    Maestro getting started
    37
    6.1k
      Support for Duet Maestros sold by M3D (which is all of them so far) is provided by M3D, not by us, because M3D does the manufacture and testing. However...
      I have heard of several cases of the micro USB cable supplied with the Maestro being faulty. So I suggest you try a different cable. [EDIT: looks like you are already using a different one.]
      The Maestro doesn't have an erase button, it has a 2-pin jumper instead. It is close the the main processor, labelled ERASE.
      I don't understand:
      A blue led briefly flashes on the WiFi board and the Diag. led flashes once.
      What WiFi board? The Duet 2 Maestro has an Ethernet connector.
      HTH David
      • StJohnundefined
        StJohn
        OK, I am confused, the board has Wifi, but no erase button. It seems to follow the general layout of the Duet 2 but so does the Maestro. There is a jumper just below the endstop connectors marked erase, no ethernet connection but has wifi. I purchased it a few days ago from E3D online as a Duet 2. Do some Duet 2s not have an erase button?.
        I guess I will jumper the erase pins and boot the board. Then try to reinstall the firmware. Unless someone can suggest a less drastic course of action.
          dc42 administrators @StJohn
          @stjohn, what you have is a Duet WiFi revision 1.04, not a Duet Maestro. So you've come to the right place for support, although you're in the wrong thread.
          If your PC uses Windows, please go to Device Manager, then connect the Duet via USB. Expand "Ports (COM & LPT) and look for the Duet there. If it isn't there, see if there is an "Unknown Device" listed anywhere. Also try a different USB port - Windows has a habit of turning them off sometimes. Try a different micro USB cable if you have another one.
          If you still can't find the Duet in Device Manager, you can try putting a jumper across the Erase pins. The "Bossa port" should appear, again under "Ports (COM & LPT)". Remove the jumper again, because the board won't program while it is present. Then follow the instructions at https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_3.
          HTH David
          • crusstyundefined
            crussty @streamliner
            @streamliner Watching along as you unravel this. Don't envy you having to sort it all out. Once you get it sorted, would you mind also posting the compiled bin's in your dev branches so we can fiddle with what you are working on without having to rebuild it?
            Mahalo!
            Chris
            • streamlinerundefined
              streamliner
              @crussty Most certainly 😃 I am just trying to determine where the 'fracture' ocurred right now... this is not fun. I think I may just pick up on the most complete version of what @dc42 has and just update it inline.
              @dc42: Speaking of, what branch of your dev firmware is currently the most similar to the feature branch: https://github.com/PrintM3D/RepRapFirmware/tree/v2-feature/morecomplete12864? I see what happened at this point...he was going to implement the feature branch, had to stop, and somewhere in between would have been an update.. i'm trying to construct a timeline to understand where to go back to.
              Thanks,
              David
                As discussed by email, I have merged Matt's work into my v2-dev branch.
                • StJohnundefined
                  StJohn
                  Thank you for your help. I went back to basics on this issue and dug out several USB cables and tried the board with them until I found one that worked. I have now connected the board to wifi and tested it. Everything seems to work so no nuclear option was needed. Thank goodness..
                  One odd thing I noticed. When homing individual axes the Z axis would move first. This caused the head bed to collide with the printhead. I have edited the homing .G files to prevent this. Now I am waiting upon a bed-levelling sensor. But all of this is for another time.
                    @stjohn said in Maestro getting started:
                    The standard homing files move the head up (or bed down) by 5mm before homing X or Y, to avoid dragging the nozzle over the bed if it is at Z=0. If on your printer it caused the head to collide with the bed, then it sounds like your Z axis is moving in the wrong direction.
                      I have merged M3D's additions to the 12864 display support into my RRF fork, put a binary at https://www.dropbox.com/s/m0r3ldy424mxf4v/DuetMaestroFirmware.bin?dl=0 and updated the documentation at https://duet3d.dozuki.com/Wiki/Duet_2_Maestro_12864_display_menu_system. Please note, this binary is not an official beta release and has had very limited testing.
                      • Radek.Krepelaundefined
                        Radek.Krepela
                        Hello, Someone can confirm info on wiki https://duet3d.dozuki.com/Wiki/The_Duet_family_of_motion_control_electronics
                        Maestro ZprobeIN pins is 30V-tolerant? can i connect a 24V PNP industrial optical sensor directly without a voltage divider or diodes ,optocupler?
                        Thank you.
                          If you use a PNP output sensor, you will need at least a pulldown resistor.
                          Be very careful to connect the sensor output to the correct pin on the Z probe connector. If you connect it to then+3.3V or +5V pin by mistake, then you will wreck the Duet. So it's still safer to use a voltage divider.
                          • Agniusmundefined
                            Agniusm
                            Not to create a separage thread. Is there a working menu system for maestro or it needs to be created? I looked but have not seen simple lcd operational. Also, can someone point to compatible lcd?
                              dc42 administrators @Agniusm
                              @agniusm said in Maestro getting started:
                              We don't have a standard set of menu files, however M3D has produced a set for the Crane Quad. I have put a copy of those at https://www.dropbox.com/s/ugrqnqu6svp7lmn/CraneQuadMenuFiles.zip?dl=0. They should at least give you somewhere to start from.
                                @hosake please use the instructions at https://github.com/Duet3D/RepRapFirmware/wiki/Building-RepRapFirmware.
