Requests for help: Gcode cam follower/ tangential knife control.
62
10.2k
    genghisnico13 @Russ Gries
    @russ-gries I dont know if this is the best way to do it, but assuming you are going to use a stepper motor you could maybe configure it as an extruder so it uses relative movement by default and if you set your steps/mm to 360°/(200stesp/rev motor) *16microstepping = 8.889 you would have an "Extruder"=Rotating Head that can be commanded to move 30° clockwise by sending G1 E30.
    You would have to align it somehow before turning that stepper and make that your initial angle.
    BTW I saw your video a while back, good work, I guess this is where all the cool kids hang.
    undefined 1 Reply Last reply 26 Sept 2018, 16:44 Reply Quote 2
      Russ Gries @genghisnico13
      @genghisnico13
      Good thinking there! its defiantly something to think about.
      One question though. if its set up as an Extruder. then how dose the firmware handle it.
      let me restate that question.
      from my understanding, if the extruder gets a command in relative movement ( E30) then over the entire moment the extruder moves that much right? so that the plastic is evenly extruded?
      so i'm not sure where that is handled. is it in the firmware or else where?
      so if the code looks like this for Printing:
      G1 X33.265 Y27.359 E1.37686
      G1 X32.331 Y28.899 E0.07487
      G1 X29.933 Y32.214 E0.17009
      Then everything is moving at the same time so to speak. while x and y are moving the extruder is moving that much and ending at the same time as the line of code.
      however, I would need to have the E ( rotational motor) move before the next moment. so that its allways going in the right direction.
      so, with this in mined, can it be done like this:
      then it would need to look like this for the rotational motor? :
      G1 X33.265 Y27.359
      E1.37686
      G1 X32.331 Y28.899
      E0.07487
      G1 X29.933 Y32.214
      E0.17009
      am i thinking of this correctly?
      it will read each line and move there before going to the next line?
      Thanks for the feed back. Unfortunately I'm not that familiar with how things are read in the buffer... so some trial and error is needed, that or one who can answer the questions can help 🙂
      good stuff. will get there. 🙂
      Thanks!!
      ~Russ Gries
      One Day At A Time…
      My Main Research Page:
      http://rwgresearch.com/open-projects/3d-printing-research/
      undefined 1 Reply Last reply 26 Sept 2018, 18:13 Reply Quote 0
        @russ-gries said in Requests for help: Gcode cam follower/ tangential knife control.:
        Correct, the movement of all the axis and extruders in the same command are coordinated.
        Yes, the firmware is designed to do this
        however, I would need to have the E ( rotational motor) move before the next moment. so that its always going in the right direction.
        well I suppose it depends, the ideal way would probably be to not use a slicer because as far as I know they don't support arc movements G2/3(they approximate with small lines), but with a small enough linear approximation to a curve the difference between doing it before or during will be very small probably insignificant.
        I'm not 100% sure, but if it doesn't work, the way you suggested below should work.
        G1 X33.265 Y27.359
        E1.37686
        G1 X32.331 Y28.899
        E0.07487
        G1 X29.933 Y32.214
        E0.17009
        Correct, for consecutive movements each line is executed after the previous movement is finished and the movements are coordinated only when they are in the same G command.
        BTW I am relatively new to this so I'm sure someone will correct me if I'm wrong.
          Russ Gries
          Ok, Thanks for the feed back!
          After doing some work on this a second option for turrning the tool head is to use a servo....
          I could get a 360 deg servo. Then just move the servo accordingly.
          Ill have to think about this more.
          Somthing like this would work with the right controls...
          https://www.adafruit.com/product/3614?gclid=EAIaIQobChMI77yl9rra3QIVltlkCh0RDQq3EAQYAiABEgK3iPD_BwE
          So a stepper might be best for eazy installation and uses...
          I'm going to use a geared stepper for this first version so the size is small. Wont be fast but it will be functional...
          ~Russ
          One Day At A Time…
            Russ Gries
            Progress.. a short video of it working! well just proof it can be done but a lot more to do in the G code script...
            https://www.youtube.com/watch?v=0EYsK1X155M
            I'm not so sure using the extruder output is going to work.
            due to how its controlled in the firmware. I have two choices from what i can see.
            1. try to hack some thing to let me move the extruder before the move but on the fly. ( no waiting)
            2. wait every time it has to move by placing it on the next line by its self... not a good option for fast coil making...
            The other option is to use the U axis and try to make absolute movements work...
            I wonder if I'm still going to have the same problem with that too...
            feed back please.
