    Firmware 2.02RC2 released
    Firmware installation
    16
    41
    7.2k
      T3P3Tony administrators @Russ Gries
      @russ-gries try updating to the latest DWC
      Russ Griesundefined 1 Reply Last reply Reply Quote 0
      • kuhnikuehnastundefined
        kuhnikuehnast
        @T3P3Tony - same Issue here... But on the latest DWC:
        Firmware Version: 2.02RC2(RTOS) (2018-09-07b2)
        WiFi Server Version: 1.21
        Web Interface Version: 1.22.3
        • Russ Griesundefined
          Russ Gries @T3P3Tony
          @t3p3tony said in Firmware 2.02RC2 released:
          yep. i think this is the latest?
          Thanks!
          ~Russ
          One Day At A Time…
          My Main Research Page:
          http://rwgresearch.com/open-projects/3d-printing-research/
            @russ-gries should be, that upgrade response was an red-herring from me, apologies.
            The error is caused because you are trying to use a stepper driver that does not have a motor connected. Possibly you have an axis or extruder mapped to multiple drivers, but only have one plugged in?
            edit: as asked here: https://forum.duet3d.com/topic/7149/is-it-bad-to-send-movement-commands-if-motor-disconnected
            • mfdundefined
              mfd
              I am not sure if this is the correct place to post this, but I had a print fail today. It seems it just stopped and reset mid print
              Here are the M122 results.
              RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02RC2(RTOS) running on Duet WiFi 1.02 or later + DueX2
              Board ID: 08DDM-9FAM2-LW4S4-6JKF0-3S86N-TLSVX
              Used output buffers: 1 of 20 (8 max)
              Static ram: 28460
              Dynamic ram: 98348 of which 0 recycled
              Exception stack ram used: 328
              Never used ram: 3936
              Tasks: NETWORK(ready,328) HEAT(blocked,1232) MAIN(running,3540)
              Owned mutexes:
              Last reset 00:54:08 ago, cause: software
              Last software reset time unknown, reason: Stuck in spin loop, spinning module GCodes, available RAM 3560 bytes (slot 1)
              Software reset code 0x4043 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x20001eec Task 0x5754454e
              Stack: 00440817 004441f8 21000000 46a4e609 411a3b87 00000000 00000000 3e25e354 447a0000 447a0000 00000000 00000000 420fcdbe 450df418 3f96d506 40a00000 46adb5d4 c0000000 00005273 20000010 00000004 00000000 00000004
              Error status: 0
              Free file entries: 10
              MCU temperature: min 32.6, current 37.7, max 38.1
              Supply voltage: min 23.8, current 23.9, max 24.2, under voltage events: 0, over voltage events: 0
              Driver 5: standstill, SG min/max not available
              Driver 6: standstill, SG min/max not available
              Expansion motor(s) stall indication: yes
              Date/time: 2018-10-06 20:25:21
              Slowest loop: 12.22ms; fastest: 0.07ms
              Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
              Bed compensation in use: none
              Heater 1 is on, I-accum = 0.0
              Segments left: 0
              Movement lock held by null
              http is ready with "M122 " in state(s) 0
              telnet is idle in state(s) 0
              file is idle in state(s) 0
              serial is idle in state(s) 0
              aux is idle in state(s) 0
              daemon is idle in state(s) 0
              queue is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 214.07ms; fastest: 0.01ms
              HTTP sessions: 1 of 8
              - WiFi -
              Network state is running
              WiFi firmware version 1.21
              WiFi MAC address 5c:cf:7f:a4:03:d9
              WiFi Vcc 3.41, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 17152
              WiFi IP address 192.168.1.156
              WiFi signal strength -55dBm, reconnections 0, sleep mode modem
              === Expansion ===
              DueX I2C errors 0
              kuhnikuehnastundefined 1 Reply Last reply Reply Quote 0
                dc42 administrators @kuhnikuehnast
                @kuhnikuehnast said in Firmware 2.02RC2 released:
                What motor current are you using?
                Please share your config.g file.
                  dc42 administrators @Russ Gries
                  @russ-gries said in Firmware 2.02RC2 released:
                  also, i have a stepper motor that only draws 40ma max. is this why i get this message or is this known error?
                  That is likely a contributing factor. I'll change so as not to generate the message when the stepper motor current is set very low.
