    Creality CR-10 upgrade
    252
    53.9k
    • Agniusmundefined
      Agniusm
      DC42, is there a way to set duet port othe than 80? I see it was possible with older releases. Having no option on mobile device to upload gcode files i got couple router and ubiquiti is using 80 for web interface so i need something else on duet for port forwarfing
      • Agniusmundefined
        Agniusm
        I would also strongly request adding upload option from modile devices.
          dc42 administrators @Agniusm
          @agniusm said in Creality CR-10 upgrade:
          See the description of the M586 command in the GCodes wiki page.
            Please make that request in the DWC Wishlist section.
            • Agniusmundefined
              Agniusm
              So my upgraded printer is working 24/7 great. Had a fan failure but that was to be expected with cheap chinese stuff. Got a small issue i was putting off for some time. i have mesh compensation in place and it works great but i have my front off the bed not completely working with this.
              Here is 2 same run parts, one from the middle of the bed(rest are same good) and one from the front (on the right). The nozzle is a tad off when printing on the front of the bed:
              I was wandering where i should look for the issue? I know my grid is set wrong as it misses some points(skips them). Would that cause an issue?
              Otherwise i am very happy with Duet hardware and the way i can edit my configs on the fly, i can really appreciate that now since i am working on Marlin firmware for my budget cluster.
              P.S. perhaps the tool to calculate mesh grid appeared for square build plates? That would be handy. or is there any plans on automatic calculation of the mesh? Say you enter how many grid points on x and y and it sets spacing? Would be even better. i think Marlin does that
                Any probe points that cannot be reached by the probe (taking into account the machine limits set by M208 and the Z probe offsets set by the G31 X and Y parameters) will be skipped.
                Good idea, I'll add it to the work list.
                • Agniusmundefined
                  Agniusm
                  David, we were brainstorming a method for e3d toolchange and how we can automate tool offsets for different tools. Perhaps you have a solution but i got an idea i would like to test as it is relevant to me too.
                  I want to mount precision piezo disc on my frame where my extruder can reach and probe it to set the height of the nozzle then use inductive probe for mesh mapping. This way, each time i swap the nozzle, i dont have to readjust z offset as even quarter turn of the nozzle throws calibration away.
                  How can i implement this in duet settings?
                  tjb1undefined 1 Reply Last reply Reply Quote 0
                    Have you looked at https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M585_Probe_Tool ?
                    • Agniusmundefined
                      Agniusm
                      Actually just yesterday was going through gcode wiki and saw this one. I will investigate.
                      • tjb1undefined
                        tjb1 @Agniusm
                        Are you using E3D hotends? The nozzle should tighten against the heat break so provided the nozzles are all the same length from end to tip, they should all tighten to the same distance.
                        Agniusmundefined 1 Reply Last reply Reply Quote 0
                        • Agniusmundefined
                          Agniusm @tjb1
                          @tjb1 Yes. Using e3d. Even if so printing different materials can have impact(thermal expansion) PLA vs PC can be 100C difference. This idea came thinking about e3d toolchanger. I was not specifically wanting to do this on my machine, but I had precision piezo kit and thought I will test the idea. Actually it will be handy if it works the way I think. Sometimes I need to change a fan and it is mounted with induction probe. Even if I do not touch induction probe out of the clamp it still needs recalibration.
                          @dc42 I want to place my probe slightly below my bed so it is out of the way. So my macro should look something like this:
                          G28 ; home
                          G10 P0 Z0 ; clear Z offset
                          T0 ; select a tool
                          G1 X430 Y0 Z10 F3000 ; move above probe
                          M585 Z F400 E2(cant remember which is asignet to z stop(2?) and which to z probe) ; drive into probe
                          M500 ; save new offset
                          G1 Z20 ; lift the tool not to drive into bed edge
                          G28
                          M98 Pmeshbed.g
                          One thing I'm not sure about how to add extra distance if my probe is say 10mm below my bed.
                            You could use G1 to move the nozzle to be above the switch at Z=5. Then send G92 Z15 to pretend it is at Z=15. Use the M585 command to probe the switch. Then do G1 Z15 followed by G92 Z5 to remove the 10mm Z offset.
                            • Agniusmundefined
                              Agniusm @dc42
                              @dc42 thanks. A work around then 🙂
                              How should i set my probe in M585 E if i connect my probe to Z probe 4 pin connector near paneldue connector? My stop endstops are all pupulated.
                                I suggest you use one of the endstop inputs on the CONN_LCD connector.
                                • Agniusmundefined
                                  Agniusm @dc42
                                  @dc42 Good note. Had no clue there were extra inputs. So i can take +3.3V, gnd and say stop 11(ENC_A) and in M585 E11? This is for precision piezo
                                  • Agniusmundefined
                                    Agniusm
                                    Do i need to define precision piezo in config.g? At the moment i have my induction probe:
                                    M558 P4 I0 F300 X0 Y0 Z1 T7000 ;
                                    should i need to add:
                                    M558 P1 I0 R0.4 F300 X0 Y0 Z0 ; Set precision piezo probe
                                    • Agniusmundefined
                                      Agniusm
                                      I getting an error of missing command, M501 in config.g.
                                      "Set the active parameters to those stored in sys/config-override.g on the SD card. This command should be included near the end of the config.g file so that the stored parameters will be loaded at startup. It can also be used to revert parameters to the values stored in config-override.g after experimenting with them."
                                      I am not really grasping on what it does.
                                        The purpose of config-override.g is to replicate some of the behaviour of EEPROM in 8-bit firmwares. You don't really need that facility in RRF because it's so easy to edit config.g to save settings that you want restored every time you power up the printer; but that doesn't stop users asking for the feature, and In a few situations it is genuinely useful. But if it confuses you, just remove or comment out the M501 command at or near the end of config.g, then don't expect M500 to save any settings.
                                        • Agniusmundefined
                                          Agniusm
                                          But i cant cancel it out as it is required by M585.
                                          So the question then is, does M585 write offset to override file and then load that offset from there?
                                          Also its unclear how that endstop needs to be set up. Does it needs to be set in config.g
                                          I am afraid it will not stop with M585 at trigger.
                                          Its advanced electronics with duet and i am probably too fresh to sort it out on my own so sorry for keep asking.
                                            If you want to run M585 and then M500 so that the resulting offset is restored after you power the machine down and up again, then you do need to use config-override.g.
