    Endstop isusse
    1.0k
    • DK90undefined
      DK90
      Hello, i have an isusse with my Y-Endstop. When i start the Printer and home the Axis, it works well.
      But after the Axis is homed or after a print, when i rehome the Y-Axis, the Endstop is still triggerd, so the Axis don´t move to the endstop.
      Can anyone help me pleas?
      M574 X1 S0 ; Set active low endstops
      M574 Y2 S1 ; Y-Endstop hight end
      M574 U2 S0 ; U-Endstop high end
      • madhunmundefined
        madhunm
        @DK90
        are you using microswitches?
        please post some pictures.
        • DK90undefined
          DK90
          Yes, i use micro switches, for the y-axis.
            If that's your Y endstop it looks like a makerbot style active low endstop, in which case your endstop config should be M574 Y2 S0
            https://duet3d.dozuki.com/Wiki/GCode#Section_M574_Set_endstop_configuration
            https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches
            Is this a new build that you are just getting set up? Or was it working before and not anymore?
            If you trigger the endstop with your finger does the light on the Duet change?
            • DK90undefined
              DK90
              It is an „new“ Setup. I have changed something but the endstop Works well in the old Setup.
              When i trigger the endstop withe the Hand, the led change and the status change also.
              In the first run, after a reboot, it works to. But than it dosn‘t works anymore.
                Phaedrux Moderator @DK90
                @dk90 can you post your config file and homing files?
                DK90undefined 1 Reply Last reply Reply Quote 0
                • DK90undefined
                  DK90 @Phaedrux
                  @Phaedrux
                  ; generated by RepRapFirmware Configuration Tool on Thu Sep 13 2018 11:57:39 GMT+0200
                  M550 PIDEX ; Set machine name
                  M552 S1 ; Enable network
                  M587 S"DarkSide" P"DarkSide" ; Configure access point. You can delete this line once connected
                  M586 P0 S1 ; Enable HTTP
                  M586 P1 S0 ; Disable FTP
                  M586 P2 S0 ; Disable Telnet
                  M584 X0 Y2 Z1 E3:4 U5 ; Driver 0 controls the X motor, 1 controls Y, 2 control Z motors,3 and 4 control E motors and 5 the U motor
                  ;M584 X0 Y1 Z2 U3 E4:5 ; create the U axis and assign stepper driver 3 to it
                  M569 P0 S0 ; Drive 0 goes backwards X
                  M569 P1 S0 ; Drive 1 goes forwards Z
                  M569 P2 S1 ; Drive 2 goes forrwards Y
                  M569 P3 S0 ; Drive 3 goes forwards E0
                  M569 P4 S0 ; Drive 4 goes forwards E1
                  M569 P5 S0 ; Drive 5 goes backwards U
                  M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
                  M92 X80 Y80 Z400 U80 E120:100 ; Set steps per mm
                  M566 X600 Y600 U600 Z12 E120:120 ; Set maximum instantaneous speed changes (mm/min) /////Orginal Werte: 600
                  M203 X20000 Y20000 U20000 Z180 E1200:1200 ; Set maximum speeds (mm/min) ´ //// Orginal Werte: 6000
                  M201 X1000 Y1000 U1000 Z250 E250:250 ; Set accelerations (mm/s^2) //// Orginal Werte: 500
                  M906 X800 Y900 Z800 U900 E800:800 I30 ; Set motor currents (mA) and motor idle factor in per cent //Orginal Werte: 800mA
                  M84 S15 ; Set idle timeout
                  ;M206 Y-5 ; offset Y-Achse nach referenzfahrt
                  M208 X0 Y0 Z0 U60 S1 ; Achsen Limit minumum
                  M208 X151 Y189 U 200 Z200 S0 ; Achsen Limit Maximum
                  M564 H0 ;Erlaube Jogbewegung ohne zu homen
                  M574 X1 S0 ; Set active high endstops
                  M574 Z1 S2 ; Set endstops controlled by probe
                  ;M558 P4 H5 F120 T6000 ;//mechanischer endschalter Set Z probe type to switch and the dive height + speeds
                  M558 P5 H3 F500 ;Induktiver Sensor
                  G31 P500 X0 Y0 Z0.2 ; Set Z probe trigger value, offset and trigger height -0.835
                  M557 X25:150 Y35:180 S40 ; Define mesh grid
                  M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                  M305 P2 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 2
                  M143 H2 S280 ; Set temperature limit for heater 2 to 280C
                  M305 P101 S"DuetDriversTemp" ; Driver Duet
