Strange startup
2.2k
    dorro1971
    Hi peeps,
    I'm looking for a little advice,...When i first powdr up my duet, it says "disconnected" on panelduet and nothing will home...if i set the bed temp to >55 degrees, the message changes to "idle" and i can home the machine.
    it's really annoying to have to enter a temperature every time i restart the machine.
    any ideas?...
    Many thanks.
      1. Which firmware version are you running on the Duet?
      2. What does the temperature read in Duet Web Control before you set it to 55C?
      3. If you send command M408 S1 to the printer from either USB or DWC before you set the temperature to 55C, what is the response?
        dorro1971
        hi, thanks for the speedy response (as always i might add)
        FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.01(RTOS) ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2018-07-26b2
        Both temps read actual values and update if you blow on them
        M408
        {"status":"O","heaters":[42.6,36.6],"active":[0.0,55.0],"standby":[0.0,55.0],"hstat":[0,0],"pos":[0.000,0.000,0.000],"machine":[0.000,0.000,0.000],"sfactor":100.00,"efactor":[100.00],"babystep":0.000,"tool":-1,"probe":"1000","fanPercent":[30.0,100.0,100.0,0.0,0.0,0.0,0.0,0.0,0.0],"fanRPM":0,"homed":[0,0,0],"msgBox.mode":-1}
        Hope this helps
        Thank you for your attention
          I think the reason is that your printer has no VIN power applied and the version of PanelDue firmware you are using doesn't understand the "O" status code. Try updating the PanelDue firmware.
            dorro1971
            hi, thank you for your continued support.
            paneldue has latest firmware, with logo...
            it's not just the pandue, the board must be powered as i get temperature feed back etc on webb control, if i call for home all from webb app, nothing moves, webb app says "disconnected" if i change bed temp to 55 it says"idle" and i can now home things..
            very odd..........
              dorro1971
              ill shoot a quick video if it helps
                Please confirm the version of firmware on your PanelDue.
                  dorro1971
                  hi,
                  firmware is PanelDue-5.0i-7.0i
                  but i seam to remeber it doing similar before i updated it...
                  thsnks
                    Go to the Setup page of PanelDue, and there you will find the firmware version displayed.
                      dorro1971
                      Sorry!...
                      it's 1.21.3(13b1)
                      my bad.
                      thanks again for your help...
                        dorro1971
                        Hi guys,
                        As a work around i've set the bed to 55 degrees in the last line of config.g.
                        looks like it's working.
                        I don't think i've done anything wrong with my config?..apart from lack of comments....
                        M555 P5 ; Set firmware compatibility to look like Repetier
                        M667 S1 ; Select CoreXY mode
                        M552 S1 ; Enable network
                        M586 P0 S1 ; Enable HTTP
                        M586 P1 S0 ; Disable FTP
                        M586 P2 S0 ; Disable Telnet
                        M575 P1 B57600 S1 ; Comms parameters for PanelDue
                        M111 S0 ; Debug off
                        M569 P0 S0 ; Drive 0 goes forwards
                        M569 P1 S0 ; Drive 1 goes backwards
                        M92 X100 Y100 Z1520 E143 ; Set steps per mm
                        M566 X500 Y500 Z40 E100 ; Set maximum instantaneous speed changes (mm/min)
                        M203 X30000 Y30000 Z1500 E20000 ; Set maximum speeds (mm/min)
                        M201 X500 Y500 Z500 E1000 ; Set accelerations (mm/s^2)
                        M906 X800 Y800 Z800 E500 I30 ; Set motor currents (mA) and motor idle factor in per cent
                        M84 S30 ; Set idle timeout
                        G21 ; Work in millimetres
                        G90 ; Send absolute coordinates…
                        M208 X340 Y220 Z267 S0 ; Set axis maxima
                        M574 X1 Y1 Z2 S1 ; Set active high endstops
                        m558 p4
                        M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
                        M143 H0 S140 ; Set temperature limit for heater 0 to 140C
                        M305 P1 T100000 B4725 C7.06e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                        M143 H1 S350 ; Set temperature limit for heater 1 to 350C
                        ;M301 H1 P10 I0.10 D100 T0.50 S1.0 ; PID settings for extruder 0
                        ;M301 H2 P10 I0.10 D100 T0.50 S1.0 ; PID settings for extruder 1
                        M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                        M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                        M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
                        M563 P0 D0 H1 ; Define tool 1
                        G10 P0 X0 Y0 Z0 ; Set tool 1 axis offsets
                        G10 P0 R55 S55 ; Set initial tool 0 active and standby temperatures to 0C
                        M501 ; Load saved parameters from non-volatile memory
                        T0
                        M572 D0 S0.03
                        M140 S55
                        Once again many thanks for a great product.
                          @dorro1971 said in Strange startup:
                          Does that really solve the problem?
