DuetWifi Mount + PanelDue enclosure (STL + sldprt files)
Hi all,
I wanted to share with you my designs for DuetWifi mount and PanelDue enclosure.
I included the original design sldprt files, and the STL files.
The models can also be found at Thingiverse, in the following links:
http://www.thingiverse.com/thing:1976962
http://www.thingiverse.com/thing:1980251Fell free to comment if you like it, and to branch your design.
The DuetWifi mount is simple to print, with no support needed and pretty quick print, thanks to the perforated design.
The mount raises the DuetWifi 20[mm] to optimize board cooling.
I also included an optional 40[mm] fan mount, which can be connected easily using M3 bolts.
I recommend to position the fan in such a way that will blow on top and below the stepper drivers.The DuetWifi board connected to mount with 4 M4 bolts. (any bolt length shorter then 25mm will be fine)
STL files download
http://www.guyaros.com/blog/images/3dprinting/DuetWifiMount/DuetWifiBaseVer2.STL
http://www.guyaros.com/blog/images/3dprinting/DuetWifiMount/Fan40Mount.STLsldprt (2016) files download (ZIP file)
http://www.guyaros.com/blog/images/3dprinting/DuetWifiMount/DuetWifiMountAssembly1.zipPanelDue Enclosure
This enclosure designed for PanelDue 4.3".
The enclosure can be mounted in various ways, thanks to the mounting adapters.
All the key components in the PanelDue are accessible, including SD card, SD cable connector, PanelDue connector, reset and erase buttons.Required Hardware
M3x6 (Mate LCD screen to Front panel), Quantity : 4
M3x12 (Mate Front panel to Back plate), Quantity : 6
M3x10 (Mate Back plate to Back Mount), Quantity : 5
M4x20 (Mate Back mount to Link), Quantity : 1
M5x40 (Mate Link to Rail), Quantity : 1
M3 Nuts, Quantity : 5
M4 Nuts, Quantity : 1
M5 Nuts, Quantity : 1STL files
http://www.guyaros.com/blog/images/3dprinting/PanelDueEnclosure/PanelDue4.3-Enclosure-Front-Ver2.STL
http://www.guyaros.com/blog/images/3dprinting/PanelDueEnclosure/PanelDue4.3-Enclosure-Back-Ver2.STL
http://www.guyaros.com/blog/images/3dprinting/PanelDueEnclosure/PanelDue4.3-Enclosure-BackMount-Ver2.STL
http://www.guyaros.com/blog/images/3dprinting/PanelDueEnclosure/PanelDue4.3-Enclosure-MountLink-Ver2.STL
http://www.guyaros.com/blog/images/3dprinting/PanelDueEnclosure/PanelDue4.3-Enclosure-MountRail-Ver2.STLsldprt (2016) files (ZIP)
http://www.guyaros.com/blog/images/3dprinting/PanelDueEnclosure/PanelDue4.3EnclosureAssembly1.zip -
Well, I just found out here that there was a physical change for paneldue v2. Just checked, and realized I have one of each from my last two orders!
It would be nice to be informed of major changes in hardware. Part of ordering multiple of the "same" part is having a reliable supply of compatible parts.
BTW nice looking paneldue enclosure! hah.