            Thanks for the help everyone! I can see us all cutting vinal, cloth, paper, cardboard, leather? ... and for me ... making coils!
            ~Russ
            One Day At A Time…
              Russ Gries
              Progross ! Got the motor and gear system all ready for testing.
              Alot more to do.. but a little at a time...
              ~Russ
              Had to re build the motor to make it 24V bipolar...
              One Day At A Time…
                Russ Gries
                Short snippet of it working.
                https://youtu.be/Ruf0Oo334ZM
                Alot of slop in the original stepper motor gears. May need to change that out for somthing better. Or see if i can fix it at all.
                But its a start! Thats what prototypes are all about!
                ~Russ
                One Day At A Time…
                  Russ Gries
                  ok, I'm lost...
                  I set up the U axis,
                  I want to control it at the same time as XYZ ( delta) but it is doing all kinds of weird things.
                  here is my config.g can you see anything i need to change?
                  ; Configuration file for dc42 Kossel updated RWG 11-25-16
                  ; Axis and motor configuration
                  M569 P3 S1 ; Drive 3 goes backwards
                  M569 P4 S0 ; Drive 4 goes backwards
                  M574 X2 Y2 Z2 U2 S0 ; set endstop configuration (all endstops at high end, active high)0 = none, 1 = low end, 2 = high end.
                  M584 U4 ; ********** map U drive to second extruder driver.
                  M665 R166.636 L343.788 B155 H405 X 0°, Y 0° ; set delta radius, diagonal rod length, printable radius, homed height and XY tower corrections
                  M666 X0.01 Y-0.45 Z0.44 Z0.00 U0 ; **********put your endstop adjustments here, or use auto calibration to find them
                  M92 X80 Y80 Z80 U90 ; Set axis steps/mm (20 tooth pulleys, 1.8deg/step motors)
                  M350 X64 Y64 Z64 U1 E16 I1 ; ( set E to 😎 Set 16x micro-stepping with interpolation
                  M906 X1500 Y1500 Z1500 U200 E800 I50 ; Set motor currents (mA) and increase idle current to 60% Russ change from default 60 to 10
                  M201 X1000 Y1000 Z1000 U3000 E1000 ; Accelerations (mm/s^2)
                  M203 X30000 Y30000 Z30000 U3000 E30000 ; Maximum speeds (mm/min)
                  M566 X1200 Y1200 Z1200 U3000 E1200 ; Maximum instant speed changes
                  G21 ; Work in millimetres
                  ;M557 R80 S18 ; ***moved to auto cal file!! define a grid with the specified radius and spacing (for delta printers)results are spored in file /sys/heightmap.csv
                  ; FAN CONTROL
                  M106 P0 I1 ; invert fan pwm
                  ; Thermistors and heaters
                  M305 P0 T100000 B3950 R4700 H0 L0 ; Typical Chinese bed thermistor. Put your own H and/or L values here to set the bed thermistor ADC correction.
                  M305 P1 T100000 B4388 R4700 H0 L0 ; E3Dv6 hot end. Put your own H and/or L values here if necessary to set the first nozzle thermistor ADC correction.
                  M301 H0 P20 I0.5 D1000 T0.85 W150 B5 ; PID settings for the bed
                  M301 H1 P10 I0.10 D100 T0.50 ; PID settings for extruder 0
                  M570 ; Allow extra heating time
                  ; Tool definitions
                  M563 P0 D0 H1 S"Extruder 1" ; Define tool 0
                  ;M563 P1 D1 S"360 Drive" ; **********Define tool 1 ( use if tool is an extruder)
                  G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
                  ;M92 E90 ; ********** (Set extruder steps per mm 20 1024 ,this is 360 deg ) for first and second extruders ( use if tool is an extruder)
                  ;Servo control
                  M307 H6 A-1 C-1 D-1 ; Disable heater channel 6 for use with servo CNC spindle. use M280 P6 Sxx the S is the ms use 0-200, I1 to invert Sig, must use on every command
                  M280 P6 S30 ; set the "throddle" to boot high, low, high. boots the esc
                  M280 P6 S5
                  M280 P6 S30
                  ;*** If you have a dual-nozzle build, un-comment the next 2 lines
                  ;M563 P1 D1 H2 ; Define tool 1
                  ;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
                  ;M92 E663:663 ; Set extruder steps per mm
                  ; Z probe and compensation definition
                  M558 P1 X0 Y0 Z1 H5 F300 T10000 I1 ; Z probe is IR and is not used for homing any axes, Z probe dive height 3mm, probing speed 300mm/min, travel speed 10000mm/min , Invert (I1) or do not invert (I0)
                  G31 X0 Y0 Z0 P500 ; Set the zprobe offset and threshold (put your own values here). For a delta, use zero X and Y offset.