                  Btw the current on the Duet WiFi/Ethernet is only adjustable in steps of 100mA, and the minimum is 100mA (peak).
                    kuhnikuehnast @mfd
                    @dc42 said in Firmware 2.02RC2 released:
                    I am using a Motor current of 800 mA. It is only one motor (X respectively driver 0)
                    Here is my config- file:
                    (sorry, don't know how to insert this in the "special form" 😞 )
                    ; Configuration file for Duet WiFi (firmware version 1.20 or newer)
                    ; generated by RepRapFirmware Configuration Tool on Tue Jul 17 2018 12:09:47 GMT+0200 (Mitteleuropäische Sommerzeit)
                    M929 S1 ; Start Event logging (S0 = stop)
                    M550 PAM8_MGN ; Set machine name
                    M552 S1 ; Enable network
                    M554 P192.168.178.1 ; Set Gateway
                    M587 S"" P"*" ; Configure access point. You can delete this line once connected
                    M586 P0 S1 ; Enable HTTP
                    M586 P1 S0 ; Enable FTP
                    M586 P2 S0 ; Disable Telnet
                    M569 P0 S0 ; Drive 0 (X) goes backwards + Chopper Control register (Idle Noise)
                    M569 P1 S1 ; Drive 1 (Y) goes forwards + Chopper Control register (Idle Noise)
                    M569 P2 S0 ; Drive 2 (Z1) goes backwards + Chopper Control register (Idle Noise)
                    M569 P3 S0 ; Drive 3 (E0) goes backwards + Chopper Control register (Idle Noise)
                    M569 P4 S0 ; Drive 4 (Z2) goes backwards + Chopper Control register (Idle Noise)
                    M584 X0 Y1 Z4:2 E3 ; Define drive mapping- Z= driver number 2 and 4.
                    M671 X-77:297 Y20:20 S3 ; Set position of the leadscrews
                    M92 X100 Y100 Z400 E2902 ; Set steps per mm
                    M566 X900 Y900 Z12 E40 ; Set maximum instantaneous speed changes (mm/min)
                    M203 X18000 Y18000 Z1002 E6000 ; Set maximum speeds (mm/min)
                    M201 X1026 Y1026 Z250 E120 ; Set accelerations (mm/s^2)
                    M906 X800 Y800 Z800:800 E500 I30 ; Set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    M208 X-21 Y-12 Z0 S1 ; Set axis minima
                    M208 X250 Y227 Z240 S0 ; Set axis maxima
                    M574 X1 Y1 S0 ; Set active high endstops
                    M574 Z1 S2 ; Set endstops controlled by Z-probe
                    ; BLtouchZ-Probe
                    M307 H3 A-1 C-1 D-1 ; Disable the 3th heater on PWM channel for BLTouch
                    M558 P9 H5 F180 T15000 ; Set Z probe type/mode 9. H=Dive Height. F=Speed the bed moves
                    G31 P25 X+26.9 Y5.935 Z1.065 ; Set Z probe trigger value, offset and trigger height
                    M557 X20:200 Y20:200 S45 ; Define mesh grid
                    ; Heatbed
                    M305 P0 S"Heatbed" T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 0
                    M307 H0 A137.2 C579.6 D2.1 V12.1 S1.0 B0 ; Disable bang-bang mode for the bed heater and set PWM limit
                    M143 H0 S120 ; Set temperature limit for heater 1 to 280C
                    ; Heater 1
                    M305 P1 S"Hotend" T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                    M307 H1 A478.8 C240.5 D4.5 V12.1 S1.0 B0 ; Disable bang-bang mode for the bed heater and set PWM limit
                    M106 P0 I0 F250 H-1 C"Part Cooling Fan" ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    M106 P1 T45:50 I0 F100 H1 C"Hotend Fan" ; Set P1 as Hotend cooler,
                    M106 P2 T45:65 S0 I0 F100 H100:101:102 T45 C"Electronics Cooling Fan" ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    M563 S"Hotend" P0 D0 H1 F0 ; Define tool 0
                    M572 D0 S0.16 ; Set Pressure Advance
                    M404 N1.75 D0.4 ; Set Filament widht and nozzle diameter
                    T0 ; Select first tool
                    ; Automatic power saving
                    M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                      Russ Gries @dc42
                      I also switched to a bigher stepper motor, running at 200ma and it still happens alot. However the other steppers running at above and amp still dose it from time to time.
                      It happens more when Im moving things manually, or homing.
                      ~Russ
                      One Day At A Time…
                      • brunofportoundefined
                        brunofporto
                        Just to report.
                        I've been using RC2 with DWC 1.22.3 since release without any issues with a Duet2 Ethernet 1.03.
                        I had one "motor phase A/B disconnected" once and was due to a bad connected plug to the extrusion motor.
                        I have a lot of disconnections from DWC but my network here is really bad so I can not know if it is related to the firmware or it is just my bad network :D.
                          kuhnikuehnast @dc42
                          @dc42 Strange thing I noticed yesterday:
                          Due to crimping failure, One phase of a motor wasn't connected at all. But the printer tried to move anyway with terrible sound. This was on a DuetWifi 1.04 Board. On my Duet 1.03 Board, however I get the message and everything is connected well...?
                            Are you sure that your Duet 1.04 is running firmware 2.02RC2 ?
                              kuhnikuehnast @dc42
                              Yes 🙂
                                The open load detection doesn't try to stop the motor moving, it just produces the message. I'm downgrading it to a warning in the next 2.02RC because it isn't totally reliable yet.
