    Grounding kossel mini frame
    1.8k
      I recommend that you also connect mains ground to the V- output of your PSU. Just watch out if you use a USB connection to the Duet, see the wiki page on USB ground loops.
      • leifundefined
        leif
        Thanks for quick reply @dc42 . I was aware of ground loops and have been connecting to the Duet with laptop powered by battery alone which was suggested a safe option. I also think the new doku is very very good, so thank you very much for this 🙂
        I updated the drawing as suggested and will wire up the rest of printer again shortly. I have also updated my steppers to 0.9 17HM19-2004S as suggested earlier in your blogpost. Practically my kossel mini came together by reading your blog, so thank you so much again 🙂
        • veng1undefined
          veng1
          Why not use a large value resistor, say 1M, between V- and mains ground?
          That will still bleed off a static charge but not, hopefully, impact ground loops as much.
          Phaedruxundefined 1 Reply Last reply Reply Quote 2
          • c310undefined
            c310
            why not to ground stepper motors body directly to main earth?
            ...without connecting main ground to V-
            i grounded mine and it seems to work without issues....
            • fcwiltundefined
              fcwilt
              Just to be safe I would not connect the PS connections V- and G without checking with the manufacture first.
              In many, if not most, cases I think it will be fine but there are PS designs (at least on paper) where this connection would not be a good idea.
                Phaedrux Moderator @veng1
                @veng1 said in Grounding kossel mini frame:
                I've also seen it recommended to use a diode between DC V- and Mains ground but I can't seem to find it anymore. I'm not an electrical wizard so I don't know if that's good advice or not. But the reasoning given was similar to what you mention.
                • c310undefined
                  c310
                  @phaedrux said in Grounding kossel mini frame:
                  @dc42 can you help us on this issue?
                  article WiKi_USB_ground_loops says that
                  "Disconnect the power supply negative output from mains ground. For safety reasons, this is not recommended."
                  So, questions:
                  1. Connect or not to V- to main ground? what is the risk of not connecting it?
                  2. put diode or resistor? what kind of parameters ?
                  3. if it is diode - which side / polarity ?
                  thanks!
                    @c310 said in Grounding kossel mini frame:
                    https://www.youtube.com/watch?v=3jYZDLOV4Jc
                    • c310undefined
                      c310
                      @dc42 thanks for video.
                      it is clear with grounding PSU, but in the video ground is NOT connected to V-
                      should i connect it or not? if yes - diode (which polarity than) or resistor... ???
                      thanks!
                        I connect it directly on my delta.
                        • phdmoreauundefined phdmoreau referenced this topic
