    Strain gauge module [SOLVED]
    Third-party add-ons
    1.4k
    • uk25undefined
      uk25
      I'm wondering if somebody used this strain gauge with Duet3D?
      Or can give advice of using it... to not to break my board.
      https://www.elecrow.com/strain-gauge-module-p-735.html
        That module should be compatible with the Z probe input of the Duet 2 series. It's for single-element strain gauges, so don't be surprised if the zero point varies with temperature.
        • uk25undefined
          uk25
          @dc42 said in Strain gauge module:
          Thanks, David. If I correctly understand better will be using something like that for full bridge configuration with four sensors.
          But its output voltage rated from -4 to +4V... Is it ok for Duet board?
            Yes, a half-bridge or full-bridge sensor used correctly should be less sensitive to temperature.
            • Falkiaundefined
              Falkia
              @uvarovkv Where and how are you going to mount the strain element? Just curious.
              Printer: "Deltacus" Delta with 510mm bed diameter and 925mm build height. Powered by Duet 2 WiFi. Duet Smart Effector with E3D Volcano.
              • Abelliundefined
                Abelli
                Your application requires a very sensitive force measuring device. A load cell sensitive enough for such low amplitude of vibration can work or you could also resort to using other types of sensing techniques but I think they might be costly. You could learn more about the force sensing techniques and related concepts through here: https://tacunasystems.com/knowledge-base/an-overview-of-load-cells/
