    Help choose: Maestro vs WiFi
    7.3k
    • Falkiaundefined
      Falkia @briskspirit
      @briskspirit you can always use it as a 2 wire sensor, just leave the reference wire disconnected or just connect the two red wires together. Anyway it will only be accurate as a 2-wire sensor.
      Printer: "Deltacus" Delta with 510mm bed diameter and 925mm build height. Powered by Duet 2 WiFi. Duet Smart Effector with E3D Volcano.
      • briskspiritundefined
        briskspirit
        @falkia Thanks, understood
        Need to make a decision:
        1 - Now I have two Thermocouples K - $30 for expansion board
        2 - Or switch to PT100 - $30 board + ~$20 sensors
        3 - Switch to thermistors - less than $10 but need to change heater blocks 🙂
        • Dougal1957undefined
          Dougal1957 @briskspirit
          @briskspirit or look into PT1000 sensors which are better than thermistors but not quite as good as PT100's but they don't need the daughter boards to function
          briskspiritundefined 1 Reply Last reply Reply Quote 0
            briskspirit @Dougal1957
            @dougal1957 Why are they better?
            Dougal1957undefined 2 Replies Last reply Reply Quote 0
              This post is deleted!
                @briskspirit the accuracy is better than a thermistor and they tend to have known response curves which are the same for most if not all of them you have no need to worry about B values or temp/resistance curves PT100's are flat response PT1000 are nearly flat certainly close enough to flat for us not to seriously worry about it. I have 100's on my delta but will probably use 1000's on my next CoreXY Build
                briskspiritundefined 1 Reply Last reply Reply Quote 1
                  @dougal1957 trying to find 3mm PT1000 on eBay and Amazon - zero...
                    Dougal1957
                    PT1000 sensor cartridges
                    You can also get the bare sensor for around 1.5-2$ each from places like RS in the UK and there most be places all round that have them get some 3mm od stainless tube and make your own
                      @dougal1957 So with so small difference in price between PT100 and PT1000 the point is to save some money on expansion board, right? Is it ok to use connectors with this type of sensor?
                        @briskspirit yes indeed it is ok a std 2 pin molex KK is what I have tested with on my Duet Ethernet board for my bed sensor using one of these discreet sensors works very well and take all the pain of configuring the Thermistor resistance-temp table (Beta value). the response on a RTD (PT100/PT1000) is pretty much linear.
                          briskspirit
                          And PT100 2-wire can't be used with connectors? And 4-wire can be?
