    Cancel print
    Firmware wishlist
    • Zesty_Lykleundefined
      Zesty_Lykle
      When I press the Cancel print button, I kind of expect the print to be cancelled, heaters to be switched off and the printer reset to Home.
      That last point doesn't happen. I need to switch pages, and find the Home All button.
      Is there a way for me to modify the functionality of the button? Or is it baked in?
      Lykle
      Design, make and enjoy life
      Co Creator of the Zesty Nimble
      • StephenRCundefined
        StephenRC
        Put the codes you want the printer to do in the sys/stop.g file.
          Actually it's the cancel.g file that gets run when a print is cancelled. If it isn't found then the motors and heaters are turned off but the head is not moved.
          • botundefined
            bot
            And if you don't turn off heaters in the cancel.g file, but you do have a cancel.g file (with g28, for eg) the heaters don't turn off. I like this feature very much, as I manually set Z height and so having the heaters remain on saves time when restarting a print to adjust z height.
            *not actually a robot
