forwards E0
                  M569 P9 S1 ; Drive 9 goes forwards E1
                  M584 X0 Y1:3 Z2:4 E5:9 ; Define X, Y, Z, E drives
                  M350 X16 Y16:16 Z16:16 E16:16 I1 ; Configure microstepping with interpolation
                  M92 X100 Y100:100 Z3200:3200 E400:400 ; Set steps per mm
                  M566 X900 Y900:900 Z12:12 E120:120 ; Set maximum instantaneous speed changes (mm/min)
                  M203 X12000 Y12000:12000 Z180:180 E3000:3000 ; Set maximum speeds (mm/min)
                  M201 X500 Y500:500 Z250:250 E250:250 ; Set accelerations (mm/s^2)
                  M906 X800 Y800:800 Z2800:2800 E800:800 I30 ; Set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  M208 X690 Y1130 Z1000 S0 ; Set axis maxima
                  M574 X1 Y1 S0 ; Set active Low endstops
                  M574 Z1 S2 ; Set endstops controlled by probe
                  M307 H7 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                  M558 P5 H5 F500 T4000 X0 Y0 Z1 ; Set Z probe type to bltouch and the dive height + speeds
                  G31 P25 X35 Y-25 Z0.97 ; Set Z probe trigger value, offset and trigger height
                  M557 X15:650 Y15:1100 S50 ; Define mesh grid
                  M671 X345:345 Y-150:1230 S3 ; Leadscrew Coordinates for G32
                  ;Bed Zone 5,6
                  M143 H0 S85 ; Set temperature limit for heater 0 to 85C Bed, heat zones 5,6
                  M307 H0 A28.2 C78.3 D10 S1.0 B0
                  ;Extruder 0
                  M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                  M143 H1 S240 ; Set temperature limit for heater 1 to 240C E0
                  M307 H1 A177.4 C115.6 D8.1 S0.5 B0
                  ;Extruder 1
                  M305 P2 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 2
                  M143 H2 S240 ; Set temperature limit for heater 2 to 280C E1
                  M307 H2 A288.7 C190.4 D5.6 S0.5 B0
                  ;Bed Zone 1
                  M305 P3 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 3
                  M143 H3 S85 ; Set temperature limit for heater 0 to 85C Bed, heat zone 1
                  M307 H3 A27.7 C69.3 D10 S1.0 B0
                  ;Bed Zone 2
                  M305 P4 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 4
                  M143 H4 S85 ; Set temperature limit for heater 4 to 85C Bed, heat zone 2
                  M307 H4 A21.8 C65.8 D10 S1.0 B0
                  ;Bed Zone 3
                  M305 P5 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 5
                  M143 H5 S85 ; Set temperature limit for heater 5 to 85C Bed, heat zone 3
                  M307 H5 A21.1 C53.1 D10 S1.0 B0
                  ;Bed Zone 4
                  M305 P6 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 6
                  M143 H6 S85 ; Set temperature limit for heater 6 to 85C Bed, heat zone 4
                  M307 H6 A21.1 C45.6 D10 S1.0 B0
                  M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                  M106 P1 S1 I0 F500 H1:2 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  M106 P2 S1 I0 F500 H1:2 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  M563 P0 D0 H1 ; Define tool 0
                  M563 P1 D1 H2 ; Define tool 1
                  G10 P1 X-65 Y0 Z0 ; Set tool 1 axis offsets
                  G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
                  M563 P2 H3 ; Define tool 2
                  G10 P2 R70 S70 ; Set initial tool 2 active and standby temperatures to 0C
                  M563 P3 H4 ; Define tool 3
                  G10 P3 R70 S70 ; Set initial tool 3 active and standby temperatures to 0C
                  M563 P4 H5 ; Define tool 4
                  G10 P4 R70 S70 ; Set initial tool 4 active and standby temperatures to 0C
                  M563 P5 H6 ; Define tool 5
                  G10 P5 R70 S70 ; Set initial tool 5 active and standby temperatures to 0C
                  ; homex.g ☺
                  ; called to home the X axis
                  ; generated by RepRapFirmware Configuration Tool on Fri Jul 20 2018 18:58:43 GMT-0700 (Pacific Daylight Time)
                  G91 ; relative positioning
                  M98 Pdeployprobe.g ; deploy mechanical Z probe
                  G1 X-690 F1800 S1 ; move quickly to X axis endstop and stop there (first pass)
                  G1 X5 F6000 ; go back a few mm
                  G1 X-870 F360 S1 ; move slowly to X axis endstop once more (second pass)
                  M98 Pretractprobe.g ; retract the mechanical Z probe
                  G1 Z-5 F6000 S2 ; lower Z again
                  G90 ; absolute positioning
                  ; homey.g ☺
                  ; called to home the Y axis
