    [Off topic] Help with PETG
    • peirofundefined
      peirof
      I put my doubts here, although I know they are not from here, in case someone can give me some idea.
      So far I have always printed with PLA and ABS, but after reading about the PETG, I have decided to try it.
      The first impressions with PETG went well, but after dismantling and assembling the Hotend, I am having problems with the printing of this material. Get printed approximately 2 and a half layers, and then jam in the extruder. Always the same, once stuck I do a "cold pull" and I can see in the tip of the filament that I extract a pile of material ... as if something had plugged it. As a result of clogging, loss of steps in the extruder, the material "slips" and is not extruded
      I have tried several things, one of them is to print without layer fans ... With similar result.
      The truth is that I do not know what it can be. I put here the parameters that I use, in case you can give me ideas of things to try:
      Extruder: Nimble
      Hotend: Prometheus v2
      Slicer: Cura 3.2.1
      Layer: Height 0,16 mm
      Hotend Temp: 245 C
      Bed Temp: 70 C
      Speed: 30 mm/sec
      Jerk: 0,5 mm
      Layer fan: I have try with 25% and NO layer fan
      Retraction Speed: 18 mm/s – Works with ABS and Nimble extruder
      What can try? What can change?
      Thanks in advance
      • peirofundefined
        peirof
        Solved....
        I have change slicer software....
        • briskspiritundefined
          briskspirit
          Changed to which one?
          • peirofundefined
            peirof
            Simplify 3d
            • burtoogleundefined
              burtoogle
              I can assure folks that there is no problem using Cura to slice PETG prints. I use PETG a lot and only use Cura and do not ever suffer from extruder jams while printing.
                Phaedrux Moderator @burtoogle
                @burtoogle it's clearly settings related.
                @peirof It would be helpful to know what the difference in settings was from one to the other. Jams would hint at retraction being too aggressive maybe?