                  ;*** If you are using axis compensation, put the figures in the following command
                  ;M556 S78 X0 Y0 Z0 ; Axis compensation here
                  M207 S7.0 F3600 Z0.1 ; Set firmware retraction details
                  M572 D0 S0.1 ; set pressure advance
                  M208 X0 Y0 Z-30 U0 S1 ; ********** set minimum limments
                  ;M208 X0 Y0 Z0 ; set max limments
                  T0 ; select first print head
                  M501 ; load Eprom settings
                  I'm sure there are thing in there that are old, its not a clean file... i need it clean it up.
                  If i dont home U, i can get it to work, but if i home it it dose not run at all... i have know idea why.
                  here is my homeu.g
                  G91 ; use relative positioning
                  M220 S100 ; Set speed factor override percentage to 100% if its higher so the home dose not slam the top.
                  G1 S1 U360 F3000 ; move axis 360 and look for and stop
                  G1 S2 U20 ; move axis
                  G1 S1 U-20 ; move axis to find home again
                  G1 U10 F2000 ; move to X0 facing position ( change this number to set home where you want)
                  G90 ; back to absolute positioning
                  G1 U200 F500 ; center the head and set a reasonable feed rate
                  any help is a huge plus!
                  Thank you!
                  ~Russ
                  ps. the first time i hit home U the entire printer makes high pitch noises from the motor? know idea what that's all about but it messes up the motors... egh!
                  One Day At A Time…
                    Which firmware version are you using? There was a bug with homing additional axes on a delta, that I fixed in one of the 2.02RC releases.
                      Russ Gries
                      Thanks David,
                      Im using 1.19 i believe. Need to double check in the morning.
                      I can upgrade and see if that fixes it.
                      A few other Q.
                      1. In the mean time dose the config.g look good or did i miss somthing? Also the homeu.g
                      2. Can i set up one axis as relative while the rest are absolute?
                      3. If i send this command. G1 X50 Y50 U10 will the U complete before the X and Y or will they all finish at the same time?
                      4. Can i set up axis U to allways move at the same apeed all the time? And use the F command to change it other wise?
                      Such as using a G0 command to move it one speed and use G1 to move another? Thses will be fixed speeds for each? But only for the U axis?
                      If i can set up G1 and G0 for set speeds on U where do i do that?
                      Thank you thank you thank you!
                      Im going crazy over here 😉
                      But ill get there!
                      ~Russ
                      One Day At A Time…
                        1. Your M584 command that creates the U axis must come before the M574 command that refers to U. Also the M584 command should re-define the extruder drivers, otherwise driver 4 will be both an axis and an extruder.
                        2. No.
                        3. At the same time.
                        4. No. The F parameter determines the speed of the move as a whole. If there is any XYZ movement, then it is the speed of the XYZ component of the move.
                        undefined 1 Reply Last reply 5 Oct 2018, 05:47 Reply Quote 0
                          Danal
                          Having read all above (but quite quickly to be honest), were I to attempt this, I would lean heavily on the G-Code concept that a G1 move does internal calculations to ensure that all axis specified on that move arrive at the same point at the same time when the move ends.
                          Also, A is normally the first rotational axis. Given RepRap flexibility, you could call it A or U... but I'm going to call it A below, as this is more normal CNC nomenclature.
                          Assuming A is defined as a rotational axis:
                          G1 Xnnn Ynnn Annn will smoothly rotate the A axis "in coordination with" the XY move. A series of these should do what you want.
                          Homing on A should be setup mechanically so that A can continuously rotate, and that "home" is triggered for a fraction of a degree of that rotation.
                          Relative vs. absolute? Doesn't really matter, when you realize an NIST standard rotational axis can be moved an infinite amount, limited only by the number of digits that the G-Code parser will accept.
                          That is, as you wind a coil, A might move through 0, many tiny increments, past 360, and just keep going. Far along in a coil, moving from 394857.2 to 394857.24 is perfectly legitimate.
                          Anyway, I'd build everything on those assumptions. You MAY already be doing that... but I wanted to make a pretty strong recommendation to NOT treat a rotational axis as an extruder, or anything else. Treat it as a rotational axis. G-Code standards will give you a big jump on what you are trying to accomplish.
                            Danal
                            DC42, does RepRap support rotational axis move coordination on G2?