                  M305 P103 X3 S"Gehäuse-unten" T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 2
                  M106 P0 S0 I0 F500 H-1 C"BT-Kühler1" ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  M106 P1 S1 I0 F500 H1 T50 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  M106 P2 S1 I0 F500 H2 T50 ; Set fan 7 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  M106 P4 S0 I0 F500 H-1 C"BT-Kühler2" ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  ;---Gehäuselüfter---
                  ;M106 P3 F40 ; Part cooling fan (P3 is PWM Fan 3 on the Duex2 10Hz)
                  M106 P3 T45:65 H100:101:102:P103
                  M563 P0 D0 H1 S"X_Tool" ; Define tool 0
                  M563 P1 D1 H2 X3 S"U-Tool" ; Define tool 1
                  G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
                  G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
                  ''' Create a tool that prints 2 copies of the object using both carriages'''
                  M563 P2 D0:1 H1:2 X0:3 F0:4 S"Clone" ; tool 2 uses both extruders, hot end heaters and fans, and maps X to both X and U
                  G10 P2 X25 Y0 U-35 S0 R0 ; set tool offsets and temperatures
                  M567 P2 E1:1 ; set mix ratio 100% on both extruders
                  and the homing.g file
                  ; homex.g
                  ; called to home the all axis
                  ; --------Grundbedinugung ------------
                  ;G1 Z5 F6000 S2 ; lift Z relative to current position
                  ;------Y-Achse---------
                  G91 ; relative positioning
                  G1 S1 Y215 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                  G1 Y-10 F6000 ; go back a few mm
                  G1 S1 Y215 F360 ; move slowly to Y axis endstop once more (second pass)
                  ;G1 Z-5 F6000 S2 ; lower Z again
                  G90 ; absolute positioning
                  ;----------X-Achse-------------
                  M400 ; make sure everything has stopped before we make changes
                  M574 X1 Y1 S3 ; set endstops to use motor stall
                  M913 X50 Y50 ; drop motor currents to 50%
                  M915 X Y S1 R0 F0 ; set X and Y to sensitivity 3, do nothing when stall, unfiltered
                  M566 X500 Y500 ; Set maYimum instantaneous speed changes (mm/min)
                  M201 X500 Y500 ; Set accelerations (mm/s^2)
                  G91 ; use relative positioning
                  G1 S1 X-200 F3000 ; move left 100mm, stopping at the endstop
                  G1 S1 X10 F2000 ; move away from end
                  G90 ; back to absolute positioning
                  M400 ; make sure everything has stopped before we reset the motor currents
                  M913 X100 Y100 ; motor currents back to 100%
                  M566 X1200 Y1200 ; Set maYimum instantaneous speed changes back to normal (mm/min)
                  M201 X3000 Y3000 ; Set accelerations back to normal (mm/s^2)
                  M574 X1 Y1 S0 ; Define active low and unused microswitches
                  G1 X11 F6000;
                  ;----------U-Achse------------
                  ; homeu.g
                  ; U AXIS
                  M574 U2 S3 ; set endstops to use motor stall
                  M913 U50 ; drop motor currents to 50%
                  M915 U S1 R0 F0 ; set X and Y to sensitivity 3, do nothing when stall, unfiltered
                  M566 U500 ; Set maYimum instantaneous speed changes (mm/min)
                  M201 U500 ; Set accelerations (mm/s^2)
                  G1 S1 U300 F3000 ; move left 100mm, stopping at the endstop
                  G1 S1 U-22 F2000 ; move away from end
                  M913 U100 ; motor currents back to 100%
                  M566 U1200 ; Set maYimum instantaneous speed changes back to normal (mm/min)
                  M201 U3000 ; Set accelerations back to normal (mm/s^2)
                  M574 U2 S0 ; Define active low and unused microswitches
                  ;-----Z-Achse------------
                  G90 ; absolute positioninn
                  G1 X50 Y100 F2000 S2 ; move to bed centre for probing
                  G30 ; probe the bed and set Z height
                  G1 Y10 X10;
                  ;---Bestätigungs Tone----------
                  M98 P0:/macros/Tunes/Zelda2.g
                    @dk90 said in Endstop isusse:
                    In your x axis section when you switch back to using microswitches you have the y axis at the low end but in your config it is at the high end.