                          The M408 response that you posted:
                          M408
                          was taken when your Duet had 5V power (perhaps from USB) but no VIN power - that's what status "O" means. So I assumed the problem you were getting was because you were not applying VIN power. If you still get the problem when VIN power is applied, please run M408 again when the PanelDue is failing to connect but you have VIN power applied (and without that extra line in config.g of course).
                            dorro1971
                            Duet is powered all the time from startup, no usb input.
                            if i set bed temp to 55 or more it goes to idle if i then set bed temp to 0 everything still works.
                            only power source is Vin 24v...(actually 27.5)..maybe a litlle high?
                            and yes that solves my problem I just don't like not knowing why..
                            panel duet says "disconnected" but still reports temperature changes...so it must be connected right?...it won't read memory card until i do the bed temp thingy...
                            a real puzzler...
                            also if i pause and canccel a print, when i restart it it homes but hangs..this may be a slicer issue but the first run is fine and if i do a second after completion it's fine...only a problem if cancelled...
                              dorro1971
                              This post is deleted!
                                dorro1971
                                when my current print is complete i'll double check......
                                  dorro1971
                                  Ok, initial power on..24v only, last line of config removed.
                                  M408
                                  {"status":"O","heaters":[44.0,54.9],"active":[0.0,55.0],"standby":[0.0,55.0],"hstat":[0,2],"pos":[0.000,0.000,0.000],"machine":[0.000,0.000,0.000],"sfactor":100.00,"efactor":[100.00],"babystep":0.000,"tool":0,"probe":"1000","fanPercent":[30.0,100.0,100.0,0.0,0.0,0.0,0.0,0.0,0.0],"fanRPM":0,"homed":[0,0,0],"msgBox.mode":-1}
                                  after m140 s55 issued
                                  M408
                                  {"status":"I","heaters":[52.2,55.0],"active":[55.0,55.0],"standby":[0.0,55.0],"hstat":[2,2],"pos":[0.000,0.000,0.000],"machine":[0.000,0.000,0.000],"sfactor":100.00,"efactor":[100.00],"babystep":0.000,"tool":0,"probe":"1000","fanPercent":[30.0,100.0,100.0,0.0,0.0,0.0,0.0,0.0,0.0],"fanRPM":0,"homed":[0,0,0],"msgBox.mode":-1}
                                  Checked wiring,..all good..is it worth re updating duet and panel duet?
                                  Any ideas...
                                  thank you..
                                    Before you send the M140 command, please send M122 and check the reported VIN voltage.
                                      dorro1971
                                      I'll do that...I wonder if the voltage is under low load. switching the bed on causes current draw and the psu to step up?
                                      It's printing now, I'll try that tomorrow..i'll also drop a volt test on it...
                                      Thank you.
                                        dorro1971
                                        19:48:06
                                        M122
                                        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01(RTOS) running on Duet Ethernet 1.02 or later
                                        Board ID: 08DGM-956GU-DJMSN-6J1DJ-3S86L-K9R3G
                                        Used output buffers: 3 of 20 (13 max)
                                        Static ram: 28476
                                        Dynamic ram: 95932 of which 16 recycled
                                        Exception stack ram used: 272
                                        Never used ram: 6376
                                        Tasks: NETWORK(ready,328) HEAT(blocked,1324) MAIN(running,3564)
                                        Owned mutexes:
                                        Last reset 00:01:02 ago, cause: software
                                        Last software reset at 2018-10-15 19:47, reason: User, spinning module GCodes, available RAM 6140 bytes (slot 0)
                                        Error status: 0
                                        Free file entries: 10
                                        MCU temperature: min 28.3, current 29.0, max 29.1
                                        Supply voltage: min 27.6, current 27.7, max 27.8, under voltage events: 0, over voltage events: 0
                                        Driver 0: ok, SG min/max not available
                                        Driver 1: ok, SG min/max not available
                                        Driver 2: ok, SG min/max not available
                                        Driver 3: ok, SG min/max not available
                                        Driver 4: ok, SG min/max not available
                                        Date/time: 2018-10-15 19:48:06
                                        Slowest loop: 6.17ms; fastest: 0.07ms
                                        Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
                                        Bed compensation in use: none
                                        Heater 1 is on, I-accum = 0.0
                                        Segments left: 0
                                        Movement lock held by null
                                        http is idle in state(s) 0
                                        telnet is idle in state(s) 0
                                        file is idle in state(s) 0
                                        serial is idle in state(s) 0
                                        aux is idle in state(s) 0
                                        daemon is idle in state(s) 0
                                        queue is idle in state(s) 0
                                        Code queue is empty.
                                        === Network ===
                                        Slowest loop: 6.22ms; fastest: 0.03ms
                                        HTTP sessions: 1 of 8
                                        Interface state: 5
                                        === Expansion ===
                                        still says disconnected until i issue M140 S(>55)...
                                        I'll uncomment the last line of config for now...
                                        Voltage test with meter did not show anything wrong....
                                        PUZZLE....
                                          dorro1971
                                          tried it with ethernet disconnected just in case...still no difference...
                                          10 out of 25