                            Russ, if it does, that would make the G-Code much simpler. You could have a single line of G-code that does each "circle" of the coil. If it does, I'll post some examples.
                            By the way, for coil winding, you may wish to generate the G-Code with a simple script. PERL, Python, Java, etc.
                              @danal said in Requests for help: Gcode cam follower/ tangential knife control.:
                              RRF does not currently distinguish between linear and rotational axes.
                              G2 and G3 moves can specify movement along additional axes, which will be done linearly and coordinated with the XY motion.
                                Russ Gries
                                Yes, this was also a question I had.
                                David,
                                If it was you trying to make what im trying to make, How would you set up and control a rotanial axis?
                                You deeply know the limitations of the firmware.
                                In the end it might not be possible to make fluid movements like im trying to do.
                                So what ever the best options i have ill stick with those. I want others to be able to use there Duet controler to use a tool end as im making.
                                At the moment My current limitation is that I want to position the tool in the direction I want to go and in order to do this the tool has to stop every time it has to turn. I'm not sure if there's any way to work around this problem?
                                If I use arcs instead of point to point then is it possible to command the tool to follow the Ark. In any fashion?
                                From what I can tell so far I'm going to have to stop every time I want to turn the tool
                                Thanks for your feedback I'll do whatever I can with what options I have and eventually may have to try a completely different platform and order to achieve this, but even if it's slow it will still allow people to make knife cutters and other things so it's still worth pursuing.
                                ~Russ
                                One Day At A Time…
                                  Russ Gries
                                  I will be upgrading my firmware and testing the homing here in a couple of hours so will find out and make sure everything is good on that part.
                                  ~Russ
                                  One Day At A Time…
                                    Russ Gries @dc42
                                    ok, firmware up to date.
                                    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02RC2(RTOS) ELECTRONICS: Duet WiFi 1.0 or 1.01 FIRMWARE_DATE: 2018-09-07b2
                                    now, i see its homing but i cant move it at all once its homed or even before its homed?
                                    But now i get an error if its not homed and try to move it. where before it just moved only if it was not home yet.
                                    now I'm stuck, i cant move it. U is rendered useless. ? strange because it dose home
                                    did i miss end stop liniments or something?
                                    I also updated my config.g
                                    these now should be correct. I redefined the extruder drives correctly yes? and moved M574 after M584
                                    M569 P5 S0 ; Drive 5 goes backwards
                                    M584 U4 E3:5
                                    M574 X2 Y2 Z2 U2 S0
                                    when I run a file with U commands, it completely ignores the U commands?.
                                    not sure what to check next, please let me know what to look for. Thanks!!!!
                                    ~Russ
                                    One Day At A Time…
                                    adavidmundefined 1 Reply Last reply 5 Oct 2018, 15:02 Reply Quote 0
                                      Russ Gries
                                      also something to note, U dose not show up here? E0 andE1 do? but the current is correct for E0 for U ?
                                      is this normal?
                                      ~Russ
                                      One Day At A Time…
                                      undefined 1 Reply Last reply 5 Oct 2018, 13:28 Reply Quote 0
                                        Danal @Russ Gries
                                        ~Russ
                                        At one point, the Web interface had problems if the printer itself was configured for axis that were not in sequence. Be sure you are on the very latest web interface, and/or that bug may still exist.
                                          Danal
                                          Russ,
                                          Given David's answer that RepRap does not distinguish axis, and given that G-Code (and RepRap) ensure that all axis in a given single move reach their individual endpoints in sync, this all adds up to doing EXACTLY what you want for a coil winder.
                                          That is, if the current XYZ position of the "control point" is somwhere around a coil, ready to make the next coil, and the U axis is "pointed aft" to correctly lay the wire, then a G2 arc move that specifies a next XY 1/4 of the way around the coil, and a U that specifies 90 degrees from where U starts (in the correct positive or negative direction)... that move will smoothly rotate U as XY accelerate, move, deccelerate.
                                          Personally, I'd do 1/4 arcs while debugging so that you can "see" what is happening better.... but once you've confirmed how this all should work, and "good" g-code, then G2 moves that do full circles, one entire coil per G2 line, should be easy.
                                          This is all very hard to put into words... does it make sense?
                                          p.s. I'd still recommend you define your rotational axis as A (not U). This is a widespread standard for extra axis in CNC. It also MIGHT make the Web interface display it better.
                                          undefined 2 Replies Last reply 6 Oct 2018, 03:31 Reply Quote 0
                                          16 out of 62