                    • DK90undefined
                      DK90 @Phaedrux
                      @phaedrux 🤦 Thank you 🙂 i will test it tomorror!
                        Does your Zelda tune play correctly?
                        • DK90undefined
                          DK90 @Phaedrux
                          @phaedrux ehm i think so 😄
                          here is the code for the macro.
                          ;ZELDATREASUREnopause;
                          G4 P1000 ; wait
                          M300 S392 P200 ; G4
                          M300 S440 P200 ; A4
                          M300 S493.88 P200 ; B4
                          M300 S554.37 P200 ; C#5
                          M300 S392 P195 ; G4
                          M300 S440 P195 ; A4
                          M300 S493.88 P195 ; B4
                          M300 S554.37 P195 ; C#5
                          M300 S415.3 P190 ; G#4
                          M300 S466.16 P190 ; A#4
                          M300 S523.25 P190 ; C5
                          M300 S587.33 P190 ; D5
                          M300 S415.3 P185 ; G#4
                          M300 S466.16 P185 ; A#4
                          M300 S523.25 P185 ; C5
                          M300 S587.33 P185 ; D5
                          M300 S440 P180 ; A4
                          M300 S493.88 P180 ; B4
                          M300 S554.37 P180 ; C#5
                          M300 S622.25 P180 ; D#5
                          M300 S440 P175 ; A4
                          M300 S493.88 P175 ; B4
                          M300 S554.37 P175 ; C#5
                          M300 S622.25 P175 ; D#5
                          M300 S466.16 P169 ; A#4
                          M300 S523.25 P169 ; C5
                          M300 S587.33 P169 ; D5
                          M300 S659.25 P169 ; E5
                          M300 S466.16 P163 ; A#4
                          M300 S523.25 P163 ; C5
                          M300 S587.33 P163 ; D5
                          M300 S659.25 P163 ; E5
                          M300 S493.88 P158 ; B4
                          M300 S554.37 P158 ; C#5
                          M300 S622.25 P158 ; D#5
                          M300 S698.46 P158 ; F5
                          M300 S523.25 P151 ; C5
                          M300 S587.33 P151 ; D5
                          M300 S659.25 P151 ; E5
                          M300 S739.99 P151 ; F#5
                          M300 S554.37 P144 ; C#5
                          M300 S622.25 P144 ; D#5
                          M300 S698.46 P144 ; F5
                          M300 S783.99 P144 ; G5
                          M300 S587.33 P137 ; D5
                          M300 S659.25 P137 ; E5
                          M300 S739.99 P137 ; F#5
                          M300 S830.61 P887 ; G#5
                          M300 S349.23 P25 ; F4
                          M300 S523.25 P25 ; C5
                          M300 S880 P25 ; A5
                          M300 S880 P25 ; A5
                          M300 S880 P25 ; A5
                          M300 S880 P25 ; A5
                          M300 S369.99 P25 ; F#4
                          M300 S554.37 P25 ; C#5
                          M300 S932.33 P25 ; A#5
                          M300 S392 P25 ; G4
                          M300 S587.33 P25 ; D5
                          M300 S987.77 P25 ; B5
                          M300 S392 P25 ; G4
                          M300 S392 P25 ; G4
                          M300 S392 P25 ; G4
                          M300 S415.3 P25 ; G#4
                          M300 S622.25 P25 ; D#5
                          M300 S1046.5 P25 ; C6
                          G4 P1000 ; wait