                  G1 S1 Y-1130 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                  G1 Y5 F6000 ; go back a few mm
                  G1 S1 Y-1130 F360 ; move slowly to Y axis endstop once more (second pass)
                  ; homez.g ☺
                  ; called to home the Z axis
                  G1 X345 Y565 F6000 ; go to first probe point center of bed and home Z
                  G1 Z5 F100 S2 ; lift Z relative to current position
                  ; homeall.g ☺
                  ; called to home all axes
                  G1 S1 X-690 Y-1130 F1800 ; move quickly to X, Y and U axis endstops and stop there (first pass)
                  G1 X5 Y5 U5 F6000 ; go back a few mm
                  G1 S1 X-690 Y-1130 F360 ; move slowly to X and Y axis endstops once more (second pass)
                  G1 X345 Y565 F6000 ; go to first bed probe point and home Z
                  G1 Z5 F100 S2 ; uncomment this line to lift the nozzle after homing
                  M98 Pretractprobe.g ; retract mechanical Z probe
                  • fcwiltundefined
                    fcwilt
                    Well first simple question.
                    When you move Z down to 0 is the tip of the nozzle almost touching the bed?
                    I configure my printer for a gap of 0.05mm.
                      Ok good, it sounds like you have measured the probe trigger height properly.
                      Next question, what firmware version are you using?
                      If you're using a version 1.21 or newer, you can use M558 P9 instead of M558 P5 for the BLTouch, this will let the system control deploying and retracting automatically when G30 is called, so you don't have to do it manually anymore. Also in the latest 2.0 versions there are a few changes to the handling of the BLTouch to make it a bit more responsive to triggering.
                      But otherwise, if your BLTouch is working properly it looks like it is configured properly in your config.g.
                      In your homex it looks like you're deploying and retracting the z probe. Not sure why.
                      Your other homing files look ok.
                      As for your start script, you have the option of also loading the mesh compensation map at startup rather than right before the print.
                      Can you post a picture of what your heightmap looks like? It's possible that something is really off on the heightmap and so it;s trying to compensate for an error.
                        You may want to rerun the G30 S-1 test several times so that you get a better average value for the trigger height. It can take a while for the probe to setting in sometimes.
                        You may also want to add a few values to the M558 command to help eliminate some bltouch problems.
                        M558 P9 H3 F100 T6000 A5 R0.2 S0.01 B1
                        A5 S0.01 tells it to probe up to 5 times if it doesn't get two results to within 0.01 of each other. And B1 turns off any heaters while probing to eliminate any possible wiring interference.
                        Also, can you post the first 50 lines or so of a sliced gcode file that exhibits the problem? It would be helpful to see what the printer is actually being commanded to do.
                          vernon1xx
                          Firmware Name:
                          Firmware version:
                          RepRapFirmware for Duet 2 WiFi/Ethernet
                          Firmware Electronics:
                          Duet WiFi 1.02 or later + DueX5
                          Firmware Version:
                          1.21 (2018-03-21)
                          WiFi Server Version:
                          1.21RC4(08b3)
                          Web Interface Version:
                          1.21-RC4
                            vernon1xx
                            I will make the changes, and post accordingly. Thank you!!!!!
                              You should probably upgrade to the latest 1.21.x or 2.x releases for all your firmware as there were a few bug fixes that may be affecting you. You're also on release candidates and it's a good idea to upgrade to the full release once it's out.
                              https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md
                              Namely from 1.21.1
                              If G30 was used to set an accurate Z height after mesh bed probing or loading a height map, if bed compensation was then cancelled then any Z offset from the height map remained. One consequence of this was that if bed probing was run again, the original height map Z offset was carried through to the new one, but the sign of the offset was reversed.
                              https://github.com/dc42/RepRapFirmware/releases
